Old 04-10-2019, 08:15 AM
FROGMAN524's Avatar
FROGMAN524 FROGMAN524 is offline
Default Wilwood Brakes
Thinking about their big brake kits front and back. Anybody have any experience with these?
https://www.wilwood.com/BrakeKits/Br...le+Rear+Wheels)
2016 Sierra 3500HD Denali CCSB SRW
UDP Tunes on V2/SOTF Switch/Stealth 64 Billet-S480FMW Billet Twins by WCFab(Illusion Blue)/Exergy 100% Injectors/Exergy 12MM CP3/Banks Intercooler/HSP Billet Manifolds/PPE Up Pipes/PPE Oil Pan/PPE Deep Trans Pan/AirDog 165 II-4G/FloPro 5" SS Turbo Back/MBRP 6" SS Tip/CTS2 Insight/EDGE EGT Probe/EDGE 0-100 Boost Sensor/Cognito 4-6/Cognito Front Driveline/Cognito Swaybar/Cognito PISK/PPE Tie Rods/King 2.5 Resis/Air Lift 5000 Ultimate Bags/Air Lift Wireless One Compressor/Wilwood TX6R Brakes Front and Back/LT295/65R20 Nitto G2s/20x9 SOTA SKULs/AMP Steps/Yukon 4.11s/Royalty Core RC1/Retrax Powertrax Pro MX/Titan STAFS 30 Gallon/JL C5s/JL 12TW3-D4/JL VX600/6i/JL XD300/1V2
Mike L Trans (Goerend R/Alto G3s/RatioTek)
SOLD2015.5 GMC Sierra 3500HD Denali CCSB
SOLD2007.5 GMC Sierra 2500HD SLT CCSB SDP Twins/Mike L Trans/ATP Tunes
If wishes were horses, beggars would ride.
Old 04-10-2019, 03:30 PM
torqued2dmax's Avatar
I have heard they are good , but make sure your wheels will fit with the ones you choose !
05 CC/LB DRW LLY Allison
Old 04-10-2019, 04:54 PM
TheBac's Avatar
TheBac TheBac is offline
Very expensive. Would only use on a truck I needed to lose every-single-pound on.
Moved to Chassis/Suspension.
Tom
Old 04-10-2019, 05:45 PM
gmduramax's Avatar
Shits broke
I’m told they’re awesome. Not sure they’re worth the money, a good pad and rotor go a long way.
10.98@124mph
Tailgate Crew Member #1
Old 04-10-2019, 08:44 PM
FROGMAN524's Avatar
Ok thanks. Not sure Iím going to do it yet but with the new 20s Iím putting on it would open up the possibility as they wonít fit with my current 17s.
Old 04-14-2019, 11:42 AM
FROGMAN524's Avatar
Pulled the trigger on these. Iíll update this when they show up and they said they should ship the 19th as the fronts were in stock but the rears were backordered.
Old 04-14-2019, 12:39 PM
Jacy_dzlguy Jacy_dzlguy is offline
lots to learn...
Curios to see how good these actually are..
2011 LML CCSB 4x4
No exhaust - Tune - Airdog - HSP Y bridge, mouth piece, cold side pipe - S&B - lowered
2008 LMM
tune - exhaust
2006 (sold)
2005 (sold)
Old 04-15-2019, 10:40 AM
cjb2283's Avatar
cjb2283 cjb2283 is offline
Gearhead
In for the results!
2015.5 GMC Sierra 2500 HD Z71 CCSB LML
-Stock
-Edge CTSII Monitor
-Diamondback HD bed cover
  #9
Old 04-15-2019, 12:31 PM
bigmackmiller's Avatar
bigmackmiller bigmackmiller is offline
I've seen them in person at the PRI show here in Indy and they are monsters
-Cody-
Instagram
@codydavemiller
@mfsdiesel
2001 LB7 CC/SB 4x4
S&B, 4"Silverline, AD150, 10mm Fleece 750, 65% SAC S&S Inj. Danville Tuning, Limitless Built Trans. Coming soon-369sxe
2007 LBZ EC S/B 4x4 SLT
4" MBRP SS
S&B Intake, Ridgerunner Moonshine Tuning
  #10
Old 04-16-2019, 07:11 AM
FROGMAN524's Avatar
Looking forward to increased stopping power with these larger tires Iím running. Bling factor doesnít hurt either.
  #11
Old 04-16-2019, 07:45 AM
Woodster's Avatar
Woodster Woodster is offline
Computer Nerd
Agreed!
Let us know what you think about them please.
2006 LBZ S.B.C.C. LT 4X4
EFI LIVE Thanks Mark
Danville BMW GT3794 Stg. 2 Thanks Mark
Built tranny w/ Limitless TC Thanks Mike & Evan
  #12
Old 04-16-2019, 09:31 AM
FROGMAN524's Avatar
Tracking shows UPS is delivering the front kit tomorrow. Rear kit should ship out by end of week.
Front kit consists of two boxes of 55-60lbs each.
Also, ordered 12 quarts of Wilwood 570 Hi Temp brake fluid from amazon which should be here next week.
  #13
Old 04-16-2019, 08:44 PM
Nickracer9 Nickracer9 is offline
I like them after upgrading to the higher temp pads. First two sets of the standard temp pads didnít seat very well. I only run the wilwoods on the fronts though.
09 Lmm/Lml SoCal Diesel Stg3 engine. Danville performance 68stg2r/S483 tct, Exergy 150% over, Exergy 12mm, built billet tranny by Limitless diesel and me. Ecm/Tcm tuning by Danville performance. Hsp Triples S369sxe coming soon!
  #14
Old 04-17-2019, 05:39 AM
Bdsankey's Avatar
Bdsankey Bdsankey is online now
Gearhead
Looks like thats only 12oz fluid, not 32oz. Did you need 12qts? If so, might want to order more.
Current Rides:
-820hp/1748ft-lbs @ Duramax Tuner (6/25/18) - Old 475/87/1.00 setup
-Built Motor, Forced Inductions Billet ETR 480/96/1.10 T6, Modded Exergy 250% Injectors, Exergy 14mm Street Pump/LBZ CP3, Goerend J Converter, Billet Trans, Fuelab Supply Pump/Reg, RCD Sump, Front E-Locker, TrueTrac, Yukon 4340 Rear Shafts, Traction Bars, DHD Center Link Brace, DHD Lower Crossmember Support
-Bosch NEW Injectors, FASS 150, 3" Downpipe, 4" Downpipe Back, RCD Sump, PPE Sleeves, DHD Centerlink Brace, DHD Lower Crossmember Support, Steering Wheel Radio Control Swap
  #15
Old 04-17-2019, 06:09 AM
FROGMAN524's Avatar
Correct. They are 12oz bottles but in a 6 pack. I ordered two six packs for a total of 144oz.
