  #121
Old 06-17-2018, 10:32 PM
ROGUE GTS ROGUE GTS is offline
In for updates. Love my lly but this is the one thing i wish it had. Couple updates will keep me from shopping for an lml denali 4x4.
Sent from my SAMSUNG-SM-G920A using Tapatalk
04.5 LLY CC/SB 4x4 DA.
  #122
Old 06-18-2018, 04:27 AM
PULRIG's Avatar
PULRIG PULRIG is offline
FNG
Anyone running this on a built transmission? I have a BD-Power Trans. Will it work or would it mess up how BD has the Trans. setup? I imagine it would be fine...
2005 LLY CC/LB 4X4. 6" lift, 35X12.5X 20 Toyo AT II, 4.56 Gearing. BANKS Intercooler, Cold Air Intake, 6 Gun Programmer, and Speed Brake. S&B Turbo Mouthpiece. BD-Power Full Bore Exhaust Manifold. 4" Exhaust. ARP Head Studs. PCV reroute. EGR Blocker Plate. BD-Power Transmission and Multi-disc Convertor. BD-Power Trans. Cooler with Fleece Trans. Cooler Lines. FASS Lift Pump. Full Kryptonite front end (Control Arms, Ball Joints, Tie rods, Idler, and Pitman supports). 5" Aluminum Dirve Shaft conversion. Sulastic Shackles. AMSOIL Duel Bypass Oil Filter System. 100% AMSOIL Fluids.
  #123
Old 06-18-2018, 06:42 PM
stibuilder's Avatar
stibuilder stibuilder is offline
I sure would like to have TAP Shift on my 06/07 Kodiak with the 6th speed. Drove a LML from Seattle to Oklahoma and back with it, sure made for easy living in the hills.
2007 Kodiak C4500 (quadcab)
Efi Live, FASS 150, Custom Exhaust, Bunch of Gauges, Tahoe Headlights, Custom Stereo,National Air Seats, Flat bed, Profab Y Bridge, ARP Studs, 12x12x2 Oil cooler, BAT Sandwich adapter, 12x12x2 trans cooler, Oil Pressure/Temp Gauges, Belly mount Onan 5500w Generator. LDS 30% Overs.
28FT Intech Car trailer
@stibuider
  #124
Old 06-19-2018, 07:06 AM
Bustedknuckles's Avatar
Bustedknuckles Bustedknuckles is offline
Honey Badger
Originally Posted by Chevy1925 View Post
i wouldnt when ran with this 6 speed conversion until dialed in. the 2-1 can be EXTREMELY harsh in the morning, enough it has locked up my tires a couple times. 4-3 lets you know its there but nothing butt puckering. The G3's have always had aggressive downshifts though from what i hear from other people. When i had the stock valve body, these symptoms were there but not near as bad. More of an annoyance in the mornings but it was worth the added strength to me to just ignore it. Right now, no one has a fix for it and honestly, i think alot of guys are not worried about. youre not under power to kill parts.
So a hard 2-1 downshift with alto G3s is somewhat normal? I've built 3 trans with them in C3 and my personal truck has a hard downshift when you first drive it. None of the other trucks do though and all three have the same setup.
Sent from my SM-G955U using Tapatalk
04 lb7: 06 front clip, EPR s366, 30% over injectors, ARP head studs, Idaho-Rob tunes, airdog, PPE trans, Precision ML converter, etc......
  #125
Old 06-19-2018, 07:17 AM
Chevy1925's Avatar
C3 clutch pack isnt used in 1st or 2nd gear
James
best time to date: 12.39
Tailgate Crew Member #4
  #126
Old 06-19-2018, 01:16 PM
onebaddmaxxx onebaddmaxxx is offline
they cause a jerk in the 5-4 and 3-2
2005 lly
Lots of thanks to Diesels Unlimited, Evan@limitless, Mark@danville
  #127
Old 07-23-2018, 03:06 PM
chevyburnout1's Avatar
chevyburnout1 chevyburnout1 is offline
Fixing it till it breaks
Finally swapped tuning and am enjoying it greatly! 6th gear comes in around 57mph slowly accelerating. Holds the higher gears even with more throttle input which even with my build is still great. Besides the stupid Allison cold shift strategy hanging the gears too high, the shift timing seems perfect and my half throttle 4-5 flair has gone away. The transmission may be getting weak but until then it gets the job done!
Dustin
'03 Silverado LB7
GT3788/CT6x88mm compounds _ 60's _ duals _ fingers _ 6480af
'77 K-10
52"/56" front/rear leaf springs and rear shackle flip: 8" lift total _ D60/14blt 4:56s _ 40" Swamper IROK's _ 383 w/nitrous _ SM465 _ 208tcase
'97 Cadillac Deville
Morimoto Mini 5000k projector headlight conversion _ 500watts in the trunk _ 20's _ Flowmasters _ Tuned ECM _ Rear mount turbo in the works....
  #128
Old 08-07-2018, 01:00 PM
Also just noticed something this weekend that I can't remember if it was mentioned. But there is a 2nd gear start programmed into the strategy when selecting 2nd gear. Flipping sweet!
Dustin
'03 Silverado LB7
'77 K-10
  #129
Old 08-07-2018, 01:11 PM
Chevy1925's Avatar
does it actually start in 2nd or do you feel it quickly shift to 2nd soon as you touch the throttle?
James
  #130
Old 08-08-2018, 12:36 PM
It starts in first then jumps to second touching the throttle. The 2-1 downshift still seems to be normal when coming back to a stop.
Dustin
'03 Silverado LB7
'77 K-10
  #131
Old 08-08-2018, 12:41 PM
Chevy1925's Avatar
ok, 10-4. i thought maybe Josh found the tables to make it STAY in 2nd gear at all times even at a full stop (think its one of the things he has to search for when hes bored). the 06-up trucks will stay in 2nd when you make a 2nd gear start tune, its just the 01-05 that do this.
James
  #132
Old 08-08-2018, 05:54 PM
PureHybrid's Avatar
Isuzu Shakes IT
That would sure be nice, I'd daily a second gear start tune if it didn't downshift to first when stopping.
8.17@84mph 1/8mi
Jesse
  #133
Old 11-06-2018, 11:53 PM
bigmackmiller's Avatar
bigmackmiller bigmackmiller is offline
Any updates on this working with a tap shifter?
2007 LBZ EXT CAB S/B 4x4 SLT
4' MBRP SS
  #134
Old 11-07-2018, 07:24 AM
Chevy1925's Avatar
ive seen prototypes. Should be soon!
James
  #135
Old 11-07-2018, 06:29 PM
Hell yea!
4' MBRP SS
