  #46
Old 03-26-2019, 09:43 AM
Josh154's Avatar
Josh154 Josh154 is offline
Just prevents it from draining the rails on a higher pulse width tune. Keeps positive fuel pressure at the cp4 so it doesn’t have to work as hard drawing fuel from the tank
16 CCSB LML - SDP cp3 conversion, exergy sportsman, SDP y bridge intake & intercooler pipes, 3” downpipe, 5” jamo exhaust, lb7 up pipe, fass titanium 165, deviant sump, epc fooler, UDT tuned
12.97 @ 103.74
08 CCSB LMM - HSP 369sxe kit, 10mm S&S cp3, built trans with suncoast 1058, supporting mods and Danville tuned
SOLD
  #47
Old 03-26-2019, 09:45 AM
SheeB SheeB is offline
Gearhead
So just to maintain actual to commanded. Ok makes sense.
Now what about a CP3 conversion (stock pump), will that add any power?
2012 LML CCSB Deleted w/Motor Ops tuning, 5" Flo Pro w/3" DP.
  #48
Old 03-26-2019, 09:52 AM
bigbird's Avatar
bigbird bigbird is offline
Originally Posted by Josh154 View Post
How can ford get 630 out of a cp4 while gm can only get 500?
Before I put the lift pump in, if I got on it with the big tune it would throw 0087. Now it’s no longer an issue. I have no clue why the Ford’s stock can make more power. Not positive, but didn’t stock turbo twin guys make 600-650 on stock CP4 If so, it’s not the CP4
10.76@ 127
EPR triples
  #49
Old 03-26-2019, 09:53 AM
Josh154's Avatar
Yes. I swapped to a sportsman cp3. Cp4 runs out of fuel around 500whp. Sportsman should do 650 easy. Stock lbz cp3s doing 650-675. Lml injectors are more efficient and return less fuel as well. Cp4 is your first bottle neck then turbo. I should be 580 but that’s pushing the stock turbo pretty dam hard
12.97 @ 103.74
SOLD
  #50
Old 03-26-2019, 09:55 AM
DuramaxRamRod's Avatar
DuramaxRamRod DuramaxRamRod is offline
Gearhead
Originally Posted by SheeB View Post
What does a lift pump (Fass/AD) add to a stock Duramax?
https://www.duramaxdiesels.com/forum...&postcount=149
From this thread:
https://www.duramaxdiesels.com/forum...ad.php?t=63908
19' Silverado 3500HD CCLB L5P 4x4
Banks Derringer
03' Silverado 2500HD ECSB LB7 4x4
EFI Live by Idaho Rob
  #51
Old 03-26-2019, 09:58 AM
Gearhead
Thanks for the info!
Only issue I have with converting is that the CP3 will void my emissions compliance.
  #52
Old 03-26-2019, 10:46 AM
Josh154's Avatar
Pretty sure there is a emissions compliant cp3 conversion out there
12.97 @ 103.74
SOLD
  #53
Old 03-26-2019, 11:10 AM
Gearhead
Hmm, I recall hearing about this. Pretty decent premium for that version though. Top it off, I'm in Canada.
  #54
Old 03-26-2019, 11:27 AM
Evan@LimitlessDiesel's Avatar
Evan@LimitlessDiesel Evan@LimitlessDiesel is offline
yerp
There is I sell a lot of them.
Limitless Diesel Performance
413-770-3585
  #55
Old 03-26-2019, 05:32 PM
NC-smokinlmm's Avatar
<<<Future tuna killer
Some say it has a higher flowing design but, I think it's just related to FPR and the 55 psi lift pump from the factory...
2010 GMC 1500 RCSB Denali Clone < lifted 22's/33's/ Kooks / Magnaflow / 5.3 / 6l80E / TVS1900 @ 14#'s / BTR Top End / Boosted Bump Stick / Trunion upgrade / 90mm / 10% over / 2.8 griptec / 105 lb ID's / Mayhem built/tuned.
