  #1
Old 02-03-2013, 07:07 PM
GMC_2002_Dmax's Avatar
GMC_2002_Dmax GMC_2002_Dmax is offline
The Still Master
Default LMM P0299 with 4094 possible fix
I have a pair of trucks local to me with 4094/72mm chargers on LMM's.
Both are Danville chargers, both had/have intermittent P0299 conditions when lugging in 5th and mostly 6th gear or under slow acceleration on the highway or pulling grades with the TC locked in taller gears.
The one I retuned/logged today seems to be running fine without codes for P0299 and he tried everything he could to get it to code including a 2.5 mile grade that usually set the code easily.
The other local truck is coming by Tuesday for a reflash to see if his truck will run code free as well once I make the changes.
I have a third truck out of state that I am going to email a new file to with a standard Garrett 4094, not a Danville one to see if it also cures the random underboost P0299 codes.
If all tests out then I believe I got it figured out for cause/effect and a fix for it.
Stay tuned.
__________________
2019 Denali L5P - New Test Truck
2016 Denali LML
-> SOLD
2012 Denali LML - > SOLD
2007 GMC "Classic", LBZ, SLE1 ,RC/LB,
12.525 at 107.07 - > SOLD
2002-GMC Sierra 2500HD SLE/CC/SB/4X4~Powered By "MOONSHINE"
12.65 fuel only, 12.00 on some N20
Retired 04/18/2009 -> SOLD
  #2
Old 02-03-2013, 07:17 PM
blackdirtymax's Avatar
blackdirtymax blackdirtymax is offline
Default LMM P0299 with 4094 possiible fix
I Knew you could do it Tony !!!
__________________
efi live-blitzkreig motorsports tierods-mbrp exhaust
ported rail fittings- shimmed-PPE dual fuelers-PPE centrifuge- PPE guages(boost/pyro/rail pressure)-
GTX4202R (going single for a bit) stage 5 ppe tranny by me
MOTOR BUILD DONE
  #3
Old 02-03-2013, 07:52 PM
paint94979's Avatar
paint94979 paint94979 is offline
Beer Nazi
Default
Care to post said tune publicly
__________________
LLY's are COOL
HUGE Thanks to Chris, Mike L., McRat Racing, Total Performance Diesel, PPE, Trent, Wicked Diesel, Mike, Henry of Creatures of the Night, Exergy Engineering and the rest of Team Salad<--My Tailgate's Always open for all of you!!
11.84 @ 115
Tailgate Crew Member #2
  #4
Old 02-03-2013, 07:55 PM
duramax hd's Avatar
duramax hd duramax hd is offline
Default
Did the 'engineer' over at longhorn fab share with you his secrets
__________________
2001 Dmax/Alli CC/SB Pewter
RIP stock Rods and block....9/2/12....Built motor 12/12/12-Failed. On the road back to stock. Moonshine Tuned, Dipper trans, Mike L. Cooler,Ultra Predator 8's on 285/55/20 BFG G-Force's
  #5
Old 02-03-2013, 08:00 PM
The Still Master
Default
He emailed me the tune........along with the 250+ hp stock trans safe tune
__________________
2016 Denali LML
-> SOLD
  #6
Old 02-03-2013, 08:13 PM
Quote:
Omg , priceless
__________________
MOTOR BUILD DONE
  #7
Old 02-03-2013, 08:23 PM
jkholder09 jkholder09 is offline
Default
Well the best thing to do would be to set the boost table and then turn on rtacs and pid data drive it and set the vane table according to actual position. Are any of the guys running the charger in arms length of a v2?
  #8
Old 02-03-2013, 08:48 PM
The Still Master
Default
We don't log anything. We just change the numbers until it looks pretty on the screen.
__________________
2016 Denali LML
-> SOLD
  #9
Old 02-03-2013, 09:44 PM
Default
it always looks like a butterfly to me lol
  #10
Old 02-03-2013, 09:50 PM
messejme's Avatar
messejme messejme is offline
Jazzy, Me and Max
Default
I get a P0045 under the same situation. I need to do the RTAC. Everytime i try logging traffic keeps getting in the way
__________________
04.5 LLY dooley CC. EFILive, SC IV, 1058, race valve, Airdog-150, 4" stack, Socal built engine, S480 over GT4094vvt stage 2, 60% overs, arson III CP3, flo pro extreme headers and up-pipes, PPE dual CP3's
  #11
Old 02-04-2013, 05:53 AM
The Still Master
Default
Quote:
RTACS only works with Road Runner LS1 style pcm's for gassers and LB7's, I know because I have two Road Runner ECM's.
You would want to create MAP files and then cut/past the data into the tune and blend the areas, however the target boost number could not be met even when the ecm shifted the vanes to 100% closed, so setting target vane position was not the fix for getting boost to cure the P0299 codes.
__________________
2016 Denali LML
-> SOLD
  #12
Old 02-04-2013, 06:56 AM
Default
RTRACS only works with Road Runner LS1 style pcm's for gassers and LB7's, I know because I have two Road Runner ECM's.
yeah if its already maxed out, I guess it either needs more fuel or later timing thier to push the turbo, or reduce the desired boost?
also there is the 2 tables in lbz/lmm under engine calibration that say let the ecm control boost. once i get the vane map correct I usually set the fuel values above 125 so that the ecm never tries to control boost, it just follows the predetermined vane % that way if the guy gets a cac leak the ecm won't wind the vanes tight and overspeed the charger.
Is it possible that the maximum vane position table is not at 100% in that area and the ecm is just cranking them down to the max allowed vane position. I have fat fingered stuff before myself I know you probably triple checked everything
just trying to think of any little detail to help
  #13
Old 02-04-2013, 10:56 AM
duratothemax's Avatar
duratothemax duratothemax is offline
<--- slippery roads
Default
I think tony has it under control...
__________________
2012 Denali - R&D testbed for upcoming new products.....
2005 Silverado LT - Blown up/broken too many engines and parts to care about making it fast anymore, so its back to mostly stock - The best names in the industry for parts/advice/help...MikeL.Guy-SoCal.Rob-ATP.Evan-Limitless.McRat.BigDipper.Bobo.Tony-RRDP.Fingers.Eric-MA.EFILive...
BT DieselWorks, LLC - EFILive tuning - Duramax/Allison/gasser STANDALONE HARNESSES - Allison lockup controllers - Allison tapshift kits - Digital DSP-5 switches - full assortment of great electronic improvements and gadgets for your GM truck/SUV
All products available for sale through our online store at www.btdieselworks.com
Be sure to "like" us on Facebook at www.facebook.com/BTDWorks
Be sure to "follow" us on Instagram @btdieselworks
  #14
Old 02-04-2013, 11:01 AM
The Still Master
Default
We stuffed a rag in the intake to fool the boost sensor..........stopped it up like a toilet.
__________________
2016 Denali LML
-> SOLD
  #15
Old 02-04-2013, 11:05 AM
Duraeater6.7's Avatar
Duraeater6.7 Duraeater6.7 is offline
Gearhead
I need to borrow your rag
Twinned Lmm 120 over pump 100hp injectors
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vB.Sponsors
