  #31
Old 11-17-2011, 12:16 PM
dmaxvaz's Avatar
dmaxvaz dmaxvaz is offline
wannabe puller
Default
Quote:
Originally Posted by Brayden View Post
That sounds like a pain..
Our turbo is a completely new S300 cartridge based turbo. Only IHI parts are the compressor cover and the turbine housing. We have the technology to make them cost effective. 2100.00 is a decent price for a drop in turbo with the ability to make 650hp. The next versions will be able to support higher power levels.
If you're going to pull an IHI turbo you may as well put something better than a compressor wheel in it. Kudo's for your creativity, and accomplishment, but you are right, what you did isn't worth the time, money, for small gains.
This turbo, our 63/68 Borg in T4 trim has made over 650hp already with a billet wheel.
For anybody wanting controllable boost pressures (Wastegate=No Headstuds Necessary) and the ability to make 650hp for under 2100.00 this is the turbo you need.
Brayden
Will this new charger move more air than a s366/74 .91ar? Are they billet wheels? How snappy is spoolup compared to a stock ihi? Btw, I used a new exh wheel and compressor wheel when I built the hybrid ihi.
__________________
01 chevy 2500hd rclb, all work and no play! boss v plow, 65 hp predator tune, afe intake, dimondeye 4" exh., 285s, stock everything.
02 chevy 2500hd ccsb, rancho 9000s. suncoast IV w/1057, EFI LIVE dsp5, AD150. LBZ CP3. Kriptonite centerlink/tierods. 305/55r20s Toyo a/t. Billet wheel s366/74 by Northwest Diesel Service and Performance. BD Blowoff valve. New best 1/4 mile time: 12.59 @106.62. Toman Tuning Inside.
  #32
Old 11-17-2011, 01:54 PM
Noreaster's Avatar
Noreaster Noreaster is offline
Default
Quote:
Originally Posted by jheyob View Post
If you guys want to play that game...this truck dyno'd 473/860 with the stock turbo and downpipe.
same dyno for both runs & no other changes other than the turbo?
__________________
02 GMC 2500HD RC/LB "No Shuckin Luck" Totaled 12.26 @ 109
Ridge Runner Diesel Performance, Big Dipper tranny, Profab Performance, Super Diesel, Creatures of the Night, AirDog, BD
02 GMC 2500HD EC/SB WCFab twins
Bay State Diesels
  #33
Old 11-17-2011, 02:26 PM
jheyob's Avatar
jheyob jheyob is offline
Default
Quote:
Nope, but he didn't do 580 on this dyno with a stock charger and stock fueling so I figured why bother comparing apples to apples if he's not.
__________________
John
'03 dmax/alli, Gmax5 w/1058 by FPE, FPE 2.5 LB7 Cheetah, DSP5, Raptor
  #34
Old 11-17-2011, 03:23 PM
Noreaster's Avatar
Default
& not like he would roll 690 with that turbo either
__________________
Bay State Diesels
  #35
Old 11-17-2011, 07:12 PM
TheBac's Avatar
TheBac TheBac is offline
Default
Come on Tom.. You didn't dyno an LB7 with a lift pump and tune on a stock turbo at 580rwhp ..
You might have had an LBZ pump, injectors and turbo mouthpiece, downpipe, manifolds and uppipes to go along with that.. Don't muddy up a thread with Apples to Kumkwats comparisons.
Thanks for having my back, AJ. Braydon, sorry to muddy up your thread, but just ask your friends Mark and Matt....yes I did. More than once, too.
Stock LB7
Stock LB7 fuel system with modded LB7 reg.
Stock LB7 turbo with modded OEM horn and boost valve (I assume you mod the horns on these Cheetahs, correct?)
Exhaust, intake, lift pump, tune...the basics.
NO uppipes, manifolds, injectors, LBZ CP3 or downpipe. Apples to apples.
Truck ran 12.28 and 12.29 at roughly 6500lbs at a track Im not comfortable racing at nor are they real "friendly" to diesels in the first place.
So sub the modded reg, thats still 570. Track runs peg at ~555.
Sorry you dont think anyone other than a "shop" can legitimately put a truck together. I chronicled everything on this site as I went along, so there are no "secrets" to what I did.
Good luck with your turbo. I hope it works well and is a good seller for you.
Tha
__________________
Tom
"BBT" -- 2003 GMC CC/SB 4x4 12.14@111.15
"The Cruzer" -- 2014 Chevy Cruze Diesel -- the DD
"Kleshay" -- 2000 C5 Corvette -- the toy
Marlene (Molly) Bacon -- 1936 - 2019 -- RIP Mom You're already missed, at home and on the piano.
Two wrongs dont make a right, but three rights do make a left.
Reality is a matter of perspective.
This forum isn't for the weak of heart.....or wallet.
"Lets build a race car they said. Itll be fun they said. I don't know who "they" are.........but they need a good punch in the face!" -- mufflerguy (yb)
  #36
Old 11-17-2011, 09:07 PM
SmokeShow's Avatar
SmokeShow SmokeShow is offline
Default
Its no fair comparing Tom's truck to many other LB7's IMO. What his stock LB7 did is simply not the norm, IMO.
Back on topic though, safe to assume these are going to handle more than 35psi okay, right since they have different guts? Seems interesting.
__________________
Mitch
SOLD02 Chevy 2500HD D/A EC SB LS
SCIII & X-Case brace by MA, Team Salad tuning & Trippin's DSP5, 4" Diamond Eye exhaust, Fumoto Valve, partially debadged, Rhino Bed Liner, SuperDiesel Intake Manifold and Ported Turbo Inlet
1983 GMC K30 CC SHORT BED
Awaiting Dmax/Allison Chassis Swap
  #37
Old 11-18-2011, 12:11 AM
carpenca's Avatar
carpenca carpenca is offline
Sponsor
Default
They'll handle whatever your head bolts will Just built the 66/73 turbine version tonight. Should have results soon.
__________________
"Heidi"
07 Chevy Reg Cab Slate Grey. FPE Duramax 101, Egr Blocker, Fuel Rail Shim, EFI DSP5 by FPE, 5" Stainless MBRP, FPE Compact Compound Turbo System.
Sold 5/12
"Candy" 03 GMC Reg Cab Inferno Red LB7 and Allison. http://www.dieselpowermag.com/featur...hp_work_truck/
Talk to me at:
Fleece Performance Engineering
855-839-5040
  #38
Old 12-01-2011, 07:23 AM
9mmkungfu 9mmkungfu is offline
Default
Any updates?
  #39
Old 12-01-2011, 11:57 AM
sneezer03dmax's Avatar
sneezer03dmax sneezer03dmax is offline
Gearhead
Default
Quote:
Originally Posted by 9mmkungfu View Post
Any updates?
^^ Second that?
__________________
2003 CC/SB GMC Sierra LB7 w/Allison
MODS:
Attitude w/ Juice, Transgo Jr.,FASS 150 Lift pump, AFE intake,Banks 4" catback w/6" midget cannon tip, boost increase valve, ported intake horn by me
8000k HID in Lows & Fogs
1999 Yamaha Roadstar Silverado
1600cc
Full Cobra Exhaust
Winter Plans:
21" Raider front wheel
Stretched HD style hard bags
Bad Dad Rear fender
Front fairing with lots of noise makers
  #40
Old 12-01-2011, 12:24 PM
jheyob's Avatar
Default
Had we done the loading exactly like it was at the DC dyno I wouldn't doubt the numbers would have been identical, but this sheet is from the dyno it baselined on, updated to std correction. 488 run was stock turbo. Rail fell down to 21k in the recent runs.
__________________
John
  #41
Old 12-01-2011, 01:56 PM
Gearhead
Default
With your mods what rpm does it begin to light?
__________________
MODS:
1600cc
Full Cobra Exhaust
Winter Plans:
Bad Dad Rear fender
  #42
Old 12-08-2011, 10:37 AM
jheyob's Avatar
Default
Quote:
100-200rpm higher than the stocker...hardly a noticeable difference.
__________________
John
  #43
Old 12-12-2011, 03:05 PM
cole30 cole30 is offline
Gearhead
Default
How did the 66 perform?
  #44
Old 12-14-2011, 04:11 PM
Gearhead
Default
Quote:
Bump
  #45
Old 12-15-2011, 10:19 PM
Sledheadxp800r Sledheadxp800r is offline
That was only my tow tune
Default
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vB.Sponsors
