Old 07-12-2018, 11:40 PM
JoshH's Avatar
JoshH JoshH is offline
Default Living that single life
After blowing up the S480 and sending shrapnel through my S300, I decided to do something I have wanted to do for a while. I decided to swap the shop truck to a ďbigĒ single. It isnít really that big by todayís standards, but it is definitely a big change for me. This is the first non stock single I have ever run on anything I owned. So far, I like it, but I have a few things I need to finalize. The turbo is a 472/87/1.0 with no wastegate anywhere. I really like the way it all came together. That 4Ē exhaust was a pain, and the 5Ē intake was a tight fit too. Here are a few pics for you all to check out. I still need to install a new MAF sensor, and I need to build a brace for the intake so it isnít hanging all that weight off the turbo.
06 Silverado 4x4 CC/SB
Old 07-13-2018, 04:58 AM
Bdsankey Bdsankey is offline
Welcome to the club!!
I have a Bullseye 475/87/1.0 without a gate and the thing is is a blast to drive.
Current Rides:
-820hp/1748ft-lbs @ Duramax Tuner (6/25/18)
-Built Motor, Bullseye Batmowheel S475/87/1.0 "Comp R75", Exergy 250% overs with "Redman" internal mods, Exergy 14mm street pump w/AN feed, Goerend "J" Converter, Built Trans, AD2 165, Beans Sump, E-Locker, TrueTrac, Yukon 4340 Shafts, Traction Bars, DHD Center Link Brace, DHD Lower Crossmember Support
Past Rides:
1) 2002 LB7 CCSB, Leather, Loaded
-New Bosch Reman Injectors, New LBZ CP3, FASS 150, RCD Sump, 3" MBRP Downpipe, 4" Downpipe Back w/ Muffler, Sleeves, DHD Centerlink Brace, DHD Lower Crossmember Support, Steering Wheel Radio Control Swap
Old 07-13-2018, 05:33 AM
1TRIKHD's Avatar
1TRIKHD 1TRIKHD is offline
Country boy Limo.
I love the single life as well.
2006 CCLB LT3 Victory Red
SDP Built Trans w/ Goerend G billet stator
S472sx-e .87/1.0ar w/ SDP Piping
Wagler street intake
Custom 80" Trac Bars by MBS Diesel
ADII 165
Full Kryptonite Front end
PPE manifolds up pipes
Special Thanks to:Scott@SDP
Tuned by:Blake@UDT
Best time to date: 12.08 @ 112.58 1.76 60ft
Old 07-13-2018, 05:47 AM
lutzjk913's Avatar
lutzjk913 lutzjk913 is offline
Looking killer man
What made you do the exhaust out the fender?
Joe
2008 CCLB LT2 DURAMAX LMM
13.44 @ 98.69
456HP 925 TQ
Old 07-13-2018, 06:18 AM
CaptPhil's Avatar
CaptPhil CaptPhil is offline
Awesome.
I did the fender exhaust on white devil for a while, it is absurdly loud, lol. You gotta take a video while getting on it.
2005 CC/SB LLY
Big Dipper w/ 1058
Bullseye Double bat S366
12.05 @ 112mph w/ S366, stock sticks, stock CP3
2005 EC/SB LLY The White Devil
Built Motor
Limitless Diesel Comp Trans
Triple Turbo
Dual Fuelers
100% Injectors (Hahaha Sure they are)
10.67 @ 133mph fuel only
Old 07-13-2018, 08:37 AM
JoshH's Avatar
Originally Posted by lutzjk913 View Post
Looking killer man
That's how I had it ran with the compound setup, and I didn't feel like running a whole exhaust.
Originally Posted by CaptPhil View Post
Awesome.
It really wasn't bad with the compounds, but there is no doubt it is louder with the single. Hopefully it isn't unbearable.
Old 07-13-2018, 09:12 AM
PACougar's Avatar
PACougar PACougar is offline
Install S472, calls it "Big" single We need to get you really initiated Josh
2004 LB7 EC/LB 2WD Dropped 6" in the front on coil overs and 7" in the rear on 18"s, Hellwig front and rear sway bars. Caltracs traction bars.
Socal Diesel built bottom end, FI S480 Billet wheel and race cover, RDL Headers and pipes,
Dual Cp3(1 modded and 1 stock), Exergy 100% over injectors,
Socal Diesel injector clamps, Socal Stage 2 Heads/ARP Head Studs
Suncoast GMAX-5 plus some billet built by my best friend Dave(He's a Badass like that), 1058 converter, MikeL Cooler
Mag-Hytec pans on Tranny(Scraping a little) and Diff
Custom modified MBRP exhaust i.e. it dumps in front of the rear tire(Also by Dave). Never had a cat
Labonte Motorsports water/meth, AirDog II 200
Custom 5" Intake Pipe w/AFE Filter, BD Cool It Intercooler,
EFI Live DSP5
Torsen limited slip(POSI), Gauges
DON'T PURCHASE FROM INDUSTRIAL INJECTION UNLESS YOU ENJOY GETTING SCREWED!
Old 07-13-2018, 09:36 AM
Chevy1925's Avatar
how loose is your converter, josh? everyone i always talk to that runs a big single loves them cause the converter matches the turbo or hates them cause the converter is too tight. or you get the guys that want to tow at 2k rpm on a 475
id love a play truck with a big single on it, loose converter with great coupling and probably keep lock up out of the pic till WOT so that sucker comes on fast
James
best time to date: 12.39
Tailgate Crew Member #4
  #9
Old 07-13-2018, 12:05 PM
JoshH's Avatar
Hey, I did use the quotation marks. Back in the day, that would have been a huge single though.
James, itís almost like the truck was made for a bigger single turbo. It has a 3k rpm precision converter and a SoCal 9100 cam. It drives really nice. So far Iím loving it.
In other news, I got the intake completely finished with a maf sensor and a nice brace. Iím really happy with how everything went together.
File Type: jpg 12A80161-08D7-4A3F-BFE7-A96AF0F0061D.jpg (46.9 KB, 65 views)
  #10
Old 07-13-2018, 12:32 PM
Chevy1925's Avatar
uh yeah! id almost say it blew the 480 up on purpose to make you go single!
James
  #11
Old 07-13-2018, 12:41 PM
SickLL7Crenshaw's Avatar
SickLL7Crenshaw SickLL7Crenshaw is offline
Billy The Kid
I just ordered a s400 single kit and turbo yesterday for my LB7. Along with a new converter from Evan. Guess I’ll experience the s400 single life here soon as well Josh!
Blake
SOLD: 05 LLY CC/SB 140k 11.18@123.7 stock/480
01 LB7 EC/SB 308k 11.31@119.8 69sxe stock motor
Tuned by Unleashed Duramax Tuning
Crenshaw Ranch, LLC. 8LB7s, 7LLYs, 1LBZ , 2LMMs, 1L5P
Thanks to Evan@Limitless and AJ Hynick aka IOWA LLY
  #12
Old 07-13-2018, 01:06 PM
JoshH's Avatar
Originally Posted by SickLL7Crenshaw View Post
I just ordered a s400 single kit and turbo yesterday for my LB7. Along with a new converter from Evan. Guess Iíll experience the s400 single life here soon as well Josh!
Now if only you could find someone to tune it for you!
  #13
Old 07-13-2018, 01:16 PM
Chevy1925's Avatar
Blake, he makes a valid point
James
  #14
Old 07-13-2018, 02:07 PM
gmduramax's Avatar
Shits broke
Seal up that air filter from under hood heat. Throw on a turbo blanket and enjoy the spool
10.98@124mph
Tailgate Crew Member #1
  #15
Old 07-13-2018, 02:09 PM
SSchmi5519's Avatar
SSchmi5519 SSchmi5519 is offline
Pro Tuner Wannabe
-Steve- 2005 LLY Inglewood Transmission, EFI Live, PPE, ARP, Crower, BT Diesel, T&B Fab
Email: ASK.SSDT@GMAIL.com
