  #16
Old 03-13-2020, 01:43 PM
Chevy1925's Avatar
Originally Posted by nwohiochevyguy View Post
So I did a HSP Y bridge and pipes last fall on my 2005 LLY when I upgraded my turbo.
Have had a small drop in MPG and now under harder acceleration I get ALOT of black smoke and she falls on her face. I know it is a boost leak, tester will be build and I will run the test.
My question is when I put the Y on I had one bolt in the head that would not torque down, suspect threads are shot in the head as the bolt looked fine.
If I drill and tap that hole any thing that I could get into if I step it up a size to get to good material?
Also what size are those bolts, I donít recall.
I have not done the boost test yet, but this bolt not torquing down has me believing that this is where I will find my leak.
Yes I cleaned my air filter & MAF Sensor last night with no change in her behavior.
if you changed the turbo, you needed a re-tune. its going to work vastly different than the stock one.
James
2002 LB7, LLY, LBZ, LMM, LML, L5P 2500HD CC/LB dmax/6sp alli "The Limo"
2020 L5P 2500HD CC/LB dmax/10sp alli "The New Limo" staying stock........ish
Tailgate Crew Member #4
  #17
Old 03-13-2020, 02:42 PM
nwohiochevyguy nwohiochevyguy is offline
FNG
Unhappy
Originally Posted by gmduramax View Post
If thereís nothing strange in the data log, there is nothing wrong with the tune. You need a new mechanic.
I have not met up with my tuner yet to get some data.
Beginning to think that myself.
2005 LLY CCSB 4x4 LT
NO CAT, NO Muffler, stock straight piped
Built Trans (billet shafts, triple disk etc.)
65mm Built turbo w/ Highflow vains
HSP Y Bridge & Pipes
S&S Injectors
LBZ CP3
AirDog 165
Heads upgraded & Studed
AFE Intake, LBZ Turbo MP
EGR Deleted
PPE UP & Down Pipes
Powerstop Z36 rotors & Pads
  #18
Old 03-13-2020, 03:01 PM
FNG
It was retuned after the turbo swap
S&S Injectors
LBZ CP3
AirDog 165
EGR Deleted
PPE UP & Down Pipes
  #19
Old 03-13-2020, 03:06 PM
Chevy1925's Avatar
not well enough
James
  #20
Old 03-16-2020, 07:18 PM
FNG
Data logged tonight by my tuner.
Have an injector (maybe 2) acting up. Causing truck to max out at 80% fuel flow on hard acceleration.
New S&S injectors put in 25K Miles ago (14 months ago) when HG were done. Hope the shop makes it right.
S&S Injectors
LBZ CP3
AirDog 165
EGR Deleted
PPE UP & Down Pipes
  #21
Old 03-26-2020, 09:38 AM
FNG
So did the pressure test and everything is holding fine.
Looks like the problem is injector related - suspect bad fuel. New Injectors 25K miles ago after adding an Airdog 165G lift pump.
VERY frustrated with the upgrades done during HG replacement. HG w/ ARP Studs, Water Pump, S&S Injectors, LBZ CP3 upgrade, Remanufactured heads due to crack (which machine shop did not find)
First valve seals were damaged when remanufactured heads were built / had to be replaced.
Then wrong glow plugs were installed, took shop 3 trips back into shop to figure that out.
Then return fitting o-rings were damaged on reassembly. Replaced with Bosch lines after Dorman failed in a few months after fixing it in a parking lot 500 miles from home.
Then $1000 in labor & parts for 4 different antifreeze leaks.
Then Water pump replaced under warranty / was replaced during HG job.
Now it has to go back to have the injectors pulled and tested / cleaned etc.
S&S Injectors
LBZ CP3
AirDog 165
EGR Deleted
PPE UP & Down Pipes
  #22
Old 03-27-2020, 12:25 PM
fl0w3n fl0w3n is offline
Those are all issues from the same shop? And you’re taking it back there?
I know we only have a small portion of the big picture being this is the internet and all, but I’d be looking at having the original shop pay a new shop to fix it right. I understand wanting to have them stand by their work, but sounds like you’re just digging a deeper hole with the more things they touch the more problems you’ll have down the road.
  #23
Old 03-28-2020, 08:49 AM
FNG
They installed the new injectors, so if under warranty they will cover it.
But I don’t suspect that will Be the case.
This is the last thing they will touch on my truck. If it was not for the potential warranty coverage I would be doing this myself.
S&S Injectors
LBZ CP3
AirDog 165
EGR Deleted
PPE UP & Down Pipes
