  #1
Old 04-10-2019, 08:15 AM
FROGMAN524's Avatar
FROGMAN524 FROGMAN524 is online now
Default Wilwood Brakes
Thinking about their big brake kits front and back. Anybody have any experience with these?
https://www.wilwood.com/BrakeKits/Br...le+Rear+Wheels)
__________________
2016 Sierra 3500HD Denali CCSB SRW
UDP Tunes on V2/SOTF Switch/Danville 63.5 Billet-S480FMW Billet Twins by WCFab(Illusion Blue)/Exergy 100% Injectors/Exergy 12MM CP3/Banks Intercooler/HSP Billet Manifolds/PPE Up Pipes/PPE Oil Pan/PPE Deep Trans Pan/AirDog 165 II-4G/FloPro 5" SS Turbo Back/MBRP 6" SS Tip/CTS2 Insight/EDGE EGT Probe/EDGE 0-100 Boost Sensor/Cognito 4-6/Cognito Front Driveline/Cognito Swaybar/Cognito PISK/PPE Tie Rods/King 2.5 Resis/Air Lift 5000 Ultimate Bags/Air Lift Wireless One Compressor/Wilwood TX6R Brakes Front and Back/LT325/60R20 BFG KO2s/20x9 Method 309s/AMP Steps/Yukon 4.11s/Royalty Core RC1/Retrax Powertrax Pro MX/Titan STAFS 30 Gallon/JL C5s/JL 12TW3-D4/JL VX600/6i/JL XD300/1V2
Mike L Trans (Goerend R/Alto G3s/RatioTek)
SOLD2015.5 GMC Sierra 3500HD Denali CCSB
SOLD2007.5 GMC Sierra 2500HD SLT CCSB SDP Twins/Mike L Trans/ATP Tunes
If wishes were horses, beggars would ride.
  #2
Old 04-10-2019, 03:30 PM
torqued2dmax's Avatar
torqued2dmax torqued2dmax is offline
Default
I have heard they are good , but make sure your wheels will fit with the ones you choose !
__________________
05 CC/LB DRW LLY Allison
AFE Blade Runner,AFE Momentum CAI,DHD Big Air intake Y pipe, DHD fuel block,DHD pcv reroute,MBRP 4 inch exhaust,DHD 3 inch downpipe,BD driver's side manifold,DHD pass side up pipe,DHD 3 inch intercooler hot&cold pipes, ATI damper,Empire pin kit by Big Foot on & off road shop, FASS fuel system,5/8 inch pickup, FASS fuel filter delete, EFI live,V2 & lap top , 5 position switch 250 hp big tune, shimmed fprv by Crank it up , built SunCoast Allison 1078 converter aftermarket trany mount by Limitless Diesel,ARP head studs,grade C gaskets,tig-welded water pump,T stats by Blackout performance,MA t case brace , Kriptonite motor mounts,MA pump rub kit,HD drive shaft 1480joints by Greensburg machine,BDS Recoil traction bars, PPE finned deep pan , Mike L trany cooler, PSC pump, 5100s, Sulastic Shackles, Curt com 2.5 hitch
  #3
Old 04-10-2019, 04:54 PM
TheBac's Avatar
TheBac TheBac is offline
Default
Very expensive. Would only use on a truck I needed to lose every-single-pound on.
Moved to Chassis/Suspension.
__________________
Tom
"BBT" -- 2003 GMC CC/SB 4x4 12.14@111.15
"The Cruzer" -- 2014 Chevy Cruze Diesel -- the DD
"Kleshay" -- 2000 C5 Corvette -- the toy
Marlene (Molly) Bacon -- 1936 - 2019 -- RIP Mom You're already missed, at home and on the piano.
Two wrongs dont make a right, but three rights do make a left.
Reality is a matter of perspective.
This forum isn't for the weak of heart.....or wallet.
"Lets build a race car they said. Itll be fun they said. I don't know who "they" are.........but they need a good punch in the face!" -- mufflerguy (yb)
  #4
Old 04-10-2019, 05:45 PM
gmduramax's Avatar
gmduramax gmduramax is offline
Shits broke
Default
I’m told they’re awesome. Not sure they’re worth the money, a good pad and rotor go a long way.
__________________
2008 GMC duramax crew cab short bed 2500.
10.98@124mph
Thanks to Mike L, SoCal Diesel, and Abel Chevorlet.
Tailgate Crew Member #1
  #5
Old 04-10-2019, 08:44 PM
FROGMAN524's Avatar
Default
Ok thanks. Not sure Iím going to do it yet but with the new 20s Iím putting on it would open up the possibility as they wonít fit with my current 17s.
__________________
  #6
Old 04-14-2019, 11:42 AM
FROGMAN524's Avatar
Default
Pulled the trigger on these. Iíll update this when they show up and they said they should ship the 19th as the fronts were in stock but the rears were backordered.
__________________
  #7
Old 04-14-2019, 12:39 PM
Jacy_dzlguy Jacy_dzlguy is offline
lots to learn...
Default
Curios to see how good these actually are..
__________________
2011 LML CCSB 4x4
No exhaust - Tune - Airdog - HSP Y bridge, mouth piece, cold side pipe - S&B - lowered
2008 LMM
tune - exhaust
2006 (sold)
2005 (sold)
  #8
Old 04-15-2019, 10:40 AM
cjb2283's Avatar
cjb2283 cjb2283 is offline
Gearhead
Default
In for the results!
__________________
2015.5 GMC Sierra 2500 HD Z71 CCSB LML
-Stock
-Edge CTSII Monitor
-Diamondback HD bed cover
  #9
Old 04-15-2019, 12:31 PM
bigmackmiller's Avatar
bigmackmiller bigmackmiller is offline
Default
I've seen them in person at the PRI show here in Indy and they are monsters
__________________
-Cody-
Instagram
@codydavemiller
@mfsdiesel
2001 LB7 CC/SB 4x4
S&B, 4"Silverline, AD150, 10mm Fleece 750, 65% SAC S&S Inj. Danville Tuning, Limitless Built Trans. Coming soon-369sxe
2007 LBZ EC S/B 4x4 SLT
4" MBRP SS
S&B Intake, Ridgerunner Moonshine Tuning
  #10
Old 04-16-2019, 07:11 AM
FROGMAN524's Avatar
Default
Looking forward to increased stopping power with these larger tires Iím running. Bling factor doesnít hurt either.
__________________
  #11
Old 04-16-2019, 07:45 AM
Woodster's Avatar
Woodster Woodster is offline
Computer Nerd
Default
Agreed!
Let us know what you think about them please.
__________________
2006 LBZ S.B.C.C. LT 4X4
EFI LIVE Thanks Mark
Exergy Performance 45% and Sportsman CP3
FASS Titanium Signature Series 165
Danville BMW GT3794 Stg. 2 Thanks Mark
Built Mike L tranny w/ Limitless TC Thanks Mike & Evan
  #12
Old 04-16-2019, 09:31 AM
FROGMAN524's Avatar
Default
Tracking shows UPS is delivering the front kit tomorrow. Rear kit should ship out by end of week.
Front kit consists of two boxes of 55-60lbs each.
Also, ordered 12 quarts of Wilwood 570 Hi Temp brake fluid from amazon which should be here next week.
__________________
  #13
Old 04-16-2019, 08:44 PM
Nickracer9 Nickracer9 is offline
Default
I like them after upgrading to the higher temp pads. First two sets of the standard temp pads didnít seat very well. I only run the wilwoods on the fronts though.
__________________
09 Lmm/Lml SoCal Diesel Stg3 engine. Danville performance 68stg2r/S483 tct, Exergy 150% over, Exergy 12mm, built billet tranny by Limitless diesel and me. Ecm/Tcm tuning by Danville performance. Hsp Triples S369sxe coming soon!
  #14
Old 04-17-2019, 05:39 AM
Bdsankey's Avatar
Bdsankey Bdsankey is offline
Gearhead
Default
Looks like thats only 12oz fluid, not 32oz. Did you need 12qts? If so, might want to order more.
__________________
Current Rides:
1) Toy: 2005 LLY ECSB, Leather, Sunroof
-1340hp/2200ft-lbs @ ATS Diesel (06/04/19)
-Tuned by Zach @ Starlite
-Built Motor, Forced Inductions Billet ETR Gen 4 S480/96/1.10 T6 w/V2 Race Cover, Modded Exergy 250% Injectors, Exergy 14mm Street Pump/LBZ CP3, Goerend Q Converter, Billet Trans, Fuelab Supply Pump/Reg, RCD & Beans Sumps, Front E-Locker, TrueTrac, Yukon 4340 Rear Shafts, Traction Bars, DHD Center Link Brace, DHD Lower Crossmember Support
2) DD/Tow Rig: 2002 LB7 CCSB, Leather, Loaded
-Tuned by Starlite
-Bosch NEW Injectors, FASS 150, 3" Downpipe, 4" Downpipe Back, RCD Sump, PPE Sleeves, DHD Centerlink Brace, DHD Lower Crossmember Support, Steering Wheel Radio Control Swap
  #15
Old 04-17-2019, 06:09 AM
FROGMAN524's Avatar
Default
Quote:
Correct. They are 12oz bottles but in a 6 pack. I ordered two six packs for a total of 144oz.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vB.Sponsors
