Old 01-09-2019, 08:12 AM
reese600 reese600 is offline
FNG
Default Cam drive gear on crank pin sheared
I need some help, I need to remove the cam drive gear off the crankshaft. I don't want to remove the crankshaft, is there anyway to get this off without removing it or ruining the main bearings? I bought this LBZ to replace mine that ate 2 valves and ruined the engine. This engine has less than 30k on it. It came out of a 2007 classic that was totaled in 2009, it was a front end hit, that is why all 3 crank keys are sheared off. 2 shops tried to get the engine running, but they didn't dig in far enough to find the problem. They just replaced the timing cover and replaced the pin on the balancer. I wonder why it wouldn't start...(heavy sarcasm)
Old 01-09-2019, 09:01 AM
JoshH's Avatar
JoshH JoshH is offline
That gear is pressed onto the crank. I can't imagine removing it without putting the crank in a press.
06 Silverado 4x4 CC/SB
Old 01-09-2019, 09:18 AM
FNG
kinda what I'm afraid of.
Old 01-09-2019, 09:20 AM
Bdsankey Bdsankey is offline
The crank is going to have to come out. There is no good way to do it without pulling the crank. That said, you can reuse the main bearings as long as they look good and you put the caps where they belong.
Current Rides:
-820hp/1748ft-lbs @ Duramax Tuner (6/25/18)
-Built Motor, Billet S475/87/1.00 T4, Modded Exergy 250% Injectors, Exergy 14mm Street Pump/LBZ CP3, Goerend J Converter, Billet Trans w/DEFEO 6 Pinion Planet, Fuelab Supply Pump/Reg, RCD Sump, Front E-Locker, TrueTrac, Yukon 4340 Rear Shafts, Traction Bars, DHD Center Link Brace, DHD Lower Crossmember Support
-Bosch Reman Injectors, FASS 150, 3" Downpipe, 4" Downpipe Back, Beans Sump, PPE Sleeves, DHD Centerlink Brace, DHD Lower Crossmember Support, Steering Wheel Radio Control Swap
Old 01-09-2019, 09:28 AM
rfletes79's Avatar
rfletes79 rfletes79 is offline
The pic shows the reluctor wheel hub and oil pump gear misaligned with the crank. That pin broke for sure. Once you remove that hub then you can see the cam gear and pin. It might be fine, and your issue is just the hub in front of it. You should be able to pull that off with a puller. Just remove the crankshaft pin, pull the hub off and replace both pins once you have the hub off.
j
1970 Chevelle Duramax Hot Rod, '04 LB7/TH400-gear vendor, HTT 67.7 FMW, Wagler street intake, 65% S&S sticks, exergy 10 mil pump, SoCal AF3388, Valve springs, Push Rods, LBZ rods, cut LB7 slugs..... 10 sec cruzer :-)
2002 2500HD LLY 6 speed ally conversion
Old 01-09-2019, 10:04 AM
I don't think you can get behind the cam drive gear without pulling the crank due to the block/main getting in the way.
Current Rides:
Old 01-09-2019, 10:11 AM
Chevy1925's Avatar
Op, you better have the heads gone over. these are interference engines so if the cam goes out of time enough, pistons will meet valves and ruin your day.
pull the crank. its going to be way easier to fix the broke pins and get the cam drive gear back on without messing up the thrust bearings. will give you a good idea on bearing health too. just cause its low mileage does not mean things are not hurt. 30k miles and 12 years old means it sat alot of its life and could have been dry started a few times
James
best time to date: 12.39
Tailgate Crew Member #4
Old 01-09-2019, 11:06 AM
juddski88's Avatar
juddski88 juddski88 is offline
Freedom Diesel
It can be done in the truck with the right puller and some dry ice, but I do agree with the other guys here, your safest bet at this point is to tear it down and just rebuild it.
2001 Chevy 2500HD ECSB
"Sore Subject" - Still don't have time for it.
I would never have learned what I have without George Alexander, Mike Lovrich, David Browning, Matt Handwork, Ben Tyler, Evan Drosehn and countless members of this forum and others.
Thank you.
2014 Jeep Grand Cherokee Limited, Ecodiesel
  #9
Old 01-09-2019, 11:30 AM
rfletes79's Avatar
Crap, I didn't see the other photo which has the hub off, my bad. Pull the crank.
j
  #10
Old 01-12-2019, 06:31 AM
FNG
Default Wtf, rod caps????????????
Ok, so the crank is out. Valves did hit the pistons, all 8 exhaust pushrods are bent into pretzels. Valves and pistons look good. But what the hell is with the rods? All 8, the caps look like this, no other broken pieces. All I did was remove to rod bolts and separate them from the crank.
The heads are going to a machine shop, and being disassembled, cleaned and inspected. The crank is gonna get keyed. All of the bearings and crank look amazing, like it was just assembled.
  #11
Old 01-12-2019, 06:52 AM
jlawles2 jlawles2 is online now
Rod caps are fractured not cut to ensure proper fit and minimize the bolts job.
Lots of custom rods are done the same way now.
https://mitchell1.com/shopconnection...a-broken-part/
Silver Birch Metallic 2004.5 GMC K2500HD with 265/75's
Banks super scoop, tubing, intercooler, and cat back with the IQ on the Window (for now). BD driver side Exhaust manifold.
Airdog 150 on frame rail. Amsoil synthetics for lubrication, and dual Amsoil filters on the driver frame rail. PPE centrifuge install.
EGR blocked. PCV rerouted. Resonator blocked (reinstalled for looks). Bladerunner installed. Dead kitty by MBRP (front pipe) and down tube replaced with the MBRP (heat wrapped from the turbo down to the front pipe).
Performax Gauges by ISSPRO in pod over mirror and overhead console (console pod by PPE). Mike L Transmission.
----Looking to do an onboard air with a set of truck air horns. Want Nathan K5LA's but not in the budget at the moment.----
06 GMC CCSB 2WD LBZ SLT package. Traded for '17 Denali
18 Denali CCSB 2500 4WD Mineral Metallic with Cocoa/Dark Sand Interior
  #12
Old 01-12-2019, 12:55 PM
Burn Down's Avatar
Fractured cap technology, as mentioned above. Be very careful with rod and caps. Obviously don’t mix them up and never set or drop them on the fractured face, any dents on dings in the fractured face will compromise the joint.
04.5’ CCSB ole blue, built trans, mpi twins
03’ Reg Cab ZF 6
05’ CCSB ole crappy, built eng, built trans, mpi twins
  #13
Old 01-14-2019, 11:54 AM
FNG
OK guys, thanks for the replies, I thought I was losing my mind the other night.
