  #1
Old 04-16-2017, 09:30 PM
wilsondiesel's Avatar
wilsondiesel wilsondiesel is offline
Default To AF or not?
So I have the motor out, head studding it along with porting heads, valve springs, and push rods. Running an ihi with s366 center section in it for Air. I plan to pull the motor again next year and do rods and more fuel. Currently still going to run stock fuel this year. Would I see any benefits with going ahead with a stage 1 or close to stock grind cam that's an AF or should I wait to do an aggressive cam when I do rods and have reliefs in pistons?
__________________
2002 LB7 the fun truck
2018 L5P
DD-2001 VW Jetta TDI 5 speed
  #2
Old 04-17-2017, 04:35 AM
S Phinney's Avatar
S Phinney S Phinney is offline
Default
Wait and do it when you build. Replace your crank too at that time.
__________________
03 GMC 4x4 CC/SB Intake, Dual Exhaust, built motor by Me, Cognito Kryptonite Suspension upgrades, Custom Traction Bars by Me, Suncoast Trans, 1055-1 Convertor, Two AirDog II 200's, Billet Sump, Venom Tuning AKA Me, Custom Fabbed Fuel system, Flexlite Fans, Best Time to date 7.14 at 98.21 mph 1211.8HP 1954.5 FT/Lb torque
2013 LML Daily Driver, 5" FloPro Exhaust, Venom Tuning, Ad 165 4G Lift Pump, Upcoming HSP Billet Bridge And Piping, Upcoming CP3 Conversion
  #3
Old 04-17-2017, 05:43 AM
unfinished business unfinished business is offline
Default
Not that this will mean much, but I am not sold on the AF cam. Failures have still occurred with AF cams. If it was me, I would look at upgrading the crank as stated above.
This is just my opinion.
Paul
__________________
2008 LMM 4x4 SB CC -A few boltons
  #4
Old 04-17-2017, 08:53 AM
JDPlowboy's Avatar
JDPlowboy JDPlowboy is offline
Default
The af cam is cool and theory looks good on paper. But I have seen power drops with them. A standard fire will make more power.
__________________
04.5 RC/LB with some power from the pacific
  #5
Old 04-17-2017, 11:09 AM
boostwhore's Avatar
boostwhore boostwhore is offline
Drag racer wannabe
Default
Quote:
Do you have dyno sheets/timeslips of cams with same specs standard firing and alternate firing to back this up? I think there is allot more that goes into making power in these trucks than firing order alone. I'm. It saying that it's the answer at all but there has been vibration analysis testing done that shows better harmonics with the af versus the standard firing order.
__________________
Chad
2007 lmm: kryptonite front end, full billet trans by Sdp, SoCal engine ovals and Carrillos, 12mm exergy stroker, 100 over exergy injectors, sdp billet 68mm over billet 480, awesome tuning from Aaron at All in trucks.
Best 1/4 to date: 11.06 at 127 in the chase for 10ís.
  #6
Old 04-17-2017, 11:27 AM
IOWA LLY's Avatar
IOWA LLY IOWA LLY is offline
Yes, its really me
Default
If the alternate firing order was better, why hasn't GM changed to it?
Why would they continue to risk broken cranks if the fix was that simple?
Why did they completely redesign the crank and lower end of the L5P if the fix was a simple firing order swap?
That would have been SO much simpler, and SO much cheaper for GM to do........ Hmmm....
__________________
2003 GMC CCSB LLY
Built by me, tuned by me.
2009 ECI Diesel Truck Points Champion
2010 ECI Diesel Truck Points Champion
2011 ECI Diesel Truck Points Champion
2012 ECI Diesel Truck Points Champion
Big thanks to everyone who helps me.
Best 1/8th, 7.29, 98.6MPH (Street tires, fuel only, single Journal bearing GT42 charger) (2010)
Best 1/8th, 6.93, 104.24MPH (Street tires, fuel only, single HX60 turbo) (2016)
Best 1/8th, 6.60, 106.6MPH (Street tires, fuel only, single HX60 turbo) (2017)
  #7
Old 04-17-2017, 11:49 AM
boostwhore's Avatar
Drag racer wannabe
Default
If you read my previous post you will see where I wrote that I don't believe that it's an absolute solution. But the af cams have been proven to improve harmonics, in most cases guys are swapping the stock can out for a more aggressive grind anyways. Why not install something that is ultimately going to allow your engine to run smoother? To the OP if it were me I would wait for the full build then decide what grind af cam to better suite your build, goals can change between now and then.
__________________
Chad
  #8
Old 04-17-2017, 12:07 PM
IOWA LLY's Avatar
Yes, its really me
Default
Quote:
Who says it will last longer before breaking? You really think GM hasn't tested this??
__________________
2003 GMC CCSB LLY
  #9
Old 04-17-2017, 01:05 PM
WolfLLY's Avatar
WolfLLY WolfLLY is offline
Making Chips
Default
Do you believe they have any benefit?
__________________
LMM CCSB LTZ Z71. SoCal motor, s485/68r, 1078 Limitless converter, S&S 200s.
LB7 ECSB 4X4
Thanks to Evan@Limitless, Mark@Danville Performance, Josh Harris@Top Notch, and Corbin(crussel)
  #10
Old 04-17-2017, 01:10 PM
IOWA LLY's Avatar
Yes, its really me
Default
Quote:
I believe they might make the engine run smoother at idle and part throttle. Based on what a lot of people have reported. But there's so many variables involved in comparing before and after an engine build that I'm skeptical of even that.
But honestly I'm not the least bit convinced they help make the crank last any longer. I could be totally wrong, and I don't have a dog in this fight at all. But I've not seen any evidence that they actually help make the cranks live so me personally I wouldn't spend one dime to switch the firing order.
__________________
2003 GMC CCSB LLY
  #11
Old 04-17-2017, 01:46 PM
Harbin_22's Avatar
Harbin_22 Harbin_22 is offline
Turning it back up!
Default
My original engine was built and balanced by the same machine shop as this engine with the AF cam. It is 10x smoother at idle than the first built engine or the two factory bottom ends I've had in the truck. My original built engine made it 5k miles with a brand new LB7 crank and stock cam. Was around 1000hp and I honestly wasn't that hard in the engine. Now this engine received an 80k mile used LBZ crank with a Socal AF cam. It has made it somewhere around 15-17k miles so far and I beat the hell out of it around 1,200hp. It may not be a fix all, but something has made this engine last longer.
__________________
10' CCSB
Carrillos, Fingers 16.5:1 Cast Pistons, 3388AF Cam, PPE Dual CP3's, Exergy 200% inj, Danvile Billet 72R, HSP tripples/2-SXE369's, Limitless Diesel All Billet Comp Trans with LD TC, DHD lock up, Air Dog, Banks, RDL, CalTracs, QA1, M/A, Isspro, Novakanes/420's, 30x14 cheaters
Tuning from Mark@Danville
1,101HP/1727ftlbs
6.56@111 1/8
10.12@138 1/4
  #12
Old 04-17-2017, 01:53 PM
IOWA LLY's Avatar
Yes, its really me
Default
Quote:
Exactly. But there is also the guys out there that have broken brand new cranks with AF cams. And plenty of built motors that have tons of miles on the stock cam and crank and still going. Idk. Just not enough stories like yours Harbin to totally convince me.
__________________
2003 GMC CCSB LLY
  #13
Old 04-17-2017, 02:12 PM
coker6365's Avatar
coker6365 coker6365 is offline
Coker6303's ***** Daddy
Default
I would rather have the piece of mind that I gave it a solid fighting chance if I were building a new motor. The AF is not worth it IMO for just a cam swap on a crank that has already seen the original firing order harmonics since the stock cam has already proven to be more than efficient enough to break stock rods/pistons.
I would run an AF with a full build and a fresh crank though as I did on my first build. I used a new LML crank the first go around. The current build is getting a narrow rod Bryant crank from SoCal. There are a few high horsepower people out there than may speak up about their findings as well. The longevity at high horsepower definitely increased with less crank failures for a given time period in the same application. Obviously its not an end all, however, I do think it may help a little. There is really not enough solid evidence to prove one way or another, but its worth a shot to me if I am already swapping the cam for a build anyway. Its a very small cost compared to the total bill, why risk it...
__________________
2015 Denali CC/SB LML, Farm Truck
2013 EC/SB LML, The Test Rig
2013 RC/LB LML, The Beater
2006 RC/LB LBZ, Tow Mirror Killer. Under the knife again and looking for more horsepuppies.
Big thanks to Josh Harris, Josh Chambers, and my brother Russell Coker for all the help with the LBZ.
  #14
Old 04-17-2017, 02:18 PM
Chevy1925's Avatar
Chevy1925 Chevy1925 is offline
Default
personally id just go straight to a better crank and move on. you can pick up SF cams cheap now used or buy them new for a few dollars less than a AF depending on where you buy from. I sold my spare lb7 crank knowing that if/when mine goes ill be buying a callies crank and fingers pistons right off the bat. may throw a cam in it but whether its AF or SF will depend on if i really want the smoother idle or if i get a good deal on one or the other.
__________________
Quote:
Originally Posted by JoshH View Post
Mike L is my role model. I want to be like him when I grow up.
James
02 LL7 2500HD CC/LB dmax/alli "The Limo"
BIG THANKS TO: Mike L, Steve, Trent, Guy, Dan, Ruben, Josh H, Scott, Brian and everyone else who has put a hand in to help me.
best time to date: 12.39
motor died/bent rods = 3/11/11
back from the dead 7:04pm 4/9/2012
Limo is back in the garage, now driving a built chevy tracker
Tailgate Crew Member #4
  #15
Old 04-17-2017, 02:51 PM
WVRigrat05's Avatar
WVRigrat05 WVRigrat05 is offline
Wound for sound
Default
When mine goes I'm slapping a junkyard 6.0 in it and running it on hog piss.
__________________
Reger
05' Black Chevy CC/SB LT- Blackout Performance built motor/trans/tuning- Gone
The Blessed Hellride- 08' White GMC Sierra SLT CC/SB,
100k miles. Piston eater.
Wife's ride- 2016 Pearl white Legacy limited 3.6R
Rig ride/new DD-02' Black Eddie Bauer explorer 4.6, -180k, still sporting original trans, outlasted two Duramaxs.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
