Old 04-17-2017, 08:56 AM
JDPlowboy's Avatar
JDPlowboy JDPlowboy is offline
Default Cracked Piston solutions
Has anyone ever replaced stock Pistons with mahle Pistons without balancing the rotating assembly? I know for years people were cutting and costing Pistons and not having any trouble. Why couldn't you just swap all 8 Pistons and roll on with a stock application?
04.5 RC/LB with some power from the pacific
Old 04-17-2017, 09:05 AM
quinton's Avatar
quinton quinton is offline
I've heard of guys doing it.
EFIlive dsp5 by me, Built trans by me, 68 danville, stock fuel, lifted. died 6/20/2013 Cracked piston. Best time 12.75 on fuel
Alive 11/15/13: lowered, Built motor, s475, plenty of fuel, plenty of spray. Tune 3 fuel only 11.84 @114, Tune 5 little bit of spray 11.45 @ 121. Both times with melted turbine wheel, loose turbo from pedestal with blown out flange gasket. .
Old 04-17-2017, 09:08 AM
ikeG's Avatar
ikeG ikeG is offline
Oughta Know Better
I have done it with no problems.
03 Chev CC SB ZF6-Gone
04 GMC CC SB SLT LLY
597/1096 Batmostocker-Gone
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
'Oughta K
Old 04-17-2017, 09:21 AM
Chevy1925's Avatar
its been done, problem is you are increasing the chances of a breaking a crank and hurting the stock bearings more (assuming stock bottom end). if you dont care, roll on!!
James
best time to date: 12.39
Tailgate Crew Member #4
Old 04-17-2017, 09:39 AM
SickLL7Crenshaw's Avatar
SickLL7Crenshaw SickLL7Crenshaw is offline
Billy The Kid
Yep lol several guys down here do this. 15k miles later there bearings look like they have 150k on them. And most of those engines done like that have a nice vibration at idle and at 1800-2000rpm from what I can tell riding in them. No thanks.
Blake
SOLD: 05 LLY CC/SB 140k 11.18@123.7 stock/480
01 LB7 EC/SB 308k 11.31@119.8 69sxe stock motor
Tuned by Unleashed Duramax Tuning
Crenshaw Ranch, LLC. 8LB7s, 7LLYs, 1LBZ , 2LMMs, 1L5P
Thanks to Evan@Limitless, yellowchevy, and Henry@COTNP
Old 04-17-2017, 09:42 AM
ikeG's Avatar
Oughta Know Better
If you have a few to pick from, you could weigh each piston and replace it with the closest one in weight. These engines are so far from perfect balance from stock that you wouldn't believe it.
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
'Oughta K
Old 04-17-2017, 09:52 AM
JDPlowboy's Avatar
That's what I have noticed when replacing stock Pistons with stock Pistons. The stock weight has so much variance!
Old 04-17-2017, 09:55 AM
JDPlowboy's Avatar
If I balanced the rods to Pistons I could see that being done. But I'm just trying to stay away from
Taking the crank out
  #9
Old 04-17-2017, 09:58 AM
ikeG's Avatar
Oughta Know Better
Ok, a pm made me reread the original post. I misread it. I thought jd asked if anyone swapped stock-for-stock Pistons. I have never swapped a stock for a Motorsport piston. However, if for some reason the Motorsport Pistons would weigh the same or a few grams variance, then I would definitely do it. But I doubt they weigh near the same. I've never weighed the two compared at the same time.
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
'Oughta K
  #10
Old 04-17-2017, 10:00 AM
Chevy1925's Avatar
why? your damn near to that point as it is.
stock balance is all over the damn place but you are adding MORE weight with the mahle pistons (assuming you are going cast, not forged).
James
  #11
Old 04-17-2017, 10:03 AM
JDPlowboy's Avatar
Time, money and stock truck. Just trying to get options figured out.
  #12
Old 04-17-2017, 10:05 AM
JDPlowboy's Avatar
I've swapped stock for stock several times and haven't had any problems several years of running under their belts. Just looking for a better option not sure why these lml Pistons junked out.
  #13
Old 04-17-2017, 10:23 AM
Chevy1925's Avatar
how about some info on the engine you are playing with? 100% stock? what model? if not stock, list mods done to the engine
James
  #14
Old 04-17-2017, 11:16 AM
JDPlowboy's Avatar
Lml with 50hp tune. Only modification was straight pipe
  #15
JDPlowboy's Avatar
It's getting a new set of gm Pistons and rings
