  #16
Old 08-17-2018, 01:38 PM
NC-smokinlmm's Avatar
NC-smokinlmm NC-smokinlmm is offline
<<<Future tuna killer
Default
I believe it's associated with pop off pressure of bypass, the filter volume and media will change it...
__________________
2010 GMC 1500 SCSB Denali Clone < lifted 22's/33's, Kooks, Magnaflow, 5.3, 6l80, TVS1900 @ 10#'s, BTR titanium valve train, BTR custom grind boost cam, head work, 10% overdriven balancer, 2.8 griptec, 65lb sticks, Mayhem built and tuned, not enough traction yet
1969 MGB GT MKII Factory Condition
2016 LML CCSB Denali < Lifted 22's/35's, Fox 2.0 < I officially need help.
  #17
Old 08-17-2018, 08:41 PM
Chevy1925's Avatar
Chevy1925 Chevy1925 is offline
Default
The bypass is on the pass side in the other oil galley. Won’t be affect by oil filter type
__________________
Quote:
Originally Posted by JoshH View Post
Mike L is my role model. I want to be like him when I grow up.
James
02 LB7, LLY, LBZ, LMM, LML, L5P 2500HD CC/LB dmax/alli "The Limo"
BIG THANKS TO: Mike L, Steve, Trent, Guy, Dan, Ruben, Josh H, Scott, Brian and everyone else who has put a hand in to help me.
best time to date: 12.39
motor died/bent rods = 3/11/11
back from the dead 7:04pm 4/9/2012
Limo is back in the garage, now driving a built chevy tracker
Tailgate Crew Member #4
  #18
Old 08-17-2018, 11:01 PM
kidturbo's Avatar
kidturbo kidturbo is online now
Piston Tester
Default
Some filters have a pressure bypass built in. But doubt that's issue. Sounds like a drain back, try a different filter.
  #19
Old 08-17-2018, 11:27 PM
stibuilder's Avatar
stibuilder stibuilder is offline
Default
Filter that was on the truck was a Rotella, looks like the holes in it are much larger and oval compared to the circular ones of the new GM filter. Post oil change the oil pressure was about 10psi higher. Going to see how it starts in the morning and see if I get any change. I kept a sample of the oil ill send out to see if there is any metal in it and go from there. Ill post a picture of all the filters later on Saturday.
__________________
2007 Kodiak C4500 (quadcab)
Efi Live, FASS 150, Custom Exhaust, Bunch of Gauges, Tahoe Headlights, Custom Stereo,National Air Seats, Flat bed, Profab Y Bridge, ARP Studs, 12x12x2 Oil cooler, BAT Sandwich adapter, 12x12x2 trans cooler, Oil Pressure/Temp Gauges, Belly mount Onan 5500w Generator. LDS 30% Overs.
28FT Intech Car trailer
@stibuider
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vB.Sponsors
