Old 02-12-2019, 10:00 PM
DylOrr's Avatar
DylOrr DylOrr is offline
Gearhead
Default O-ringing block
Im wanting to be 100% sure everything is right on this build. Ive never o ringed a block on a duramax. Done a few fire rings on Cummins. Anyways, ive done my research. 4.42 ring centerline, .041 stainless wire, .039 width, .036 depth, found in a previous thread. My question is what gaskets do i need to use. Block is brand new, dont believe it will need to be decked. Do i just put a regular gasket on and basically let the ring push it into the head?
Dylan
2005 Suburban with an LLY
Old 02-13-2019, 07:54 AM
Bdsankey's Avatar
Bdsankey Bdsankey is offline
Gearhead
If you are doing an o-ring (steel wire) then use a MLS gasket (Victor Reinz wave stopper is my go to). Fire rings need to have a special gasket since the ring itself seals the combustion chamber.
Current Rides:
-Tuned by Zach @ Starlite
-Built Motor, Forced Inductions Billet ETR Gen 4 S480/96/1.10 T6 w/V2 Race Cover, Modded Exergy 250% Injectors, Exergy 14mm Street Pump/LBZ CP3, Goerend Q Converter, Billet Trans, Fuelab Supply Pump/Reg, RCD & Beans Sumps, Front E-Locker, TrueTrac, Yukon 4340 Rear Shafts, Traction Bars, DHD Center Link Brace, DHD Lower Crossmember Support
-Tuned by Starlite
-Bosch NEW Injectors, FASS 150, 3" Downpipe, 4" Downpipe Back, RCD Sump, PPE Sleeves, DHD Centerlink Brace, DHD Lower Crossmember Support, Steering Wheel Radio Control Swap
