  #1
Old 03-01-2019, 11:41 PM
DIESELMAFIAPER.LB7's Avatar
DIESELMAFIAPER.LB7 DIESELMAFIAPER.LB7 is offline
<----twinz
Default Sac injectors
So curious if anyone has had issues with sac injectors not wanting to cold start....
I had 80% over exergy injectors with vco nozzles never had a real issue starting the truck below 32* ever
I've noticed dince my new sac 100% overs anything under 25* this ****ing thing doesn't like to start with a couple turns of the key and some extra cranking?
Maybe sac injectors need something im not thinking of ?
__________________
2003 GMC CC/SB: billet 66/83mm compounds, dual pumps, exergy injectors, built trans (by me) tuned by me 11.11 @ 124.63mph @ 7100lbs
2012 mega cab 6.7: Tuned and deleted (reliable) sold! (should have kept it)
2016 CCSB custom sport lml ltz deleted with sotf tunes by me
  #2
Old 03-02-2019, 07:40 AM
rcr1978's Avatar
rcr1978 rcr1978 is online now
Default
I've noticed the same thing with mine but not quite as severe as you explain. Mine will start it just turns over a little longer than before, they are Exergy 100% SAC's and I also did a set of Lincoln/S&S 100% SAC's for a friend with the same result. I was going to add a little more cranking fuel to just have not yet. I already bumped the rail psi a little around the idle p/t areas.
Irrelevant but on paper my Exergy's flow more than the Lincolns's I got though.
__________________
04 LB7 ECSB Built motor, Wagler billet narrowed Rods, Callies billet narrowed journal crank, Mahle Race Cast pistons, Randy's Girdle, Wagler/Callies Stage 1 alterfire cam, Exergy 100% SAC's, dual CP3's, Randy's race ported heads, Profab cast flow/up pipes, and S475 over a DTS 67.7
2010 LMM CCLB-Tuning/Exhaust
2015 LML Cab and chassis- Tuning/Exhaust
  #3
Old 03-02-2019, 08:28 AM
DAVe3283's Avatar
DAVe3283 DAVe3283 is offline
Default
I have SAC +75% injectors (Lincoln / S&S for what that's worth) and my truck starts great in the cold, down to 13F so far. I never plug it in either, not worth the electricity cost IMO.
SAC injectors take major tuning changes vs. VCOs to be happy in the cold. I ended up using less pilot fuel than VCOs, less timing advance when cold, a hair more fuel pressure, and a way smaller cranking pulse (at -10C, stock was 1600 us, I run 850 us, about half!).
I attached my tune if you guys want to look through. I do my MAF scaling in a funky way vs. most tuners I've seen, so the MAF limit tables might look weird. And I have a big single with a really big cam, so keep that in mind if you see the mid-RPM stuff being funky. It is hard to get on top of this turbo with this cam, so I do weird stuff.
You should be looking at the base timing, pilot timing, ECT timing compensation & multiplier, pilot quantity, cranking quantity, and main pulse tables. In the idle range, those should work on most engines. Mine has lowered compression vs. stock, so a stock motor could be more aggressive with the cranking fuel but might want to pull a little timing out? But this should be a good starting point or reference information.
This is how SAC +75% injectors can start in the cold:
__________________
  #4
Old 03-02-2019, 09:59 AM
<----twinz
Default
Yeah I'll drop pilot and timing a little more see if it helps anything.
And I'll watch main injection I run plenty of rail pressure at idle/cranking for sure once it starts it cleans right up
__________________
  #5
Old 03-05-2019, 02:43 PM
chevyburnout1's Avatar
chevyburnout1 chevyburnout1 is offline
Fixing it till it breaks
Default
I have the smaller 65% SAC nozzles, 16.5:1 compression and mine starts fantastic at 0 degrees a few days ago. And as crazy as it sounds I swear it starts faster than a stock truck. I know it's stupid but just a reminder we're LB7's with no ECM glow plug diagnostics. Back in the day I lost 6 glow plugs over the course of one summer and was having just a slight hard start when winter hit. Didn't even realize. Easy to over think the simple stuff.
__________________
Dustin
'03 Silverado LB7
GT3788/CT6x88mm compounds _ 65's _ duals _ fingers _ 6480af
'77 K-10
52"/56" front/rear leaf springs and rear shackle flip: 8" lift total _ D60/14blt 4:56s _ 40" Swamper IROK's _ 383 w/nitrous _ SM465 _ 208tcase
'97 Cadillac Deville
Morimoto Mini 5000k projector headlight conversion _ 500watts in the trunk _ 20's _ Flowmasters _ Tuned ECM _ Rear mount turbo in the works....
  #6
Old 03-05-2019, 06:43 PM
SickLL7Crenshaw's Avatar
SickLL7Crenshaw SickLL7Crenshaw is offline
Billy The Kid
Default
My 100% sacs will start at 5* no issues. I’ve noticed zero change during starting from stock injectors to these.
__________________
Blake
2001 LB7 312k miles
10.9@123 Stock Motor
Crenshaw Ranch, LLC. 8LB7s, 7LLYs, 1LBZ , 2LMMs, 1L5P
Tuned by Unleashed Duramax Tuning, LLC
  #7
Old 03-16-2019, 06:37 AM
<----twinz
Default
Yeah mine hates it I dunno never had a issue till the sac injectors with starting in the cold runs fantastic otherwise.
I made changes with a minor change in how it started was 19* I bumped glow plug time up a little as well and it started first try still took bout 6-8 seconds of cranking. Might make a few more changes to it today see what happens
__________________
  #8
Old 03-16-2019, 06:38 AM
<----twinz
Default
Quote:
I put all new in maybe the relay isnt really working correctly either
__________________
  #9
Old 03-16-2019, 09:12 AM
Chevy1925's Avatar
Chevy1925 Chevy1925 is online now
Default
Quote:
Highly possible since they commonly die
__________________
Quote:
Originally Posted by JoshH View Post
Mike L is my role model. I want to be like him when I grow up.
James
02 LB7, LLY, LBZ, LMM, LML, L5P 2500HD CC/LB dmax/alli "The Limo"
BIG THANKS TO: Mike L, Steve, Trent, Guy, Dan, Ruben, Josh H, Scott, Brian and everyone else who has put a hand in to help me.
best time to date: 12.39
motor died/bent rods = 3/11/11
back from the dead 7:04pm 4/9/2012
Limo is back in the garage, now driving a built chevy tracker
Tailgate Crew Member #4
  #10
Old 03-17-2019, 01:28 AM
BlkMax's Avatar
BlkMax BlkMax is offline
Default
I have some 65% overs and Starlite tuning. I have noticed that the truck will not cold start the first time with the autostart, not enough cranking time.... It always starts the second time the autostart tries. It has not been an issue with using the key, I think the autostarter could use another second or two or cranking and it would be just fine.
__________________
Black Max....
Black Max, the fun truck:
'03 2500 4x4 CC/LB
Bent Rods, now under construction, its time to put all the saved up parts in....
Special thanks to Pat & Kat McSwain, MikeL, Guy, Trent, and others from here-thank you for the great ideas!
EPR triples
Emma, my DD:
'04 2500 4x4 EC/SB
HTT T4 366 74 .91, 65% SAC's from LDS, 10mm CP3 from Fleece, Trans Kit from Evan, tunes by Mark at Danville
  #11
Old 03-17-2019, 05:16 AM
NC-smokinlmm's Avatar
NC-smokinlmm NC-smokinlmm is offline
<<<Future tuna killer
Default
Quote:
Isn't actuating glow plugs very long I'd bet.
__________________
2010 GMC 1500 RCSB Denali Clone < lifted 22's/33's/ Kooks / Magnaflow / 5.3 / 6l80E / TVS1900 @ 14#'s / BTR Top End / Boosted Bump Stick / Trunion upgrade / 90mm / 10% over / 2.8 griptec / 105 lb ID's / Mayhem built/tuned.
2016 LML CCSB Denali < Lifted 22's/35's, Fox 2.0 < I officially need help.
  #12
Old 03-17-2019, 01:58 PM
THEFERMANATOR's Avatar
THEFERMANATOR THEFERMANATOR is offline
LEGALLY INSANE
Default
With sac injectors I've found pilot timing/quantity are key to making them work. SMALL changes to pilot can completely change the way the engine reacts. I've only got 45 overs, but it starts better now than it did with stockers.
__________________
1995 GMC 2500 SUBURBAN powered by 01 DURAMAX/ALLISON, little of this, a little of that,
DIAMONDEYE 4" exhaust, CORSA muffler, AFE stage 1 dry filter, custom tuning by me, KENNEDY single pump and pump rub kit.
  #13
Old 03-17-2019, 02:29 PM
gmc502 gmc502 is offline
Default
Quote:
did you add or subtract ?
__________________
2002 GMC 2500HD, ECSB, 4WD, LB7,300k miles and still truckin
new style gm exhaust manifold, banks big head wastegate, PPE boost valve, banks air intake,high idle switch in cruise control, stock but not for long
EFI live tuned byMe now,dps5 switch,EGT probe and autometer boost sensor,SoCal 6spd conversion
  #14
Old 03-18-2019, 06:42 PM
LEGALLY INSANE
Default
Quote:
I subtracted quantity, switched to an lly timing table, and tweaked from there. What I found was even a half a degree change in pilot timing could make the idle fuel rate change 1mm3 of fuel with no other changes.
__________________
  #15
Old 03-19-2019, 05:47 AM
Default
very interesting,thank you for the info
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vB.Sponsors
