  #1
Old 12-02-2019, 06:08 PM
DylOrr's Avatar
DylOrr DylOrr is offline
Gearhead
Default Trans go converter valve- modifying for no knockdown
I am putting billet parts and checking everything out in my buddies trans. It was already built by a fairly local shop. The truck is getting a decent build and will be around the 900-1,000hp mark. I usually modify the stock valve for no converter knock down. This one has a trans go valve in it and unfortunately I don’t have any spare early 5 speed valves. Is it possible for me to tig weld up the hole on the end and the hole on the body and grind the valve just like you would a factory one? Or is there a better method, or is it just best to leave it and still let it knock it down some?
__________________
Dylan
2004 RCLB- remote mount s480, 200s, dual junkyard pumps
  #2
Old 12-02-2019, 06:22 PM
PureHybrid's Avatar
PureHybrid PureHybrid is offline
Isuzu Shakes IT
Default
What year? I'd just grind it and leave the spring / ball in there
__________________
04 GMC ECSB LLY - Mix breed trans/SC1056 - Kennedy twin pumps/pickup - 531/944
I can't complain, but sometimes I still do
8.17@84mph 1/8mi
Jesse
  #3
Old 12-02-2019, 08:01 PM
DylOrr's Avatar
Gearhead
Default
It’s an 02 trans. I know on the earlier ones on the stock valve you weld the hole in the end. I don’t know if I should do that to the trans go valve as well.
__________________
Dylan
  #4
Old 12-03-2019, 01:02 AM
PureHybrid's Avatar
Isuzu Shakes IT
Default
Your transgo valve still has a hole on the inner most end? I was thinking the old style valves had a hole, but came with a cup plug you had to install. Last one I installed for an 01-02 was solid on the end.
__________________
8.17@84mph 1/8mi
Jesse
  #5
Old 12-03-2019, 06:20 AM
Bdsankey's Avatar
Bdsankey Bdsankey is offline
Gearhead
Default
Quote:
Quote:
I just tore down a customers trans with a transgo boost lockup valve and it does not have any holes in the valve. I don't have a stock one as well and plan on just grinding the transgo valve.
__________________
Current Rides:
1) Toy: 2005 LLY ECSB, Leather, Sunroof
-1340hp/2200ft-lbs @ ATS Diesel (06/04/19)
-Tuned by Zach @ Starlite
-Built Motor, Forced Inductions Billet ETR Gen 4 S480/96/1.10 T6 w/V2 Race Cover, Modded Exergy 250% Injectors, Exergy 14mm Street Pump/LBZ CP3, Goerend Q Converter, Billet Trans, Fuelab Supply Pump/Reg, RCD & Beans Sumps, Front E-Locker, TrueTrac, Yukon 4340 Rear Shafts, Traction Bars, DHD Center Link Brace, DHD Lower Crossmember Support, Banks iDash 1.8 Monitoring System
2) DD/Tow Rig: 2002 LB7 CCSB, Leather, Loaded
-Tuned by Starlite
-Cast S475/96/1.10 T6 Over Stock IHI, FASS 150,4" Exhaust, RCD Sump, PPE Sleeves, DHD Centerlink Brace, DHD Lower Crossmember Support, Steering Wheel Radio Control Swap, LML Oil Pump, LML Piston Cooling Nozzles, 2020 L5P Oil Cooler, Derale Aux Oil Cooler w/Fan, Banks iDash 1.8 Monitoring System
  #6
Old 12-03-2019, 06:21 AM
Evan@LimitlessDiesel's Avatar
Evan@LimitlessDiesel Evan@LimitlessDiesel is online now
yerp
Default
Do yourself a favor and get a stock Valve spring and retainer to modify.
__________________
Limitless Diesel Performance
413-770-3585
  #7
Old 12-03-2019, 06:37 AM
Bdsankey's Avatar
Gearhead
Default
Quote:
10-4, I'll order a replacement. Which PN valve do you recommend?
__________________
Current Rides:
-Tuned by Starlite
  #8
Old 12-03-2019, 07:30 AM
yerp
Default
Quote:
Depends on what year your stator assembly is which valve you need.
__________________
413-770-3585
  #9
Old 12-03-2019, 07:36 AM
Bdsankey's Avatar
Gearhead
Default
Yeah, I found my book. Looks like it'll either be 29541144 or 29537334 depending on the stator. The truck is an 04 so I believe it could go either way depending on mfg date of the trans.
__________________
Current Rides:
-Tuned by Starlite
  #10
Old 12-03-2019, 09:20 AM
DylOrr's Avatar
Gearhead
Default
Can I swap stator assemblies to a 6 speed or are they different? Or even swap the whole stator, plate, pump assembly
__________________
Dylan
  #11
Old 12-03-2019, 09:57 AM
Mike L.'s Avatar
Mike L. Mike L. is offline
Default
Yes
__________________
Inglewood Transmission Service
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #12
Old 12-03-2019, 10:15 AM
DylOrr's Avatar
Gearhead
Default
I’ll just put a 6 speed set up in it then. Thanks for the quick help guys
__________________
Dylan
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vB.Sponsors
