  #31
Old 06-30-2018, 11:08 AM
WVRigrat05's Avatar
Wound for sound
unplug the MAF and see what it does, don’t think that’s your issue, most likely the FPR or lift pump, play with the pressure on it.
Reger
100k miles. Piston eater.
  #32
Old 07-10-2018, 10:32 AM
500hpduramally 500hpduramally is offline
FNG
Factory filter housing is deleted. Fass pressure at 8psi.
So the truck runs smooth and no haze or smoke with MAF reading below 38-40.
But with the MAF reading 38-40 it reads low at WOT 350-375. Any ideas why it would reads low at wot? New air filter dry air filter (not oiled) new MAF SENSOR, and all connections are tight
2005 CC/SB LLY 4X4
EFI Live by Duramax tuner
Build trans
Fass 150
MBRP exhaust
Diamond eye downpipe
Exergy sportman cp3 lbz regulater
45 over S&S injectors
Danville 3794 stg2
Wcfab y bridge intercooler pipes intake and turbo mouthpiece
Long Horn fab traction bars
  #33
Old 07-11-2018, 06:26 AM
WVRigrat05's Avatar
Wound for sound
MAF probly needs scale adjusted
Reger
  #34
Old 07-30-2018, 04:40 PM
FNG
So MAF reading is figured out. Just wasnt calibrated right. Idles pretty smooth. Still fighting the haze/blue smoke. Thought it was kinda fixed but it got down to 55-60 degrees in the morning last week and the truck smoked blue bad and seemed to be missing slightly for 10-15 mins. Did another compression test and here are the results
1-340 2-340
3-350 4-350
5-340 6-320
7-320 8-340
Think these are low enough to cause smoke?
Balance rates seem okay plus or minus 1-1.5.
Have no blow by
These were the results back in April
1-360 2-360
3-360 4-380
5-380 6-360
7-360
2005 CC/SB LLY 4X4
Build trans
Fass 150
MBRP exhaust
Danville 3794 stg2
  #35
Old 07-30-2018, 09:37 PM
WVRigrat05's Avatar
Wound for sound
320 is getting a tad low, but shouldn’t cause that much smoke, have you played with the rail pressure at idle to see if it cleans up?
Reger
  #36
Old 07-30-2018, 10:25 PM
FNG
Was originally at 4400psi and got bumped to 6500. It did seem to help alittle but still hazes at 6500
2005 CC/SB LLY 4X4
Build trans
Fass 150
MBRP exhaust
Danville 3794 stg2
  #37
Old 07-30-2018, 11:03 PM
2004LB7's Avatar
2004LB7 2004LB7 is online now
Idle timing? Pilot timing?
2008 Chevrolet 3500HD DRW LTZ
  #38
Old 07-31-2018, 05:40 AM
FNG
pilot at cold start is 13-14 degrees. And do you mean main injection timing? If so it’s 4 degrees at cold start
2005 CC/SB LLY 4X4
Build trans
Fass 150
MBRP exhaust
Danville 3794 stg2
  #39
Old 07-31-2018, 08:45 PM
FNG
Pilot inject at hot idle is 8 and main is 2
So you 320-350 compression shouldn’t make it smoke and haze at “cold” start up?
2005 CC/SB LLY 4X4
Build trans
Fass 150
MBRP exhaust
Danville 3794 stg2
