Old 02-09-2019, 07:17 PM
Rooftop Special Rooftop Special is offline
Gearhead
Default Oil priming after build - leave glow plugs out?
Hey Guys,
So it's been a slow process (primarily because of me) but I have the engine about ready to go back in. The machine shop said to leave the glow plugs out so I don't build pressure while I'm cranking the engine to oil prime it. I've read here to just leave the bail connectors undone, crank until you see oil pressure and you should be good to go?
Let me know. Thanks guys!
Casey
Old 02-09-2019, 09:12 PM
kidturbo's Avatar
kidturbo kidturbo is offline
Piston Tester
Personally I'd go with machine shop way. Cranks faster, primes quicker with no cylinder pressure. But also pull ecm fuse or disconnect bail so as not to fire the injectors.
Sent from my SAMSUNG-SM-G890A using Tapatalk
Old 02-09-2019, 11:26 PM
DAVe3283's Avatar
DAVe3283 DAVe3283 is offline
If you used a high quality assembly lube, you should be fine leaving the glow plugs in. I did mine that way when I built it, just unplugged the FICM fuse. But it is less stress on the engine to remove the glow plugs.
My engine was fired the day after it was assembled though. If yours has been sitting a long while, it's probably worth the effort to pull the glow plugs.
Old 02-10-2019, 07:54 AM
Bdsankey's Avatar
Bdsankey Bdsankey is offline
Gearhead
I filled my oil pump with Schaefer’s moly ep, unplugged FICM plugs then watched for oil pressure on my cts2. Once I saw oil pressure I plugged the FICM back in and haven’t had any issues.
I left my glow plugs in.
Current Rides:
-Tuned by Zach @ Starlite
-Built Motor, Forced Inductions Billet ETR Gen 4 S480/96/1.10 T6 w/V2 Race Cover, Modded Exergy 250% Injectors, Exergy 14mm Street Pump/LBZ CP3, Goerend Q Converter, Billet Trans, Fuelab Supply Pump/Reg, RCD & Beans Sumps, Front E-Locker, TrueTrac, Yukon 4340 Rear Shafts, Traction Bars, DHD Center Link Brace, DHD Lower Crossmember Support
-Tuned by Starlite
-Bosch NEW Injectors, FASS 150, 3" Downpipe, 4" Downpipe Back, RCD Sump, PPE Sleeves, DHD Centerlink Brace, DHD Lower Crossmember Support, Steering Wheel Radio Control Swap
Old 02-10-2019, 12:37 PM
torqued2dmax's Avatar
Originally Posted by Rooftop Special View Post
Hey Guys,
Casey
2 1/2 months thats not bad for that big of a project , welcome back !
05 CC/LB DRW LLY Allison
Old 02-10-2019, 08:26 PM
hondarider552's Avatar
hondarider552 hondarider552 is offline
Getting faster
Tom (thebac) made a garden sprayer with a fitting to the main oil gallery. Use the search it's here somewhere
"OldManTan"
04 SC/SB 1500 big fuel, big SXE turbo, TH400 8.91@155 5.76@126
06 Cummins cc/sb EFI by Hardway.
15 Cruze diesel deleted by Fleece
Tailgate Member #1 I prefer the backdoor
Old 02-11-2019, 01:58 PM
Gearhead
I did see that, pretty cool but I think since I'm not really doing a lot of these, just this one hopefully, it would just sit around the garage afterwards.
Old 02-11-2019, 02:04 PM
Gearhead
Thank you Sir. The machine shop had it like a month, maybe 5 weeks. I had them build it into a long block. Then it sat at my house until I bit the bullet and started cleaning everything up and bolting it back together. Glad I labeled everything and took a lot of pictures.
If you look at the project as a whole it is intimidating but if you do one thing at a time it really isn't a "hard job", just time consuming.
Now I'm working on bellhousing and torque converter bolts, FUN!
  #9
Old 02-11-2019, 06:15 PM
Do not forget red loctite or coated bolts , new ones , on converter and keep up the good work !
  #10
Old 02-11-2019, 06:49 PM
TheBac's Avatar
TheBac TheBac is offline
A little Dawn dishsoap and hot water and the sprayer went back to being a sprayer. IIRC, I used it last to spray weed killer.
Thanks for the shout out, Brian.
Tom
  #11
Old 02-11-2019, 07:41 PM
Gearhead
I thought it was blue loctite and torqued to 60lbs? Can you confirm it's red?
I intended on using the old bolts as I read several posts where others have done that.
  #12
Old 02-11-2019, 07:51 PM
Ne-max's Avatar
Ne-max Ne-max is offline
I like turtles
Dont use red. Blue only.
2013 ccsb Tow rig
2006 rclb 6.6
The fun stuff. Built motor, trans, triples, nitrous
  #13
Old 02-12-2019, 03:04 PM
I was going off of Mike Ls post , he said red or coated he sells them , new only , all I know is what he posted , but that was an old post thoughts may have changed !
  #14
Old 02-12-2019, 03:51 PM
Well I looked and looked and the only post I can find is the one of him saying if you use red you will need to apply heat to it prior to removal , sorry if I may have given you advice that is not current !
  #15
Old 02-12-2019, 04:05 PM
Yea , I just found it 12-07-2008 ,post #9 Mike L , blue is for gun sights only , use red with new bolts ! I about went crazy thinking I misread the post !
