Old 02-14-2019, 01:36 AM
duramaxnate's Avatar
duramaxnate duramaxnate is offline
Professional Amateur
Default That's one way to lower compression..
Wasn't able to see the original block but, it was windowed. Not sure what the guy was doing, (probably hot rodding it) but, broke a valve spring and bent only one push rod.
Truck wasn't making much power, but this did come out of a duce and a half.
Damaged the upper pan and oil cooler.
Very expensive Oops.. Injectors all tested bad, valve train wasn't in good shape either.
Something to add to the wall of carnage..
Sent from my Note 9
RIVCO MOTORSPORTS
WWW.RIVCOMOTORSPORTS.COM
SOCAL DIESEL TRUCKS
WWW.SOCALDIESELTRUCKS.COM
-"Casper" 2005 GMC LBZ ECSB
Best Time: 10.59 @ 128 (Kat Driving)
9s......loading..........
-"Betty" 2006 GMC LBZ CCSB
Best Time: 12.70 @ 104
Not going any faster.
Thanks to all that helped me
- The McRats
- Mike L @ Inglewood Transmission
- And many others
Old 02-14-2019, 01:41 AM
More pics..
And that's how I got the heads delivered.. .
Sent from my Note 9
RIVCO MOTORSPORTS
SOCAL DIESEL TRUCKS
- The McRats
- And many others
Old 02-14-2019, 06:26 AM
zakkb787's Avatar
zakkb787 zakkb787 is offline
<thatís not me...
I somehow bent my pushrod when I put my lb7 back together. Had two calves stamped in my piston. Put another pushrod in, eye checked my pistons. And it’s still going today new owner will be in for a surprise if he tears it apart
2006 LLY CC/SB LT3 black, charcoal interior, tuned, leveled on 33s, my little piece of heaven
Other toys:
1982 K10 6.2 Detroit diesel/sm465/np205 with 4 inch lift and 35s.
2011 Yamaha YFZ450X
2018 GasGas XC300
