  #1
Old 01-31-2015, 01:29 PM
CaptPhil's Avatar
CaptPhil CaptPhil is offline
Default The White devil
A bit over a month ago I hurt the trans in white devil, formerly great white, also known by some other names that aren't appropriate for public. The majority of the issues I was having I kept to myself since they were relatively small things that I am fortunately able to fix myself, but after getting it on the lift I was able to see some pretty piss poor "fabrication" skills at work. After hurting it I heard the true story of who built the trans and why from a couple very reliable sources who have asked to stay neutral in this situation.
I knew the trans had to come out anyway because of a tc issue I was having. The tc would lock immediately in 2nd while in normal drive when it was cold, and once warm would lock and unlock erratically. It was doing this even though the tcc solenoid duty cycle was zero%. Only issue could have been a converter flow valve problem.
Anyway, I was just getting the tuning semi squared away when I hurt the trans and lost 4th. Initial diagnosis was a stripped c2 hub or p2 planet. Trans was supposed to have a sleeved hub, more on that later. Ordered billet hub and planet and a new 1055, trans already had billet shafts. Big money into a super low mile trans. Shitty to have a $5k bill only three months and less than a thousand miles after buying a race ready built truck, especially after literally two pulls on a smallish tune.
Towed the truck up to Evan and he was cool enough to tear it down in front of us. Some pics for your enjoyment.
Stock hub that was supposed to be sleeved. Junk.
P2 planet twisted and stripped. Junk.
Converter flow valve flat tired on THE WRONG END, hence tc problems.
Badly warped steels out of I believe the c3 pack. Ruined fresh Suncoast intabulators, big money clutches added to the bill.
N****red drain plug to the mag hytec deep pan. Stud with a nut welded to it, which broke on the way out. Really?
Trans Had slotted steels in the c4s, which shredded the clutches and clogged the internal Filter, which in turn smoked the c3s. I'm not a trans builder, so my explanations may be incorrect, but as it was explained to me, this trans would not have survived regardless of the planet damage. This is the perfect example of how a builder can make all the difference. It was full of high dollar parts and the best clutches on the market but assembled by people who have no business working on a competition trans in a 1000hp truck.
Fortunately evan has big power experience and is going to get this thing right. Not to mention he has fantastic customer service. It is refreshing to have a builder who answers texts and phone calls immediately. I really hope I am finally able to enjoy this truck, because so far it has been a disappointment to say the least.
I would like to thank Evan @ limitless diesel, Andrew @ Suncoast, Logan (onebadmaxx), Shane (s.phinney). You guys at least keep me optimistic about the trucks potential and have been great with helping someone you have no real reason to help. I truly appreciate it all.
__________________
2005 CC/SB LLY
Big Dipper w/ 1058
Bullseye Double bat S366
12.05 @ 112mph w/ S366, stock sticks, stock CP3
2005 EC/SB LLY The White Devil
Built Motor
Limitless Diesel Comp Trans
Triple Turbo
Dual Fuelers
100% Injectors (Hahaha Sure they are)
10.67 @ 133mph fuel only
  #2
Old 01-31-2015, 01:37 PM
CaptPhil's Avatar
Default
Some wonderful fabrication skills demonstrated. I am not a great welder, but come on man.
Found my drive pressure leak. Welded fu***ng bellows? give me a break.
Found an exhaust leak on the downpipe. Gonna have to fix that.
Lower shock mounts..... don't have words for this one.
__________________
2005 CC/SB LLY
Big Dipper w/ 1058
Built Motor
Triple Turbo
Dual Fuelers
  #3
Old 01-31-2015, 02:33 PM
mike diesel's Avatar
mike diesel mike diesel is offline
I'm alright.
Default
That's why i didn't buy a "built" truck
__________________
'89 s10 daily driver
  #4
Old 01-31-2015, 02:36 PM
andy-stevenson's Avatar
andy-stevenson andy-stevenson is offline
Default
What did the previous owner have to say?
__________________
05 LLY
Built Trans
Died 10/13/2015
  #5
Old 01-31-2015, 02:40 PM
NC-smokinlmm's Avatar
NC-smokinlmm NC-smokinlmm is offline
<<<Future tuna killer
Default
Was the guy welding blind or what. Holly sheet...
Welded bellows, that's a new one...
__________________
2010 GMC 1500 SCSB Denali Clone < lifted 22's/33's, Kooks, Magnaflow, 5.3, 6l80, TVS1900, lots of boost, Mayhem tuned, etc...
2015 Corvette Stingray Z 51 < Stock...
2016 LML CCSB Denali < Lifted 22's/35's, Fox 2.0 < I officially need help.
  #6
Old 01-31-2015, 02:43 PM
CaptPhil's Avatar
Default
Quote:
It's a long story. some trans stuff is getting sorted out between us. I am not pushing for anything really other than the sleeved hub that was supposed to be in the trans, which he is sending along with a set of clutches. I won't demand anything more and he isn't obligated to provide anything more, I just don't operate like that.
Mike I don't blame you, I knew there would be stuff that I would want to change and my ocd would force me to clean up some stuff, but I didn't expect the truck to be quite as poorly represented as it was. BUT now I have two trucks and a very good base to work from.
__________________
2005 CC/SB LLY
Big Dipper w/ 1058
Built Motor
Triple Turbo
Dual Fuelers
  #7
Old 01-31-2015, 02:48 PM
Muff's Avatar
Muff Muff is offline
Just Learning
Default
Sorry for your luck. Those welds, trans parts, make me instantly think what else is wrong with this truck?! Who "built"/made this mess?
__________________
The Learning Curve
2007 Long body - EFI - Built Transy < She was my first. SOLD
"Vern" 2002 Reg can (with a cap) 300,000 original miles. Lowered, tuned, sold to some jackass who blew it up instantly.
"Vendetta" Nobody knows but she gonna eat
You cant put a price on fun
  #8
Old 01-31-2015, 02:49 PM
I'm alright.
Default
Not going with a billet p2 planet and billet c2 hub?
__________________
  #9
Old 01-31-2015, 02:52 PM
Lparrill's Avatar
Lparrill Lparrill is offline
Might as well burn money
Default
I really thought that truck would have been better than that. Doesn't make all the problems I had with the built truck I bought look so bad. I'm glad your getting it worked out. Looking forward to seeing some videos
__________________
Levi
04 GMC CCSB LLY l Mahle Pistons with reliefs l Carillos l ARP Studs l Socal Stg 2 Heads l Suncoast Trans with Billet Shafts l Danville 72vgt l Double Bat S483 l HSP Piping l 60% overs l II 85% over + LBZ CP3 l FASS 220 l DRP Sump l BT Lockup Box l Fabtech "Traction"/Axle wrap Bars l Mishimoto Intercooler l Zex Nitrous
Tuning by Wade at Diesel Day Dreams
  #10
Old 01-31-2015, 02:53 PM
Evan@LimitlessDiesel's Avatar
Evan@LimitlessDiesel Evan@LimitlessDiesel is offline
yerp
Default
Quote:
Yes both
__________________
Limitless Diesel Performance
413-770-3585
  #11
Old 01-31-2015, 02:56 PM
zf>allison's Avatar
zf>allison zf>allison is offline
you never had your car.
Default
Those aren't welds at all. There's a difference in a weld and a glob of shit. That down pipe and up pipe that's just embarrassing. I hope u get it sorted out.
__________________
04.5 single cab lly zf6 barely not stock.(the jalopy)
05 single cab lly zf6
Arp studs, welded water pump, 100 overs, dual fuelers, valair 1000 hp triple disc, danville efi live, fass 150, custom single s400 kit,
serious weight reduction
28x10x16 Hoosier slicks on pyos
Down on 2 leaves, t bolts gone.
best
10.91 at 129mph, 1.577 60 foot
dynoed 743 hp raceweight 5k with driver
Instagram-636zf6
  #12
I'm alright.
Default
Quote:
Originally Posted by Evan@LimitlessDiesel View Post
Yes both
Ahh good choice!
__________________
  #13
Old 01-31-2015, 02:58 PM
TheBac's Avatar
TheBac TheBac is offline
Default
Turns out Mr dmax711 was a ripoff artist? Makes you wonder if the engine is all he said it was, too.....
Sorry you got hosed like this, Phil. Nobody deserves that.
__________________
Tom
"BBT" -- 2003 GMC CC/SB 4x4 12.14@111.15
"Flyin' Brick" -- 1999 Chevy 1500 RC/SB 2wd -- stalled out, no motivation
"The Cruzer" -- 2014 Chevy Cruze Diesel -- the fun little DD
"The Bigger Boat" -- 2011 Workhorse P700 - 6.0LS/Allison - what I drive at work
Two wrongs dont make a right, but three rights do make a left.
Reality is a matter of perspective.
This forum isn't for the weak of heart.....or wallet.
"Lets build a race car they said. Itll be fun they said. I don't know who "they" are.........but they need a good punch in the face!" -- mufflerguy (yb)
  #14
Old 01-31-2015, 03:07 PM
onebaddmaxxx onebaddmaxxx is online now
Default
The engine is supposed to be built by burkett....Then again, supposed to have a sleeved hub too.
__________________
2005 lly
Lots of thanks to Diesels Unlimited, Evan@limitless & Mark@danville
  #15
Old 01-31-2015, 03:09 PM
yerp
Default
Ahh good choice!
I'm not fan of sleeved hubs. I don't use them especially after what I found one late night last week while trying to prepare for what Mike Graves is going to do to his trans next year I have a billet hub here with a design I won't even use unless it's in my own truck now.
__________________
413-770-3585
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
vB.Sponsors
