Old 10-14-2018, 07:04 PM
boostwhore's Avatar
boostwhore boostwhore is offline
Drag racer wannabe
Default 72stg2r, sxe372ís in a triple setup?
Hey fellas, Iíve been bouncing around the idea of triples for my next setup. What are your thoughts on 72stg2r and sxe372ís as atmosphere chargers? Will likely be going to a 14mm cp3 or twin over my 12 and 250ís or so. Right now Iím pulling my 14k fifth wheel to the track and would love to continue doing so with this setup. Thoughts? Any guesses as to what it could make power wise?
Chad
2007 lmm: kryptonite front end, full billet trans by Sdp, SoCal engine ovals and Carrillos, 12mm exergy stroker, 100 over exergy injectors, sdp billet 68mm over billet 480, awesome tuning from Aaron at All in trucks.
Best 1/4 to date: 11.06 at 127 in the chase for 10ís.
Old 10-14-2018, 07:29 PM
Ne-max's Avatar
Ne-max Ne-max is offline
I like turtles
Your injectors are going to hold you back to the 1200hp matk. Save your money and get a 10mm pump. Also would do s369s.
2013 ccsb Tow rig
2006 rclb 6.6
The fun stuff. Built motor, trans, triples, nitrous
Old 10-14-2018, 08:21 PM
boostwhore's Avatar
Drag racer wannabe
Ya, I just wanted to stay somewhat driveable with the 250’s. Pulling a trailer with anything bigger might be a little bit much, but 1400-1500rwhp is where I ultimately would like to be. What injectors would you recommend for those power levels? Was thinking the 372 would leave a bit of room for growth.
Chad
Old 10-14-2018, 08:23 PM
Ne-max's Avatar
I like turtles
Ya, I just wanted to stay somewhat driveable with the 250ís. Pulling a trailer with anything bigger might be a little bit much, but 1400-1500rwhp is where I ultimately would like to be. What injectors would you recommend for those power levels? Was thinking the 372 would leave a bit of room for growth.
Nothing in that power range will work pulling. I would say you would need 400s since it's a lmm.
2013 ccsb Tow rig
2006 rclb 6.6
Old 10-14-2018, 08:53 PM
hondarider552's Avatar
hondarider552 hondarider552 is offline
Getting faster
You ain't gunna tow 15k with 1500hp on tap just letting you know... Can't have a race truck and a tow truck all in one...
"OldManTan"
04 SC/SB 1500 big fuel, big SXE turbo, TH400 8.91@155 5.76@126
06 Cummins cc/sb EFI by Hardway.
15 Cruze diesel deleted by Fleece
Tailgate Member #1 I prefer the backdoor
Old 10-14-2018, 08:58 PM
boostwhore's Avatar
Drag racer wannabe
They will be Lbz injectors like I have now. Do you think that turbo setup would be capable of those power levels? My only reason for wanting the vgt in the valley is to try and maintain some street manners/towabililty (don’t think that’s a word, you know what I mean).
Chad
Old 10-14-2018, 09:09 PM
boostwhore's Avatar
Drag racer wannabe
Talking
I have been around long enough, kinda knew this was the response I would get as far as power levels and towing. I have absolutely no experience with a truck of those power levels. But I am gonna do my very best to prove ya wrong, if nobody tried to do the impossible we wouldnít be where weíre at in this industry.
My favourite part about my current setup is pulling the trailer out of the pits after beating on dedicated trailer queens. Itís always good for a couple confused looks.
Chad
Old 10-15-2018, 06:34 AM
Nickracer9 Nickracer9 is offline
The s369ís should get you there but the valley vgt will be your restriction. Could probably get more if you gate around it. I was told by hsp you would need a s468 for the 12-1300whp range and a s472 for the 1400-1500 range. It sounds good but then I started thinking how much more stress the converter and everything else will be taking. Iím shooting for a true 1100ish with my 68 stg2r/71mm turbine and s369ís. Going with exergy 150ís but hoping they arenít too smokey since I tow often as well. Iíll let you know how my setup goes by mid November.
09 Lmm/Lml SoCal Diesel Stg3 engine. Danville performance 68stg2r/S483 tct, Exergy 150% over, Exergy 12mm, built billet tranny by Limitless diesel and me. Ecm/Tcm tuning by Danville performance. Hsp Triples S369sxe coming soon!
  #9
Old 10-15-2018, 08:02 AM
Ne-max's Avatar
I like turtles
They will be Lbz injectors like I have now. Do you think that turbo setup would be capable of those power levels? My only reason for wanting the vgt in the valley is to try and maintain some street manners/towabililty (donít think thatís a word, you know what I mean).
Still not enough fuel. Everyone compares injector percentages not realizing that's over factory flow. A lly 200% flows almost the same as a lbz 250%.
Josh H on here has a great deal on some lbz 250s
2013 ccsb Tow rig
2006 rclb 6.6
  #10
Old 10-15-2018, 04:03 PM
boostwhore's Avatar
Drag racer wannabe
Ya I’ve been looking at his injectors, need to finish building a house before I can move forward with the truck. Any guesses on where the 72 vgt ungated with the 369’s would run outta air assuming fuel is not an issue?
Chad
  #11
Old 10-15-2018, 04:12 PM
clrussell's Avatar
clrussell clrussell is offline
pro-procrastinator
Ya Iíve been looking at his injectors, need to finish building a house before I can move forward with the truck. Any guesses on where the 72 vgt ungated with the 369ís would run outta air assuming fuel is not an issue?
I think harbin made 1200 on 72 and 69s. Not sure though.
03 reg cab. Low and slow
07 crew long classic- stolen
  #12
Old 10-15-2018, 04:30 PM
MarkBroviak's Avatar
MarkBroviak MarkBroviak is offline
DMax Junkie
1256hp at the tires is the most I've personally seen from that turbo setup.
06 LBZ "White Lightning" 2wd rclb Stockish Grizzly Locker 3.42 gears Current fastest pass 1.520 60ft 6.705@108.95mph 1/8th 10.242@140.11mph
Current Standing 1/2Mile record holder for Diesel Pickup @ 159.8mph
Made it on fastest DMax list with Single VGT and single cp3 fuel only! 1.589 60ft 6.9291@103mph 1/8th 10.96@127.76mph
Stock motor best 11.277@119mph B68mmStg2R 250%inj 12mmcp3
Wife's tow rig-08 LMM SierraHD SLT2 "Stormy" CCSB murdered out TCTLMMStg2 Exergy 12mmcp3 1/8th 7.93@88mph 1/4-12.408@109.18mph
06 GP GXP 5.3L StealthGray Metallic
http://www.danvilleperformance.com
http://www.youtube.com/markbroviakdp
http://www.youtube.com/channel/UCV6K...?feature=watch
Mark@DanvillePerformance.com
Proud and Honored to be able to say I'm the tuner for some of the Quickest and Fastest Dmax's out there! Stock motor Dmax pass with bolt ons and vgt(JKlennon - 9.96 @ 134.05 (5/11/18) Fastest Allison equipped Dmax power truck and first into the 5's with an Allison(Mike Graves Prostreet - 9.068 @ 161.19 (7/16/17)Fastest Crewcab with an Allison(Mike Graves 9.555@149.50(4-22-17) Fastest LLy and Fastest street Truck ever(bcdeutch731 C-10 - 8.395 @ 168.13 (9/22/16) Fastest LMM ever(Harbin_22 - 10.12 @ 138.12 (05/01/18)Fastest VGT turbo truck(Dmax02 (Alex) - 9.893 @ 139.62 (6/10/16) The #1 and #2 Fastest ZF6 trucks in the world (Ryan Pini LLY ZF6 10.674@132.4mph) #2 is with a stock engine(Jesse Rhodes 10.912@130.27mph)
  #13
Old 10-15-2018, 05:46 PM
Harbin_22's Avatar
Harbin_22 Harbin_22 is offline
Turning it back up!
Depends on which calculator I use but mine is somewhere in the 1175-1325hp at the tire area lol. 72R with two SXE369's and 200% LBZ inj. Still tows my 4500# boat pretty well
10' CCSB
Carrillos, Fingers 16.5:1 Cast Pistons, 3388AF Cam, PPE Dual CP3's, Exergy 200% inj, Danvile Billet 72R, HSP tripples/2-SXE369's, Limitless Diesel All Billet Comp Trans with LD TC, DHD lock up, Air Dog, Banks, RDL, CalTracs, QA1, M/A, Isspro, Novakanes/420's, 30x14 cheaters
Tuning from Mark@Danville
1,101HP/1727ftlbs
6.56@111 1/8
10.12@138 1/4
  #14
Old 11-22-2018, 11:44 AM
Utahski's Avatar
Utahski Utahski is offline
My latest LLY setup is a 472 on top with 2-369 T4 atmospheres, 125% injectors. Stock valley CP, big Industrial stroker on top. Enough fuel. Makes just shy of 1300hp which is plenty. Hard tuning the smoke out at 4400-6500' elevation. I run mostly on tune 2, sometimes 1 and sometimes 3, anything more is unnecessary for street. I don't tow and doubt this setup would be very good.
'04.5 LLY / ECSB 4WD Green/gray
Built engine, EPR triples and tune
10.97@125.55
