Old 11-07-2019, 06:48 PM
TheBac's Avatar
TheBac TheBac is offline
Default Which T-case to use?
For the 1/2 ton:
Can I use another Tcase in place of the 261XHD? These are as rare as hens teeth for sale, and people want a fortune for them.
I see quite a few 261HD from behind a 6.0/4L80E in the want ads and wondered if they'd work behind an Allison.
If so, would it simply bolt on and mate to the Alli output shaft, or do I have to change the Tcase input/output shafts/sockets?
Funny how 5 years later Im regretting selling the 261XHD I had from the donor. I can always stay 2wd.
Tom
Old 11-07-2019, 07:19 PM
duramaxzak's Avatar
duramaxzak duramaxzak is offline
Wanna be puller!
The 261HD has different input and output spline counts than the 261XHD
- ZAK
2011 CHEVY 2500HD CCSB Duramax/Allison LTZ
2005 CHEVY 2500HD RCLB 2WD Duramax/Allison
2002 GMC 2500HD RCLB Duramax/allison 2.6 puller
Special thanks to:
- Danville performance, Mark.
- Suncoast transmission's, Andrew.
- Wehrli custom fab, Jason.
- Profab, Rick
- Turbo performance, Levi.
- HSP, Joe and Dave.
- SoCal diesel.
- Wagler competition, Jeramy.
Old 11-07-2019, 07:25 PM
JoshH's Avatar
JoshH JoshH is offline
The input will be your biggest hurdle. I'm not sure how you would get the correct input to mate up to an Allison because there isn't one available that I'm aware of that is a direct replacement, but I'm sure it is possible to do it.
06 Silverado 4x4 CC/SB
Old 11-07-2019, 07:32 PM
TheBac's Avatar
Question: then how have the guys gotten the 246 case to work with an Allison? New input socket in the tcase?
Tom
Old 11-07-2019, 07:47 PM
lutzjk913's Avatar
lutzjk913 lutzjk913 is offline
Tom
What kind of truck or SUV Do you need a transfer case out of?
Joe
2008 CCLB LT2 DURAMAX LMM
13.39 @ 99.44 mph W/ 1.76 60í
456HP 925 TQ
2003 Regular Cab LB7
Old 11-07-2019, 07:53 PM
TheBac's Avatar
Dmax truck with manual Tcase. NP261XHD
I dont necessarily need it, Joe. I can always stay 2wd. Was just exploring options now that I have a 4wd chassis. Back in the day, Chris used the Dmax tcase with the 1/2 ton axles. I was just wondering if something else could be used.
Tom
Old 11-07-2019, 08:00 PM
TheBac's Avatar
To add: I have found multiple NP263Xhd Tcases for sale for reasonable prices.....but Im not sure just how difficult it would be to wire them to work properly in a manual Tcase truck without the OEM harnesses, or if its possible to convert them to manual.
Tom
Old 11-07-2019, 09:10 PM
wilsondiesel's Avatar
wilsondiesel wilsondiesel is offline
Following, I am interested to know as well, as Iím building a gutted 2.6 pull truck but only have 263xhd cases around
2002 LB7 the fun truck
2018 L5P
DD-2001 VW Jetta TDI 5 speed
  #9
Old 11-07-2019, 09:12 PM
Chevy1925's Avatar
I donít see why you couldnít make a 263 a manual shift. Rig up a manual shift linkage to the shift shaft that the encoder motor goes too and just do it that way. Iirc the shifter shaft could be turned and felt like there were ďdetentsĒ on each spot. Itís been a while since I had a t-case open though and never really studied that part
James
best time to date: 12.39
Tailgate Crew Member #4
  #10
Old 11-07-2019, 09:13 PM
Chevy1925's Avatar
Hell, even if there are no detents or shifter wants to move out of selection, just build a shifter gate for 2wd, 4wd, etc
James
  #11
Old 11-07-2019, 09:22 PM
lutzjk913's Avatar
What if I knew of a 2003 truck thatís a parts truck
I saw a transfer case in the bed and all the wiring is still there. Truck has been sitting a while outside but Iím sure the wiring is salvageable.
Joe
456HP 925 TQ
  #12
Old 11-07-2019, 11:48 PM
JoshH's Avatar
Iím afraid I canít answer that question. All I know is nobody makes a 32 spline input for an xhd case, and an input from an hd case will not fit according to multiple sources I checked with. Perhaps you can ask in that thread how theyíre making it work.
For what itís worth, it would probably be easier to make some sort of linkage to manually shift a 263xhd than to put a 29 spline input in a 261hd.
  #13
Old 11-08-2019, 03:28 AM
ikeG's Avatar
ikeG ikeG is offline
Oughta Know Better
There are detents on the shifting mechanism of a 263. When we used one on our puller, ypu could shift it into ranges using a crescent wrench if the encoder was removed
03 Chev CC SB ZF6-Gone
04 GMC CC SB SLT LLY
597/1096 Batmostocker-Gone
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
'Oughta K
  #14
Old 11-08-2019, 07:17 AM
TheBac's Avatar
Joe, if you think about it, next time you're by there, check on that Tcase....ya never know.
Did some more digging. It might be possible to fab a lever to use on a 263 case, but then you run into "how do you trigger the front diff activator?"
Ferm knows quite a bit about these from the posts Ive read. Would be interesting to get his perspective on it.
Meh, it doesnt hurt anything to stay 2wd. Less weight, less complexity. Just have to resort to old-fashioned tried-and-true chassis setup theory. No big deal.
Tom
  #15
Old 11-08-2019, 07:30 AM
Chevy1925's Avatar
put a hummer front shaft axle shaft in (makes it a solid shaft, no shift fork or collar needed) or buy one of the upgraded ones from dhd or another place
As for shift linkage, just grab a floor shifter from any gm truck/suv in your body year range. You may not use the full linkage but the shifter will bolt in easier and carries the pivot and just may have to do some modding time the linkage side.
James
