Old 08-09-2019, 05:15 AM
Chilly Chilly is offline
Gearhead
Default Mahle Wavestopper Grade D Head Gaskets
I found part numbers for Mahle Wavestopper grade C head gaskets. Trying to track down the grade D part numbers.
I found OEM, but not the Wavestopper type.
Can anyone help me out?
Built LBZ. Billet crank, Wagler rods and cam. 100 over injectors, 12mm & stock CP3. Danville 68 with Bullseye S483. Billet Suncoast/1058.
Old 08-09-2019, 06:07 AM
boominator's Avatar
boominator boominator is offline
I have looked in the past I do not believe they make them in a D.
Old 08-09-2019, 07:41 AM
Chevy1925's Avatar
Wavestoppers are only in C grade.
if you need a D, get the regular Mahle.
how much was that block cut you need a grade D? thats ALOT of gasket to put on something that will be seeing good power.
James
best time to date: 12.39
Tailgate Crew Member #4
Old 08-09-2019, 07:53 AM
PureHybrid's Avatar
Isuzu Shakes IT
I can't remember where I read it now, maybe on the package itself, but I thought the grade D was a C thickness but an overbore gasket
8.17@84mph 1/8mi
Jesse
Old 08-09-2019, 07:57 AM
Chevy1925's Avatar
nope, they are .010 thicker than a C. they are meant for "overbored/decked" but thats a broad discription. i know the mahle and lml hg are good for .040 bore overs. im guessing if you run stock pistons and deck the block more than .005, this is where the grade D can come into play for a shop that is just trying to get an engine slapped back together. I would rather cut the pistons though than run the grade D.
James
Old 08-09-2019, 09:17 AM
ikeG's Avatar
ikeG ikeG is offline
Oughta Know Better
We ran D's on an engine for a couple seasons at over 1k hp. That engine is still going strong in a 900hp street truck.
03 Chev CC SB ZF6-Gone
04 GMC CC SB SLT LLY
597/1096 Batmostocker-Gone
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
'Oughta K
Old 08-09-2019, 05:25 PM
rcr1978's Avatar
rcr1978 rcr1978 is offline
Whats the difference from the regular Mahle/Victor Reinz vs the wavestoppers. I though they were just all the same?
04 LB7 ECSB Built motor, Wagler billet narrowed Rods, Callies billet narrowed journal crank, Mahle Race Cast pistons, Randy's Girdle, Wagler/Callies Stage 1 alterfire cam, Exergy 100% SAC's, dual CP3's, Randy's race ported heads, Profab cast flow/up pipes, and Billet S480 over a DTS 67.7
2010 LMM CCLB-Tuning/Exhaust
2015 LML Cab and chassis- Tuning/Exhaust
Old 08-09-2019, 07:13 PM
Gearhead
Was the head or block O-ringed?
  #9
Old 08-10-2019, 03:23 AM
ikeG's Avatar
Oughta Know Better
No
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
'Oughta K
  #10
Old 08-10-2019, 05:52 AM
Ne-max's Avatar
Ne-max Ne-max is offline
I like turtles
Wave stoppers have multiple little metal rings that get pressed into block surface. Almost like small o-rings. They actually leave imprints on the on sealing surface.
2013 ccsb Tow rig
2006 rclb 6.6
The fun stuff. Built motor, trans, triples, nitrous
  #11
Old 08-10-2019, 08:08 AM
rcr1978's Avatar
Huh shit So these are only available in C's? The A&B ones I got had the little rings your explaining can someone post up some pics of The wavestoppers vs the normal Mahle/Victor Reinz ones?
