Old 07-23-2018, 12:16 PM
Dante2795 Dante2795 is offline
FNG
Default Pulling with lowered truck
Looking to do my first sled pull but Iím worried my truck being to low will cause problems. It has 3in shackles with 2 leafs removed and I donít have air bags. Will that cause too many issues with raising my front end? Any info would be greatly appreciated.
07.5 LMM
100s, Dual pumps
Stock Lly turbo with 10 blade turbine
11.5 @117mph
Stock long block
Old 07-23-2018, 12:42 PM
Chevy1925's Avatar
its certainly not going to help you in pulling the sled unless you have a hitch that will raise way up. you want the sled to pull the ass end down and drive it into the ground to help get more traction. By no means does this mean you cant go out and have fun.
as for how it sits, unless you have axle wrap bars, i wouldnt attempt it. pulling leaves will make that thing want to axle wrap like crazy when under load and power. if you still have the stock overload, you can clamp that to the leaves that are left to work as a axle wrap control (old school way alot of guys did way back when)
James
best time to date: 12.39
Tailgate Crew Member #4
Old 07-23-2018, 12:47 PM
Duramax racer 8 Duramax racer 8 is offline
Gearhead
Get bags and stops
Old 07-23-2018, 12:56 PM
FNG
Truck does have traction bars so I’m not worried about axle wrap. Just not sure if it being so low will even be worth it to hook it to a sled
07.5 LMM
100s, Dual pumps
11.5 @117mph
Stock long block
Old 07-23-2018, 01:40 PM
JoshH's Avatar
JoshH JoshH is offline
Get some pulling bump stops and you should be good to go.
06 Silverado 4x4 CC/SB
Old 07-23-2018, 08:30 PM
Dozerboy's Avatar
Dozerboy Dozerboy is offline
So what if your lowered your still going to have fun right? You might even get lucky and do pretty well.
06 GMC 2500 CCSB SLT LBZ 4X4
