  #1
Old 03-29-2017, 01:05 PM
JDPlowboy's Avatar
JDPlowboy JDPlowboy is offline
Default Allison oil pump assemblies
Just curious how many people have seen pump failures and how many times have you seen it?
I have seen 5 in the past 2 years and they have all been random except one which was junk right out of the Allison box.
Just curious on numbers.
__________________
04.5 RC/LB with some power from the pacific
  #2
Old 03-29-2017, 01:10 PM
Mike L.'s Avatar
Mike L. Mike L. is offline
Default
The 6 speeds are hard on pumps. 5 speeds not so much.
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #3
Old 03-29-2017, 01:12 PM
JDPlowboy's Avatar
Default
Reason for failure?
__________________
  #4
Old 03-29-2017, 01:20 PM
Mike L.'s Avatar
Default
Quote:
Originally Posted by JDPlowboy View Post
Reason for failure?
Don't really see a reason. Probably cheaper metal on the six speed pumps.
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #5
Old 03-29-2017, 03:04 PM
whytry's Avatar
whytry whytry is offline
Default
Quote:
Do you replace them on standard builds?
  #6
Old 03-29-2017, 03:28 PM
Mike L.'s Avatar
Default
I replace them when they are bad.
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #7
Old 03-29-2017, 05:36 PM
KyleC4's Avatar
KyleC4 KyleC4 is offline
Default
My 5 speed with 172k miles was bad when Mike rebuilt my trans for me last month. He showed me pump. Interesting I must say though in regards to 6 speeds.
Mike, do the trans show or have a telltale sign when pump is wearing out? I figure line pressure is dropping so would it show up as constant higher values in the TAP cells then normal? Longer engagement times? Flares?
__________________
TEAM Chevrolet Cadillac
Mike L and Inglewood transmission
  #8
Old 03-29-2017, 07:44 PM
Mike L.'s Avatar
Default
It takes a trained eye to see a pump that is about to go out. They will transfer metal from one side to the other.
Pump gears are made of sintered metal ( powdered steel compressed ) This makes a better bearing surface for better wear. Kinda like babbit bearings on the crank minimizing wear. The pump gears are harder and are prone to gaul ( transferring metal from one side to the opposing side ) Once you see the slightest gauling; your pump is done.
Wonder how many alli's have been built with weak ass pumps that are about to grenade.
Wonder why you have weird problems after a so called build? Throwing a clutch pack into the trans will put you back on the same road of disaster as you are trying to fix. you must look deeper.
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #9
Old 03-30-2017, 12:35 AM
henery97's Avatar
henery97 henery97 is offline
Default
Had a bad pump in a 5 speed that ate a c2 clutch. Pretty obvious grooves everywhere. Surprised that the contaminates from the clutch pack were enough to damage not only the pump housing but the pump gears, had to replace the whole thing.
__________________
17 Denali L5P
unreliable POS
07 LBZ/alli cc/sb
s475/stock, race casts, exergy 60s
12.5@108mph
85 K5 Jimmy
6.2L Diesel
  #10
Old 03-30-2017, 12:27 PM
KyleC4's Avatar
Default
It's amazing how many components we have in our vehicles that are made from powdered metal.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
