  #1
Old 01-09-2019, 10:43 AM
Columbus450's Avatar
Columbus450 Columbus450 is offline
Default Any real life Reviews on WC fab cold air intake?? Dyno testing?
I wasnít sure what section to put this in so please move it if itís in the wrong one
I am running the Danville BMW 3794 65mm with his tunes
Pushing about 600 hp I am still on the stock intake set up Iíve heard the OEM LBZ air filter Doesnít flow as well over 500 hp not sure if thatís true,
Love love the filtertration of the Donaldson OEM filter
I was really wanting to dress up under my hood with the WC fab intake In illusion blueberry we all know they are very pretty but how effective actually are they feedback please thanks!!
  #2
Old 01-09-2019, 11:47 AM
Bdsankey's Avatar
Bdsankey Bdsankey is online now
Gearhead
Default
It is a good kit. Personally I like to push the WCFab or HSP intakes at my shop for someone with a drop in turbo as they flow the best in my opinion (smoothest bends, smoothest inner surfaces to keep flow laminar, less gap between pipes in the boots etc).
You can't go wrong with any of them on a drop in turbo. A stock turbo is a little more forgiving in terms of its maximum air requirements.
__________________
Current Rides:
1) Toy: 2005 LLY ECSB, Leather, Sunroof
-820hp/1748ft-lbs @ Duramax Tuner (6/25/18) - Old 475/87/1.00 setup
-Built Motor, Forced Inductions Billet ETR 480/96/1.10 T6, Modded Exergy 250% Injectors, Exergy 14mm Street Pump/LBZ CP3, Goerend J Converter, Billet Trans, Fuelab Supply Pump/Reg, RCD Sump, Front E-Locker, TrueTrac, Yukon 4340 Rear Shafts, Traction Bars, DHD Center Link Brace, DHD Lower Crossmember Support
2) DD/Tow Rig: 2002 LB7 CCSB, Leather, Loaded
-Bosch NEW Injectors, FASS 150, 3" Downpipe, 4" Downpipe Back, RCD Sump, PPE Sleeves, DHD Centerlink Brace, DHD Lower Crossmember Support, Steering Wheel Radio Control Swap
  #3
Old 01-09-2019, 01:44 PM
gmduramax's Avatar
gmduramax gmduramax is offline
Shits broke
Default
In my opinion, any intake that gets air from under the hood isn’t good. Drag racing with your headlight out would probably be fine.
__________________
2008 GMC duramax crew cab short bed 2500.
10.98@124mph
Thanks to Mike L, SoCal Diesel, and Abel Chevorlet.
Tailgate Crew Member #1
  #4
Old 01-09-2019, 02:08 PM
MarkBroviak's Avatar
MarkBroviak MarkBroviak is offline
DMax Junkie
Default
Quote:
Originally Posted by gmduramax View Post
In my opinion, any intake that gets air from under the hood isnít good. Drag racing with your headlight out would probably be fine.
Agreed! LBZ mouthpiece and a Banks Ram air intake is the best possible parts combo for most power available. I have an S&B on my personal truck because it came on the truck and I'm cheap lol. The quality of the WCFab is awesome and I love the look of them and they work great but the downside is the underhood heat and the metal piping transfer the heat to the intake air.
__________________
06 LBZ "White Lightning" 2wd rclb Stockish Grizzly Locker 3.42 gears Current fastest pass 1.520 60ft 6.705@108.95mph 1/8th 10.242@140.11mph
Current Standing 1/2Mile record holder for Diesel Pickup @ 159.8mph
Made it on fastest DMax list with Single VGT and single cp3 fuel only! 1.589 60ft 6.9291@103mph 1/8th 10.96@127.76mph
Stock motor best 11.277@119mph B68mmStg2R 250%inj 12mmcp3
Wife's tow rig-08 LMM SierraHD SLT2 "Stormy" CCSB murdered out TCTLMMStg2 Exergy 12mmcp3 1/8th 7.93@88mph 1/4-12.408@109.18mph
06 GP GXP 5.3L StealthGray Metallic
http://www.danvilleperformance.com
http://www.youtube.com/markbroviakdp
http://www.youtube.com/channel/UCV6K...?feature=watch
Mark@DanvillePerformance.com
Proud and Honored to be able to say I'm the tuner for some of the Quickest and Fastest Dmax's out there! Stock motor Dmax pass with bolt ons and vgt(JKlennon - 9.96 @ 134.05 (5/11/18) Fastest Allison equipped Dmax power truck and first into the 5's with an Allison(Mike Graves Prostreet - 9.068 @ 161.19 (7/16/17)Fastest Crewcab with an Allison(Mike Graves 9.555@149.50(4-22-17) Fastest LLy and Fastest street Truck ever(bcdeutch731 C-10 - 8.395 @ 168.13 (9/22/16) Fastest LMM ever(Harbin_22 - 10.12 @ 138.12 (05/01/18)Fastest VGT turbo truck(Dmax02 (Alex) - 9.893 @ 139.62 (6/10/16) The #1 and #2 Fastest ZF6 trucks in the world (Ryan Pini LLY ZF6 10.674@132.4mph) #2 is with a stock engine(Jesse Rhodes 10.912@130.27mph)
  #5
Old 01-09-2019, 02:18 PM
Chevy1925's Avatar
Chevy1925 Chevy1925 is offline
Default
x3.
__________________
Quote:
Originally Posted by JoshH View Post
Mike L is my role model. I want to be like him when I grow up.
James
02 LB7, LLY, LBZ, LMM, LML, L5P 2500HD CC/LB dmax/alli "The Limo"
BIG THANKS TO: Mike L, Steve, Trent, Guy, Dan, Ruben, Josh H, Scott, Brian and everyone else who has put a hand in to help me.
best time to date: 12.39
motor died/bent rods = 3/11/11
back from the dead 7:04pm 4/9/2012
Limo is back in the garage, now driving a built chevy tracker
Tailgate Crew Member #4
  #6
Old 01-09-2019, 10:01 PM
Yngdmax92's Avatar
Yngdmax92 Yngdmax92 is offline
Default
So what's the stock lbz intake good for?
I have the same set up, billet stg2 with upgraded vanes. I have zero smoke with marks tunes. 3150 us sounds about right from what I've seen.
__________________
2003 2500 hd cc/sb (leftovers) MPS 63.5 ihi, built trans, airdog 150, 30 overs..... Sold
New and improved! 2007 classis lbz LS ec/sb
Egr delete, pcv re-route, PIPED, airdog 4g 165,
Danville performance tunes.
  #7
Old 01-10-2019, 07:06 AM
Duramax racer 8 Duramax racer 8 is offline
Gearhead
Default
Lbz mouth piece and banks!!
  #8
Old 01-10-2019, 07:08 AM
The smoke I have from Marks tunes is very minimal just a little puff on heavy acceleration till the turbo lights , it will throw the most which isnít real bad either on the Built trans #5 it will sit and get ! , never did I suspect it was related to the air filter,Itís a diesel and modified dumping lots of fuel....
Needless to say thanks a lot for the info i got the Wcfab kit coming on the way
And Mark I like the idea of the bianks scoop sitting under my bumper sucking nothing but cold air ,But also I could see it getting muddy and getting crap in there also Iím not a fan of plastic intakes
  #9
Old 01-10-2019, 07:35 AM
Chevy1925's Avatar
Default
put the truck on the dyno and run it with and without the paper element. The info on stock air boxes is old as shit and frankly, i wouldnt trust it. the test done way back then were never done with the turbos and tuning we have today.
75 bucks to hit up a dyno day would be the cheapest way to know if you need to jump to a banks type setup (or any other intake that will separate under hood air from outside air) or stay stock. The paper filter will be the restriction, not the tubing size.
__________________
James
  #10
Old 01-10-2019, 07:39 AM
Bdsankey's Avatar
Gearhead
Default
I know my truck picked up 37hp on the dyno with a 4094 68r, 60% overs, 10mm pump the second we removed the S&B filter. I left the airbox there just pulled the element. We did 5 runs filter on and 5 runs filter off and the average gain (peak) was 34.8hp. The curve was also fatter down low but not enough to write home about.
__________________
Current Rides:
  #11
Old 01-10-2019, 07:41 AM
Yngdmax92's Avatar
Default
I guess until I see smoke out the pipe I don't really have the desire to do an intake unless it's for looks.
Truck spools instant and runs frican mint! If you feel a difference, report back.
__________________
  #12
Old 01-10-2019, 08:02 AM
OK so with the testing that was done way back then before the turbos and tuning we have now wouldnít the results be even worse now with (factory element )
Since were running bigger turbos that demand even more air flow I would see it as a choke point
  #13
Old 01-10-2019, 08:03 AM
Chevy1925's Avatar
Default
that doesnt mean much. your visual test and butt dyno will never be able to tell you the difference. your MAF sensor will trick you.
__________________
James
  #14
Old 01-10-2019, 08:06 AM
Default
My trucks spools freaking instant as well, if I actually feel a difference I will report,Probably will be more sound over anything we will see I know the best way to tell is put it on the Dyno
  #15
Old 01-10-2019, 08:21 AM
Chevy1925's Avatar
Default
Quote:
Originally Posted by Columbus450 View Post
OK so with the testing that was done way back then before the turbos and tuning we have now wouldn’t the results be even worse now with (factory element )
you would think so.
there is a bigger side to this you need to look at too. The effectiveness at the air cleaner doing its #1 job.... keeping the air clean. you will never out do the stock paper element in that factor unless you go to a different air box that again uses a paper filter. Most aftermarket filters flat out dont keep enough dirt out for turbo applications. Dry filters will never get fully clean when you try to clean them, they keep shit packed between the layers because they are so tightly woven. good for clean air, bad for reuse, still does not filter as much as paper. oiled requires many layers to keep up. The more surface area, the better. allows for more flow and the ability to catch dirt over time.
if you are sacrificing some ponies for clean air, is it worth it? if you want to keep things as clean and pull air in as well as it should but gain a few ponies, go with the banks.
Just fyi, the testing from way back when was the stock 01-05 filter and housing was good for 500rwhp. the 06-10 was good for 600rwhp. again, take with a grain of salt but i would bet you MIGHT be missing 50-60hp using the stock setup from filter to no filter.
__________________
James
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vB.Sponsors
