Old 09-18-2018, 12:51 PM
Novak's Avatar
Novak Novak is offline
SQUIRREL TRYN TO GET A NUT
Default Sand blaster!!!
Hello Gentlemen....
Iím in my favorite part of tool buying which means I paid off my box and sockets and now I want bigger tools. I know Northern Tool is pretty consistent with a descent selection however I havenít used any of the brands Iím looking at. My current sandblaster is sh*t, I bought it in UT for cheap and thatís what I got....cheap. But I was starting a business on a budget so hey, sum-b paid for itself faster.
I want a new sandblaster clearly but I want it contained with a vacuum and circulating hopper. They are somewhere in the ball park of 1000-1400 for an Eastwood or Allsource or even Redline standing cabinet. Standing is key because Iím gonna weld up a caster cart under the cabinet so I can move it around my shop. I donít care if itís pedal driven TBH. I just donít want to pay good American dollars for something thatís gonna fill my shop up with Silica dust or be a POS in a long run.
Here is an example of what Iíve been looking at.
https://m.northerntool.com/shop/tool...7897_200347897
If anyone has any input on which brand and or model please please say so!
2008 LMM :SOLD 2/18
4" MBRP TB AXLE DUMP, EFI IDAHO ROB, PPE RAIL PLUG, S&B AIR, PPE TRANS COOLER, FLEECE TRANS LINES, AIRDOGG 165, EDGE CTS, KRYPTONITE STEERING RODS AND KRYPTONITE IDLER, COGNITO STEERING BRACES, COGNITO DIFF MOUNT, BARS TURNED DOWN AND DROP SHACKLES ON REAR, ALL OTHER PM (REROUTES AND DELETES) PAINT PAINT PAINT
2004.5 LLY :SOLD 2/15
5" TB EXHAUST, FASS LIFT PUMP, PPE TUNE, PUMP RUB, MOUTHPIECE, PAINT PAINT AND PAINT
1978 CHEVY LUV MACHINE
PROBABLY THE BEST $700 INVESTMENT IVE EVER MADE
2006 CUMMINS MEGA CAB 48RE AUTOMAGIC
STOCK AF........
Old 09-18-2018, 12:56 PM
Chevy1925's Avatar
how big of a cabinet you want? My dad use a harbor freight one all the time and has provisions for a shop vac to hook to. just dont get a bunch of grease chunks in there or it plugs up the recirc of the hopper. We use a 60 grit silica thats demagged (stuff we use in caulking so he just takes a few bags home if needed). only bad thing is the size of the cabinet can be an issue.
James
best time to date: 12.39
Tailgate Crew Member #4
Old 09-18-2018, 03:51 PM
Novak's Avatar
Big enough to fit a wheel inside.
Iíve seen the harbor freight ones and the cabinets look good. Itís the vac and blaster system that Iím most concerned with
2008 LMM :SOLD 2/18
STOCK AF........
Old 09-18-2018, 07:00 PM
1FastBrick 1FastBrick is offline
look up a company called Skat Blast. They seem to have a nice product and its made in the USA.
Old 09-20-2018, 09:26 AM
Novak's Avatar
Iíll check em out tonight!
2008 LMM :SOLD 2/18
STOCK AF........
Old 09-25-2018, 09:39 AM
ikeG's Avatar
ikeG ikeG is offline
Oughta Know Better
This ^ x100. Best product I have found. Great service and parts availability
03 Chev CC SB ZF6-Gone
04 GMC CC SB SLT LLY
597/1096 Batmostocker-Gone
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
'Oughta K
Old 10-02-2018, 05:44 AM
Novak's Avatar
http://www.skatblast.com/960-t-pro-t...t-cabinet.html
I really like this one!
I do love the made in the USA part!
2008 LMM :SOLD 2/18
STOCK AF........
Old 10-02-2018, 05:47 AM
Novak's Avatar
Has anyone experimented with difference media? Like for instance I do a lot of plastics (ABS) I fear that my Aircraft stripper with ruin a rifle stock one day while Iím attempting to remove manufactured paint or patterns, I also do a boat load of aluminum as well. I havenít had to replace someoneís stuff yet but as a worse case scenario trial I guinea pigged a bow limb and my ďplastic safeĒ media from a local retailer carved right in.
2008 LMM :SOLD 2/18
STOCK AF........
  #9
Old 10-02-2018, 05:43 PM
Pressure and media type will affect what it does.
At work they need to use a real fine media and low pressure to get more of a cleaning effect.
I forget what is used and the pressure. I will have to look next time I'm in the shop.
  #10
Old 10-04-2018, 05:25 PM
Cougar281's Avatar
Cougar281 Cougar281 is offline
I can't say how it would be with plastic or wood, but I've used baking soda as blast media. It's worked pretty well for me on everything I've cleaned - Aluminum, steel, etc. Harbor Freight carries several different levels of coarseness.
'04.5 2500HD Silverado LT CC/LB, LBZ D/A Dark Grey
Metallic, 05+ HD Hood & Grille, 192k and counting
Mike L Trans built by ME.
EFILive, PPE Race Valve, KD Twin Lift Pumps & Billet Fuel Pickup, MBRP 4" "Cat-Back" T409 straight piped.
300.59' 3rd place first pull
Best 1/4 times:
Truck: 14.067 @ 96.29, weighing in at over 7200#
446.4RWHP/820.2RWTq
Car (95 Cougar 4.6L V8): 14.680 @ 94.00
"The FIRST weapon is the mind, all others are incidental."
"I'd rather be judged by twelve than carried by six."
