  #1
Old 08-13-2019, 05:55 AM
turbo_bu turbo_bu is offline
Default CP4 class action lawsuit against GM
Not sure if this has already been posted, but just saw that there is a class action lawsuit against GM for the CP4 failures.
dieselprogress.com/more-legal-woes-for-gm-diesel-28292
__________________
Got Boost?
2004 CC SB LB7 Auto
OS - 15189044
  #2
Old 08-13-2019, 07:00 AM
JoshH's Avatar
JoshH JoshH is offline
Default
Yeah, I'm sure that'll go far....
__________________
06 Silverado 4x4 CC/SB
06 Express 2500 Duramax Van "The Dumpster"
  #3
Old 08-13-2019, 08:50 AM
2004LB7's Avatar
2004LB7 2004LB7 is offline
Default
I believe they tried this with the common rail TDI with their far higher failure rates and, if I'm not mistaken, basically got nowhere
There is a thread over on TDIclub with hundreds, if not thousands of users that have had failures, including mine.
One thing to keep in mind is Bosch was the manufacturer of the pump and not GM. And they have made several changes or improvements if you will that seems to have reduced the failure rates. The TDI has been using them for several years before the Duramax.
__________________
2008 Chevrolet 3500HD DRW LTZ
285/75/17 Nitto Dura Grapplers, 4.56 gears, Front and rear ARB lockers, Efi Live tuning by me, Raptor 160 LP, Cognito 4-6 NTB Lift, 4" Exhaust, Built Trans by Mike L.
2006 BRM Jetta TDI. Injectors, turbo, Malone custom tuning on ecm and tcm
  #4
Old 08-13-2019, 09:12 AM
Bdsankey's Avatar
Bdsankey Bdsankey is offline
Gearhead
Default
While Bosch is the supplier/manufacturer of the pump GM chose to use it and put it into a production application. What blows my mind is CP4 failures are much less common on the 6.7 ford platform what what I've seen on social media.
__________________
Current Rides:
1) Toy: 2005 LLY ECSB, Leather, Sunroof
-1340hp/2200ft-lbs @ ATS Diesel (06/04/19)
-Tuned by Zach @ Starlite
-Built Motor, Forced Inductions Billet ETR Gen 4 S480/96/1.10 T6 w/V2 Race Cover, Modded Exergy 250% Injectors, Exergy 14mm Street Pump/LBZ CP3, Goerend Q Converter, Billet Trans, Fuelab Supply Pump/Reg, RCD & Beans Sumps, Front E-Locker, TrueTrac, Yukon 4340 Rear Shafts, Traction Bars, DHD Center Link Brace, DHD Lower Crossmember Support
2) DD/Tow Rig: 2002 LB7 CCSB, Leather, Loaded
-Tuned by Starlite
-Bosch NEW Injectors, FASS 150, 3" Downpipe, 4" Downpipe Back, RCD Sump, PPE Sleeves, DHD Centerlink Brace, DHD Lower Crossmember Support, Steering Wheel Radio Control Swap
  #5
Old 08-13-2019, 09:44 AM
2004LB7's Avatar
Default
Quote:
Yeah, I was not trying to say they are off the hook but they are the ones who told GM that this pump was appropriate for this application and and was good for so many miles/hours, etc. In this application bosch is the material expert. So GM in turn would counter sue Bosch. I guess in the end, if enough pressure was put on them, it would likely be something like the LB7 injector debacle. Improved design, longer warranty, etc.
If either party can show (prove) they are actively working on the situation and taking care of the customers then a class action suit will almost never materialize
As for the ford, I wander if it is due to better filtration. These CP4s are very suspectable to contamination and lack of lubrication. Since they run on the same diesel we do, and I doubt they are more diligent in use of additives, then this leaves filtration.
Supposedly they also have a lift pump, and some have claimed it was the reason for the lower failure rates. But it doesn't explain why the cp4 in the TDI failed so much when they have lift pumps too.
__________________
  #6
Old 08-13-2019, 01:51 PM
NC-smokinlmm's Avatar
NC-smokinlmm NC-smokinlmm is online now
<<<Future tuna killer
Default
Just add a lubricant and or run lift pump, no air in a positive pressure system...
__________________
2010 GMC 1500 RCSB Denali Clone < lifted 22's/33's/ Kooks / Magnaflow / 5.3 / 6l80E / TVS1900 @ 14#'s / BTR Top End / Boosted Bump Stick / Trunion upgrade / 90mm / 10% over / 2.8 griptec / 105 lb ID's / Mayhem built/tuned.
2016 LML CCSB Denali < Lifted 22's/35's, Fox 2.0 < I officially need help.
  #7
Old 08-13-2019, 01:59 PM
Mike L.'s Avatar
Mike L. Mike L. is offline
Default
Doesn't matter as only the lawyers will win. They will get millions and us poor guys will get a free lube and oil.
__________________
Inglewood Transmission Service
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #8
Old 08-13-2019, 04:38 PM
Don@F1 Don@F1 is offline
FNG
Default
Quote:
Yup, usually 5 bucks per person and the firm gets millions.
  #9
Old 08-13-2019, 05:03 PM
2004LB7's Avatar
Default
Thats a pretty good payout. I was hoping for at least $4 but would settle for $3
__________________
  #10
Old 08-13-2019, 07:56 PM
JoshH's Avatar
Default
Fords fail just as often. I’ve personally had more Ford fuel system failures come through the shop than GM.
__________________
  #11
Old 08-15-2019, 10:31 PM
Dozerboy's Avatar
Dozerboy Dozerboy is offline
Default
Quote:
Originally Posted by JoshH View Post
Fords fail just as often. Iíve personally had more Ford fuel system failures come through the shop than GM.
Thatís pretty surprising to me. Everyone I talk to that works on diesels says the fords ainít failing as often.
__________________
06 GMC 2500 CCSB SLT LBZ 4X4
These views expressed on this post are not my own, but rather randomly generated computer gibberish, and in no way should be used to judge the author's IQ or mental health.
  #12
Old 08-16-2019, 08:11 AM
FNG
Default
VW CP4 style pumps die early too. They are a crap design. Maybe the latest revisions will be better.
Denso was in front of Bosch on common rail by at least 2 years. GM had to switch. The LB7 injector fiasco was just horrible.
In the end it comes down to tailpipe regulations. We needed too much pressure and complexity to achieve them. We also need clean air. So .....Im hoping the newest tech will get us there with more reliability.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vB.Sponsors
