  #1
Old 07-13-2018, 09:53 PM
Nickracer9 Nickracer9 is offline
Gearhead
Default Tranny acting up on built Lmm
So truck has been kinda shifting hard into gear the last week or so and then down shifting from 4-3-2-1 it sometimes really shakes the truck. Doesnít do it every time but every few times. Thought it was my a/c running as temps have got a lot hotter thus affecting the shifting/tuning. Well today I was getting a coffee and I noticed the engine temp getting warmer and warmer. As it climbed from 190 to 215 just at idle. So as I left it was stuck in 1st gear then would rev up and then all of a sudden it locked up and I could hear the rear tires almost skidding. Stopped, turn truck off for a couple minutes and it was fine. Whole way home it was normal then it stuck in 4th gear when I pulled into my development(no code). Really seems heat related but for the most part temps were within a hundred degrees of ambient 190-200. Any ideas? Truck is built lml in a lmm with built trans and compounds(1000whp).Also have a fleece alli locker and I def get my share of p0700 when itís turned on. Disconnected it after today and it was still acting up. Thanks again.
Sent from my iPhone
  #2
Old 07-14-2018, 02:55 AM
48548 48548 is offline
Gearhead
Default
You need to use a better code reader. 700 is a generic trans default code. A tech 2 or mdi would work.
Sent from my SM-G955U using Tapatalk
  #3
Old 07-14-2018, 10:13 AM
Harbin_22's Avatar
Harbin_22 Harbin_22 is offline
Turning it back up!
Default
Who built the trans
__________________
10' CCSB
Carrillos, Fingers 16.5:1 Cast Pistons, 3388AF Cam, PPE Dual CP3's, Exergy 200% inj, Danvile Billet 72R, HSP tripples/2-SXE369's, Limitless Diesel All Billet Comp Trans with LD TC, DHD lock up, Air Dog, Banks, RDL, CalTracs, QA1, M/A, Isspro, Novakanes/420's, 30x14 cheaters
Tuning from Mark@Danville
1,101HP/1727ftlbs
6.56@111 1/8
10.12@138 1/4
  #4
Old 07-15-2018, 12:07 PM
Gearhead
Default
Sdp, Iím waiting to hear back what he thinks. It feels like the tranny is running like full fluid pressure at light throttle. I let the truck cool off and it drives ok but still the aggressive shifts. I did recently change the spin on filter and the magnet looked pretty clean. Idk?!?
  #5
Old 07-15-2018, 12:25 PM
Mike L.'s Avatar
Mike L. Mike L. is offline
Default
Maybe a broken spring in the trim valve bore.
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #6
Old 07-15-2018, 12:33 PM
Gearhead
Default
I was gonna drop the pan and take a look. Is there a way to check oil pressure or codes with efilive that the edge cts might not be seeing? Thanks
  #7
Old 07-18-2018, 07:01 AM
Gearhead
Default
Tech2 said p0777 pressure control solenoid number 2 stuck on and p0732 incorrect second gear ratio. Seems to shift up ok but canít shift back down from 4th gear and then itís stuck in 4th with a CEL. Any ideas? We did try a new tcm as well. Thanks.
  #8
Old 07-18-2018, 07:42 AM
SickLL7Crenshaw's Avatar
SickLL7Crenshaw SickLL7Crenshaw is offline
Billy The Kid
Default
Is the TCM tuned? If so by who?
__________________
Blake
SOLD: 05 LLY CC/SB 140k 11.18@123.7 stock/480
01 LB7 EC/SB 308k 11.31@119.8 69sxe stock motor
Tuned by Unleashed Duramax Tuning
Crenshaw Ranch, LLC. 8LB7s, 7LLYs, 1LBZ , 2LMMs, 1L5P
Thanks to Evan@Limitless, yellowchevy, and Henry@COTNP
  #9
Old 07-18-2018, 09:16 AM
Gearhead
Default
Iíve tried a tuned tcm by Mark and a new stock lmm tcm. Same issue.
  #10
Old 07-18-2018, 04:09 PM
Gearhead
Default
Well I was pulling the psm(pressure sensing module I think?)off the valve body and noticed that one oring is blown out and another is questionable. Should I stop here or pull the trim valves out too? Thanks guys!!! Feel like Iím getting close
  #11
Old 07-18-2018, 04:21 PM
Mike L.'s Avatar
Default
Quote:
Looks like you found it.
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #12
Old 07-18-2018, 04:27 PM
Gearhead
Default
Thanks Mike. I’m gonna leave the trim valves alone for now. These orings really look degraded though.
  #13
Old 07-18-2018, 08:32 PM
Gearhead
Default
That oring fixed it! Finally back on the road
  #14
Old 07-18-2018, 09:03 PM
2004LB7's Avatar
2004LB7 2004LB7 is offline
Default
Thanks for the update. Not everyone gets back after a repair
__________________
2008 Chevrolet 3500HD DRW LTZ
285/75/17 Nitto Dura Grapplers, 4.56 gears, Front and rear ARB lockers, Efi Live tuning by me, Raptor 160 LP, Cognito 4-6 NTB Lift, 4" Exhaust, Built Trans by Mike L.
2006 BRM Jetta TDI. Injectors, turbo, Malone custom tuning on ecm and tcm
  #15
Old 07-18-2018, 09:38 PM
Gearhead
Default
I spoke to soon, started acting up a bit. Drove it for a while just fine and then I went to tow haul and itís kinda aggressive with the downshifts, like the rear tires squeal from 4-3. Thought I had it :/
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
