Go Back   Duramax Diesels Forum > Duramax/Diesel Technical > Duramax Hard Parts > LB7
Notices
Thread Tools Display Modes
Old 05-14-2020, 08:40 AM
byeezy_lb7 byeezy_lb7 is offline
FNG
Default misfire issue.
hey guys im trying to get my truck dialed in and truck threw a code for misfire cylinder 7.
the truck falls flat on its face off idle and the injectors clack and sputter and then finally decides to get going.
I used the cts2 monitor to check balance rates and i dont know if my monitor is not working properly but they all say 0.0
any ideas?
motor is fully built, triple turbos with 200 over injectors and dual 10mm cp3 pumps...
thanks.
2003 Lb7
fully built motor, triple turbskis
Mike L built trans with all the billet goodies.
Old 05-14-2020, 09:44 AM
slowlml's Avatar
slowlml slowlml is offline
Empty Pockets
If they all say 0.0 something is wrong. Whose injectors and tuning?
Nic R
"Flat Back Gorilla" Daily/Tow rig- 04 GMC Sierra LB7 CC Flatbed/Stock..ish
"Empty Pockets" Race/Pulling truck- 2012 CCSB Cummins/Built engine/48re swap
Old 05-14-2020, 09:54 AM
2004LB7's Avatar
2004LB7 2004LB7 is offline
I would be looking at the connection right at the injectors. Maybe a loose nut or two
2008 Chevrolet 3500HD DRW LTZ
Old 05-14-2020, 10:38 AM
FNG
S&S injectors and pumps and danville tuning
2003 Lb7
Old 05-14-2020, 11:06 AM
Burn Down's Avatar
X2 on a loose injector nut, bad connection.
Albert
04.5 CCSB ole blue, built trans, mpi twins, 12.5X @ 108
99' Reg Cab, 1500 2wd, Turbo or Procharged 6.0, 4L80E build inprogress
05 CCSB Millennium Falcon, built eng, built trans, mpi twins, 11.51 @ 119 1.59 60
84' Reg Cab SB, 415 BBC, 4-speed, needs a D-max zf6 swap
Old 05-14-2020, 01:30 PM
juddski88's Avatar
juddski88 juddski88 is offline
Freedom Diesel
Did it start doing it after any hard runs or abuse?
2001 Chevy 2500HD ECSB
"Sore Subject" - Still don't have time for it.
I would never have learned what I have without George Alexander, Mike Lovrich, David Browning, Matt Handwork, Ben Tyler, Evan Drosehn and countless members of this forum and others.
Thank you.
2014 Jeep Grand Cherokee Limited, Ecodiesel
Old 05-14-2020, 07:25 PM
KyleC4 KyleC4 is offline
This won’t help your condition but last time I had an lb7 constantly show 0.0 for balance rates the truck had a bad speed sensor on transfer case. When at a stop the tech 2 was showing 1mph being read by ECM.
Concord Chevrolet
Mike L and Inglewood transmission
Old 05-15-2020, 05:13 AM
Bdsankey's Avatar
Bdsankey Bdsankey is offline
As said above, the truck will not report accurate balance rates if it senses throttle input or vehicle speed. It is also possible that you have a loose nut on an injector causing the issue.
K&D Service Inc
Call or Text: 906-284-0962
Providing a "one-stop-shop" for all of your automotive needs!
Current Rides:
-Built Motor, Triples (2x S369 over a 472), F1 Diesel 300% Inj, Exergy 14mm Street Pump/LBZ CP3, Goerend Bolt Together Converter, Billet Trans, Banks Intercooler, Fuelab Supply Pump/Reg, RCD & Beans Sumps, Front E-Locker, TrueTrac, Yukon 4340 Rear Shafts, Traction Bars, DHD Center Link Brace, DHD Lower Crossmember Support, Banks iDash 1.8 Monitoring System
-FASS 150,4" Exhaust, RCD Sump, PPE Sleeves, DHD Centerlink Brace, DHD Lower Crossmember Support, Built Motor, Big Oil Cooling, Banks iDash 1.8 Monitoring System
  #9
Old 05-18-2020, 08:27 AM
FNG
It did start doing it after I broke The engine in and started getting on the throttle..
2003 Lb7
  #10
Old 05-18-2020, 08:46 AM
juddski88's Avatar
Freedom Diesel
May have lifted an injector, or cup if they aren't threaded... Assuming you don't have an aftermarket head that doesn't use cups. Could be a couple of things, but that's what I would check first. Do a compression test.
Thank you.
