Old 12-01-2019, 05:21 PM
LBZ_Baker98 LBZ_Baker98 is offline
Default TCC slip rate in TCM tune
I've got my LBZ TCM slip rate adjusted to try and help the converter lock at full throttle. It's set stock at 650rpm I think and mines adjusted to 900rpm. It works most of the time but sometimes leaves a bit to be desired. I know a lock up box is best but wanted to try adjusting the rpm to like 1200 or so and see what happens but not sure how it will be on the trans. It's a built trans with stock shafts running a goerend R converter. Thanks in advance
07 LBZ CCSB EFI Live DSP5 and trans tuning by (Who's ever tunes I decide to run that day) airdog 165, Built trans by Josh H. At Top Notch Garage
Old 12-02-2019, 12:01 AM
2004LB7's Avatar
2004LB7 2004LB7 is offline
I think mine is set to 2000 or something high like that. Haven't had any issues. But I don't race it like some others
2008 Chevrolet 3500HD DRW LTZ
Old 12-02-2019, 07:13 AM
N2BRK N2BRK is offline
don't know on the LBZ but I can say on the LMM that table does nothing. I'm surprised with stock air and fuel that you can't get an R to lock on it's own properly.
08 LMM Crew 4x4
Dipper Trans/Mark's 68mmStg2R/40 over LBZ tips
Exergy 12mm
Old 12-02-2019, 08:11 AM
Chevy1925's Avatar
you need to log how much difference you are getting (slip). adjusting it may not do anything else for you if the slip is below the threshold.
James
best time to date: 12.39
Tailgate Crew Member #4
Old 12-02-2019, 10:33 AM
True. Also, I ASSumed you adjusted the slip table in EFILIVE that is mapped wrong. If you had someone with the ability to properly modify the tune with a cax file, then you can truly change the slip limit and make it work properly.
08 LMM Crew 4x4
Exergy 12mm
Old 12-02-2019, 11:10 AM
2004LB7's Avatar
I'm pretty sure it was fixed in an update back in 2014
https://forum.efilive.com/showthread...!!-OS-25941752
Old 12-02-2019, 01:10 PM
No. Keep reading. Look around post 115 and 126. They mapped the wrong address. It still doesn’t work.
08 LMM Crew 4x4
Exergy 12mm
Old 12-02-2019, 01:34 PM
Yngdmax92's Avatar
Yngdmax92 Yngdmax92 is offline
Do you know how to do this? I'd be interested in this myself as well.
2003 2500 hd cc/sb (leftovers) MPS 63.5 ihi, built trans, airdog 150, 30 overs..... Sold
New and improved! 2007 classis lbz LS ec/sb
Egr delete, pcv re-route, PIPED, airdog 4g 165,
Danville performance tunes.
  #9
Old 12-02-2019, 01:35 PM
I cannot, sorry. Mitch (from that thread on efilive) did mine for me. He mapped it out and it works perfectly.
08 LMM Crew 4x4
Exergy 12mm
  #10
Old 12-02-2019, 03:01 PM
2004LB7's Avatar
That sure is interesting. Because it seems to work fine on mine. If I have it set too high 8k rpm???) it doesn't work. It seems as it it is out of range it will ignore it and cause lockup issues but if lower like mine (2k rpm) then it works great. But then again I'm only on stock air so I'm not pushing it as hard as some others
  #11
Old 12-02-2019, 03:10 PM
I tried it and found that weirdness too, if you max the table out, LOL. It was like a hybrid between T/H mode and normal... just weird.
I tried it at 2k and it did nothing. I tried it on my buddy's stock'ish truck with built trans and we found it got into lockup seemingly a little earlier in 3rd but neither truck ever locked in 2nd. With the properly mapped tune from Mitch it locks when it is supposed to. He has it right and it works perfectly. I don't know why EFILIVE wouldn't fix it. he shared his info with them. I tried to revive that thread in the past and it sits there dead.
EDIT: I just saw you're on 4.56 gears with 285/75, maybe you aren't having that much slip to worry about? Have you logged?
08 LMM Crew 4x4
Exergy 12mm
