  #61
Old 02-07-2018, 08:22 AM
dordtrecht5's Avatar
dordtrecht5 dordtrecht5 is offline
Regular Cabs Rock
Originally Posted by ikeG View Post
The distance between the centerlines of each cylinder bore. If it wasnt stock, you would also have to manufacture your own crankshaft, heads and rocker shafts etc for it to work. Stock bore spacing is required in all pulling classes.
If you look at big, big cubic inch gasoline stuff, like Sonny's, they change the bore spacing so the bore size can be humungous and still have material between the cylinders.
Sorry, maybe I worded it badly. I know the definition of "bored spacing."
I am asking what the spec is for the bore spacing on the block in the OP.
Sent from my Moto Z (2) using Tapatalk
'06 LBZ RC/LB 4x4
EFI by TDT
Super High Flow EGR delete kit and Centerlink support by AllSeason
GMAX6 & ML-G HD
BT DieselWorks Lock-up
12.59 @ 105
SOLD
02 CCSB LB7 EFI Big tie rods/PacBrake bags/DVD Pioneer head unit Rockford Fosgate speakers/110-120voltAC inverter/Mastercraft MTR
Thanks go out to 770JOHNNYW and blk smoke lb7
International Association of Bridge, Structural, Reinforcing and Ornamental Ironworkers Local 21 Omaha, NE
United Steel Workers Local 1343 South Milwaukee, WI
  #62
Old 02-07-2018, 09:36 AM
RPM Motorsports's Avatar
smokinum
Factory bore spacing, so factory parts will be a direct bolt on.
(Russ)
17 CC/SB L5P 4x4 High Country
73 RC/NB LBZ Nova Grocery getter
  #63
Old 05-01-2018, 06:24 PM
ctodd36 ctodd36 is offline
Gearhead
Where can a guy inquire about this?
04 ECSB 2.5 puller
15 CC Dually
  #64
Old 05-01-2018, 09:50 PM
smokinum
Going to be a while before we will even be close. There is so much involved, and I’m in no hurry to rush a block to be done. Still in the process of making molds, and will need to tool up the CNC once we have cores ready to machine. On a good note.., I got a call from Gale Banks today, he’s going to be sending us specs on including the L5P rear reluctor and sensor, so we can make one block work for any combination 01+ ����.
(Russ)
  #65
Old 05-02-2018, 02:59 AM
Gearhead
Originally Posted by RPM Motorsports View Post
Going to be a while before we will even be close. There is so much involved, and Im in no hurry to rush a block to be done. Still in the process of making molds, and will need to tool up the CNC once we have cores ready to machine. On a good note.., I got a call from Gale Banks today, hes going to be sending us specs on including the L5P rear reluctor and sensor, so we can make one block work for any combination 01+ ����.
Very nice! Ok I will keep in tune with this!
04 ECSB 2.5 puller
15 CC Dually
  #66
Old 05-02-2018, 04:42 AM
PureHybrid's Avatar
Isuzu Shakes IT
You know you've made it big when Gale Banks calls you with good info
8.17@84mph 1/8mi
Jesse
  #67
Old 05-02-2018, 04:53 AM
NC-smokinlmm's Avatar
<<<Future tuna killer
So are you making l5p crank fit older blocks?
2010 GMC 1500 RCSB Denali Clone < lifted 22's/33's/ Kooks / Magnaflow / 5.3 / 6l80E / TVS1900 @ 14#'s / BTR Top End / Boosted Bump Stick / Trunion upgrade / 90mm / 10% over / 2.8 griptec / 105 lb ID's / Mayhem built/tuned.
  #68
Old 05-02-2018, 09:01 AM
smokinum
No, talking about being able to use old style crank or new style crank in the blocks we are doing up.., not using an L5P crank in an old style block. Gale said I would have to add a sensor hole to the block, waiting to see the file of the rear of the L5P and will go from there.
(Russ)
  #69
Old 05-02-2018, 09:16 AM
smokinum
Nah, he’s a gear head just like all of us, very humble guy and always a wrath of great info. I hadn’t talked to him directly in a few years. We spent about 20min BS’ing about racing and a house he’s building up in the mountains by me. He just bought an L5P truck for himself, that’s awesome for the derringer advancement. I’ll be trying one out in my L5P at the track, comparing current time slips vs derringer, and reporting everything back to him. Would be awesome to see better than a 14.3 ET like Scortcher is capable of, we saw 14.9 stock.
(Russ)
  #70
Old 03-14-2019, 06:04 AM
Bdsankey's Avatar
Bdsankey Bdsankey is offline
Any updates on this?
Current Rides:
-820hp/1748ft-lbs @ Duramax Tuner (6/25/18) - Old 475/87/1.00 setup
-Built Motor, Forced Inductions Billet ETR 480/96/1.10 T6, Modded Exergy 250% Injectors, Exergy 14mm Street Pump/LBZ CP3, Goerend J Converter, Billet Trans, Fuelab Supply Pump/Reg, RCD Sump, Front E-Locker, TrueTrac, Yukon 4340 Rear Shafts, Traction Bars, DHD Center Link Brace, DHD Lower Crossmember Support
-Bosch NEW Injectors, FASS 150, 3" Downpipe, 4" Downpipe Back, RCD Sump, PPE Sleeves, DHD Centerlink Brace, DHD Lower Crossmember Support, Steering Wheel Radio Control Swap
  #71
Old 03-14-2019, 08:18 AM
RickDLance's Avatar
RickDLance RickDLance is offline
Have you got an estimate on how much lighter the aluminum block would be than stock in an LBZ application?
www.ProFabPerformance.com
We also handle S & B filters, Air Dog lift pumps, American Eagle wheels, and Kraftwerks Superchargers.
My 24th Duramax is the StudeMAX drag car!!
Special Thanks to my Sponsors!!
Danville Performance, SoCal Diesel, Vibrant Performance, & ProFab Performance!!
  #72
Old 03-15-2019, 09:09 AM
boominator's Avatar
boominator boominator is offline
bump
  #73
Old 03-15-2019, 12:51 PM
SmokeShow's Avatar
SmokeShow SmokeShow is offline
Last I asked Russ about em (been a 2-4wks ago) I believe design is complete. It's at a point where quite a chunk of change is needed to get tooled up for 'em. That's where he stands but said he had a few other projects he was working on before putting anymore money into producing the blocks.
But hopefully he'll be along shortly to give a more definitive update.
Mitch
SOLD02 Chevy 2500HD D/A EC SB LS
SCIII & X-Case brace by MA, Team Salad tuning & Trippin's DSP5, 4" Diamond Eye exhaust, Fumoto Valve, partially debadged, Rhino Bed Liner, SuperDiesel Intake Manifold and Ported Turbo Inlet
1983 GMC K30 CC SHORT BED
Awaiting Dmax/Allison Chassis Swap
  #74
Old 03-15-2019, 11:10 PM
smokinum
FEA testing is being done now before we get onto molds . But yes, I’ve got one other major project that needs to be wrapped up, before I jump into the expensive part of the block project . I was able to get some awesome pointers from Zach Hamilton to keep me on track with things, & it’s greatly apreciated.
(Russ)
  #75
Old 03-16-2019, 04:08 AM
That's really cool you know him...
Keep it up, we appreciate the hard work...
