#16
![]() Right!? LOL. I guess there is a upgraded spider assembly that converts it to a multi port system? Not sure what that’s all about. Sent from my iPhone using Tapatalk
2003 GMC Sierra CCSB. LBZ / Six speed / EGR Delete / DSP5 with tuning from Idaho Rob @ ATP Trucks / Bilstein 5100s / Air Ride 5000 bags / Merchant Reman Tcase / TNR head unit. 2015.5 Denali. Dmax Allison / Exergy Sportsman CP3 / WCFab "Y" Bridge with cold air bundle / WCFab 3" downpipe / LB7 up pipe / 4" Flo Pro exhaust / FASS 150 / Sump / AirLift 5000 bags with WirelessOne on board air / B&W Turnover ball / AMP Research power steps. |
#17
![]() Quote:
2006 LLY CC/SB LT3 black, charcoal interior, tuned, leveled on 33s, my little piece of heaven Other toys: 1982 K10 6.2 Detroit diesel/sm465/np205 with 4 inch lift and 35s. 2011 Yamaha YFZ450X 2018 GasGas XC300 |
#18
Well, if it was that cheap to repair......
Tom "BBT" -- 2003 GMC CC/SB 4x4 12.14@111.15 "The Cruzer" -- 2014 Chevy Cruze Diesel -- the DD "Kleshay" -- 2000 C5 Corvette -- the toy Marlene (Molly) Bacon -- 1936 - 2019 -- RIP Mom ![]() Two wrongs dont make a right, but three rights do make a left. Reality is a matter of perspective. This forum isn't for the weak of heart.....or wallet. "Lets build a race car they said. Itll be fun they said. I don't know who "they" are.........but they need a good punch in the face!" -- mufflerguy (yb) |
#19
I had a 97 k1500 ext cab with the 5.7L vortex that had a CPIS and swapped to the upgraded spider MPIS and it ran great after that. Pretty easy fix.
2006 CCLB LT3 Victory Red SDP Built Trans w/ Goerend Y billet stator S472sx-e .87/1.0ar w/ SDP Piping Wagler street intake Calvert Racing bars ADII 165 Full Kryptonite Front end PPE manifolds up pipes Special Thanks to:Scott@SDP Tuned by:Blake Best time to date: 11.96 @ 112.50mph Best 60ft: 1.66 |
#20
Well, it begins. You planning to drop the 4L60E out today.
First I had to put it a small diet. Only one bolt gave a problem getting those off, this thing is filthy, but not a rust bucket. Definitely not a Michigan truck, it’s whole life. ![]() Sent from my iPhone using Tapatalk
#21
Driver’s side rocker
#22
Well, she's a runner.
Backed her off of the lift under her own power. Other than a anti lock brake light on the dash all seems to be in order. I'm a bit perplexed by the Tcase, I drained it before I removed it. When I refilled it it would only take about a half of a qt, before it started running back out of the fill port. I really think it should have taken closer to 2.2 qts. So more investigating to do there. It's the auto 4wd one, you know 2wd / 4hi / 4lo / auto 4wd, but it works just fine. I'm going to mix up some used motor oil and diesel fuel and coat the underside, keeping with my low buck theme. I have a Viper remote start that I bought for the 03, but never installed, so I may as well toss that on her too, that way I can warm it up in the morning. Kind of silly what a kick I'm getting out of this thing, but whatever. It should allow my LML to avoid some salted roads.
#23
I thought the budget undercarriage coating was wax and gasoline. The gas would evaporate leaving a wax coating behind.
How long does the used motor oil formula last?
2008 Chevrolet 3500HD DRW LTZ 285/75/17 Nitto Dura Grapplers, 4.56 gears, Front and rear ARB lockers, Efi Live tuning by me, Raptor 160 LP, Cognito 4-6 NTB Lift, 4" Exhaust, Built Trans by Mike L. 2006 BRM Jetta TDI. Injectors, turbo, Malone custom tuning on ecm and tcm |
#24
![]() Quote:
On my LML I use actual cavity wax, that's recommended by the OEMs. This being a shit box of sorts, I figured the used oil will at least improve the look of the surface rusted frame, and the diesel fuel should thin it enough to blow through a gun. Time will tell.
#25
Did you use the GM auto t case fluid? They use a special kind of fluid not the normal kind our trucks take
#26
![]() Quote:
No, ATF came out of it, I put DEX VI back in. SI says the green GM stuff, or synthetic ATF. I figured DEX VI should work Sent from my iPhone using Tapatalk
#27
Autotrac uses the blue smurf fluid, otherwise the viscous coupler can fail as well as the shift fork chew up. GM came out with the autotrac fluid after the autotrac case came out. Dex vi is not to be used in any transfer case as per GM. Dex vi is too thin, you're supposed to use there manual trans lubricant(aka dex iii or dex/merc fluid). Dex vi will take out any transfer case.
1995 GMC 2500 SUBURBAN powered by 01 DURAMAX/ALLISON, little of this, a little of that, DIAMONDEYE 4" exhaust, CORSA muffler, AFE stage 1 dry filter, custom tuning by me, KENNEDY single pump and pump rub kit. ![]() |
#28
![]() Quote:
#29
Been driving this for a bit. Feels good to let the Denali sit in the shop, while the roads are slippery or salt covered.
A complete tune up got the motor running smooth, it did have two dead holes. Plugs were way past any usable life, cap and rotor had tons of corrosion as well. It's setting a P0160 code for bank two o2 sensor being non responsive. Also also has an anti lock brake light on. I will double check the wiring on the o2, but have yet to dig into the anti lock brake issue. May change the name of this beater from "Cheap Hoe" to "Sno Hoe". I figured if we were going to put the effort into keeping another 4wd around, may as well put it to work. Not commercially or anything, just my driveway, the widow who lets me store my RV in her second driveway, my mother's house, stuff like that. No plowing contracts. Found an old Meyers plow set up off of a 1988 Chevy Truck. $500 for it complete. It's solid, another friend of a friend FB marketplace deal. They had owned the plow and truck since new. Transmission failed in the truck, the gentlemans health was failing, wife and kids were selling off the farm stuff. They represented it to be complete and in working order. It took a bit of head scratching to get the lights wired up correctly, but it's all sorted out now. The suspension will need some help, to support the weight of it, probably going to do a torsion key lift kit on it. Overall its coming along.
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
