Old 09-17-2018, 03:29 PM
coreyfatboy's Avatar
coreyfatboy coreyfatboy is offline
FNG
Default Overheat limp mode temp only 212
Hey everyone my kid has an 06 with bigger injectors and turbo deleted with efi live. Having transmission problems (long story). Have it at the transmission shop and he is trying to do test on it and it keeps saying itís overheating and goes into limp mode. His snap on scanner says the temp is 212-217. Itís not actually overheating. I did take efi live out because we were having communication problems with the tcm and the shop said had to return everything to stock. Any help would be fantastic
Old 09-17-2018, 03:33 PM
gmduramax's Avatar
Shits broke
Take it to a shop that knows what they’re doing. It’s throwing communication codes for a reason.
10.98@124mph
Tailgate Crew Member #1
Old 09-17-2018, 03:49 PM
boostwhore's Avatar
boostwhore boostwhore is offline
Drag racer wannabe
Scott @screamin diesel performance is a reputable trans builder in Port Angeles, Washington.
Chad
2007 lmm: kryptonite front end, full billet trans by Sdp, SoCal engine ovals and Carrillos, 12mm exergy stroker, 100 over exergy injectors, sdp billet 68mm over billet 480, awesome tuning from Aaron at All in trucks.
Best 1/4 to date: 11.06 at 127 in the chase for 10ís.
Old 09-17-2018, 04:11 PM
TheBac's Avatar
TheBac TheBac is offline
Isnt this the second time you've tried repairing this truck? Get it to a competent shop that works on modded Duramaxes.
Tom
Old 09-17-2018, 04:33 PM
1TRIKHD's Avatar
1TRIKHD 1TRIKHD is offline
Country boy Limo.
Like said up above, take it to Scott at SDP
2006 CCLB LT3 Victory Red
SDP Built Trans w/ Goerend G billet stator
S472sx-e .87/1.0ar w/ SDP Piping
Wagler street intake
Calvert Racing bars
ADII 165
Full Kryptonite Front end
PPE manifolds up pipes
Special Thanks to:Scott@SDP
Tuned by:Blake@UDT
Best time to date: 12.08 @ 112.58 1.76 60ft
Old 09-18-2018, 07:25 AM
FNG
We had the communication problems taken care of that’s why it is at transmission shop. He is a transmission mechanic not a diesel mechanic. Never had engine overheating problems. He was taking it for a test drive to check pressures in tranny and got dic on dash saying engine was overheating and it went into limp mode. The temp guage was bouncing all around but actual engine temp was never over 215
Old 09-18-2018, 08:34 AM
Chevy1925's Avatar
were the basics checked?
James
best time to date: 12.39
Tailgate Crew Member #4
Old 09-18-2018, 09:10 AM
FNG
I guess that’s what I’m asking. If anyone has had similar problem and where to start
  #9
Old 09-18-2018, 09:28 AM
Chevy1925's Avatar
check the water level, search on where the coolant temp sensor is (there is only one), search on the finicky gauge clusters.
James
  #10
Old 09-18-2018, 09:31 AM
mechman3 mechman3 is offline
no such thing as too fast
I would check for a pinched grounded wire coolant sensor wire. I had this issue after HG replacement. Just a thought
2005 GMC CC/LB
Grade C HG with ARP studs
3"MBRP Downpipe
EGR blocker plate
Fass Titanium 165
EFI Live by Starlite Diesel
Edge Insight CTS
MikeL Trans
  #11
Old 09-18-2018, 10:47 AM
torqued2dmax's Avatar
Tell us about the truck, that might help , is transmission upgraded ? have HGs been replaced yet ? who did injectors , turbo, EFI ? is bottom end stock ? the more you put in your sig the more likely someone might chime in , otherwise its like saying over the phone hay doc I dont feel good whats wrong !
05 CC/LB DRW LLY Allison
