  #1
Old 08-15-2019, 08:08 AM
rickcdewitt rickcdewitt is offline
Gearhead
Default Traction bar design for lifted truck that flexes off road.one center bar or two out?
Hey guys I'm looking into making some kind of axle wrap control for my truck and could use some feedback on whether or not its a good idea to do a center ladder style bar with a shackle on our trucks?
I've always made that type on smaller lifted trucks to keep articulation and limit bind. My concern is having the axle housing come apart from the weight and torque these trucks have if only supported by the inner side of one axle tube?
I could use rubber bushings and inboard two bars as far as possible?
This truck only tows and offroads a little.sometimes both at the same time,lol.i rip around quite a bit but no drag or pulls.Thoughts? ideas? Thanks guys!
__________________
2002 ccsb,zf6,SB org dual disc,3" mbrp dp,4" mbrp exh, exhaust brake,s&b intake,ported airhorn,p&p ihi w/wetzel wheel,ppe boost valve and rail plug,ad 165,lml manifold,arp studs,lift bags,4" rancho lift,35's
  #2
Old 08-15-2019, 08:39 AM
Bdsankey's Avatar
Bdsankey Bdsankey is online now
Gearhead
Default
Two long bars should be fine. If you're going to make them yourself I'd put them as close to the driveshaft angle as possible. I didn't do this BUT I also don't articulate my suspension much/offroad.
I made mine with Ballistic Fab joints and bushings (heim/spherical joints on one end and bushings on the other to limit the bars ability to roll completely).
__________________
K&D Service Inc
Call or Text: 906-284-0962
Providing a "one-stop-shop" for all of your automotive needs!
Current Rides:
1) Toy: 2005 LLY ECSB, Leather, Sunroof
-1340hp/2200ft-lbs @ ATS Diesel (06/04/19)
-Built Motor, Forced Inductions Billet ETR Gen 4 S480/96/1.10 T6 w/V2 Race Cover, F1 Diesel 275% Inj, Exergy 14mm Street Pump/LBZ CP3, Goerend AR Converter, Billet Trans, Fuelab Supply Pump/Reg, RCD & Beans Sumps, Front E-Locker, TrueTrac, Yukon 4340 Rear Shafts, Traction Bars, DHD Center Link Brace, DHD Lower Crossmember Support, Banks iDash 1.8 Monitoring System
2) DD/Tow Rig: 2002 LB7 CCSB, Leather, Loaded
-Cast S475/96/1.10 T6 Over Stock IHI, FASS 150,4" Exhaust, RCD Sump, PPE Sleeves, DHD Centerlink Brace, DHD Lower Crossmember Support, "Budget" Motor, Big Oil Cooling, Banks iDash 1.8 Monitoring System
  #3
Old 08-15-2019, 08:52 AM
Chevy1925's Avatar
Chevy1925 Chevy1925 is online now
Default
the suspension doesnt care about driveshaft angle. its a link setup where we are trying to minimize driveshaft plunge.
the goal would be to have them as parallel to the ground as possible to 0 out anti-squat from the bars. problem is, that doesnt "look good".
unless you are cycling more than what 10-12" stroke shocks can move, the typical two axle wrap bars works well, simple to put on, and dont require a custom crossmember.
the single triangulated setup with shackle is tried and trued as well but i would for sure pre-heat/weld the axle tubes to the center section. its not a bad idea on any high hp truck that will likely see high torque and wheel hop. ive seen guys still twist the pumpkin with the typical two single bars.
__________________
Quote:
Originally Posted by JoshH View Post
Mike L is my role model. I want to be like him when I grow up.
James
2002 LB7, LLY, LBZ, LMM, LML, L5P 2500HD CC/LB dmax/6sp alli "The Limo"
2020 L5P 2500HD CC/LB dmax/10sp alli "The New Limo" staying stock........ish
Tailgate Crew Member #4
  #4
Old 08-15-2019, 11:47 AM
Gearhead
Default
Bd I'm thinking the angle from front spring eye to center of leaf pack bend point would be the one to follow for reduced bind.maybe johnny joints?
Limo driver i miss my black crew cab, rip! I called it the limo too,haha. Good point on range of travel.i just don't want it to get any worse and tear up logging roads on my friends ranches getting where this boat needs to go
On my old long arm ranger jumper i had some bars that mounted to the top of the axle at a flat angle.worked ok until it got 38's and 60's. I miss that little truck.nothing like hauling ass jumping 6ft+ in the air.
__________________
  #5
Old 08-15-2019, 11:53 AM
Bdsankey's Avatar
Gearhead
Default
The Ballistic Fab joints are just like Johnny Joints BUT are much easier to rebuild.
__________________
K&D Service Inc
Current Rides:
  #6
Old 08-15-2019, 01:27 PM
04chase 04chase is offline
Default
this is what i did to get max travel and handle 1k torque without issue. very soft deavers dont like that torque. they will turn into an S shape.
this has worked great for me . no wheel hop what so ever
__________________
-2018 Audi S4
-2007 LBZ CCSB LT3- 3794 stg 2 ,efi dsp5, custom coil over ,deaver 1/2 ton 4" springs , Mike L Trans , fass 150 , k3la ,bolt ons 600whp/1100wtq
-1955 Belaire
-2012 Ram 5500 6.7 -Kelderman 4 link rear/front , accuair elevel ,service truck #CHASETRUCKMOBILE
dreams sold
09 CTS-V 800 WHP Daily
04 SS Silverado TT 440 LSX 1200 AWHP-Truckin throwdown winner 2012
  #7
Old 08-15-2019, 01:36 PM
Chevy1925's Avatar
Default
gotta work on them paint skills, Chase
__________________
James
  #8
Old 08-15-2019, 03:52 PM
Gearhead
Default
Whats going on at the front of that link setup chase? Boomerang shackle thingy with a pivot in the middle?
__________________
  #9
Old 08-17-2019, 09:27 PM
Gearhead
Default
This kit looks interesting?
https://www.ruffstuffspecialties.com...YaArkLEALw_wcB
__________________
  #10
Old 08-20-2019, 10:53 AM
Gearhead
Default
The ballistic joints do look pretty awesome. For the price i think it'd be hard to beat the cognito economy kit. 1.75" tubes though.maybe add gussets?
As far as welding the center section to the tubes on my spare rear axle should i remove the r&p(it has a slight seal leak anyway)? Just drain it? I'll do the center bar if it isn't to involved?
__________________
  #11
Old 08-21-2019, 03:12 PM
Default
its just a ruffstuff hd anti wrap bar.
shackle is up front mounted to the oem crossmember
paint was actually to see if i was still touching the train horn at full compression.
__________________
-2018 Audi S4
-1955 Belaire
dreams sold
  #12
Old 08-21-2019, 03:21 PM
Gearhead
Default
Aha,now i see.lol.it kinda looked like two shackles?yeah i know that wouldn't make any sense
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
vB.Sponsors
