Old 04-25-2019, 08:03 PM
Sgreen Sgreen is offline
FNG
Default New to fourm
New guy from Graham Wa, I have an 05 lly with 240k, just had heads machined and installed Mahle grade C head gaskets on with ARP studs, new B&D drivers side exhaust manifold, PPE up pipes, MBRP 3" down pipe, MBRP 4" straight pipe to muffler Pusher supermax y-bridge with larger charge tubes, AFE blade runner turbo inlet, PPE accelerator programmer, Banks 4" muffler, was asking if this combination of parts will help wake the demons up!!! Thanks for your time
Old 04-25-2019, 10:37 PM
DAVe3283's Avatar
DAVe3283 DAVe3283 is offline
Welcome! Those parts will make it run much stronger than stock, but you're going to be limited on tuning with the PPE box tuner. But since you appear to have stock turbo, injectors, and CP3, it should be close to what an EFILive tune would do. And it will be more than enough to hurt a stock transmission. If it were me, my next upgrade would be a built transmission.
If you take it easy in 5th gear and the 4->5 & 5->4 shifts, you can probably get by for a while on the stock transmission. But start putting some pennies aside for when it lets go.
Old 04-26-2019, 06:12 AM
BoiseRob's Avatar
BoiseRob BoiseRob is offline
Welcome! Why did you have the heads pulled and reworked?
As to your question of whether it will wake up the Demons? Some of the parts yes, some of the parts are unnecessary (Y bridge & charge tubes) with a PPE tuner & stock turbo. Even the BD manifold upgrade won't do much if anything again because of the stock turbo. The only thing the LLY's needed were an intake and turbo inlet.
If your future plans are to upgrade the turbo, fueling & tuning, you built a strong base.
For the first 10 years, my 2007 LBZ lived with a 425hp DD tune (thanks RC!), stock trans (Mike L cooler & Transgo JR installed by IT), MBRP Cat-back 4" and stock fuel.
These trucks really don't need much attention if they're maintained properly...
Old 04-26-2019, 06:43 AM
Mike L.'s Avatar
Mike L. Mike L. is offline
Welcome
Inglewood Transmission Service
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
Old 04-26-2019, 06:57 AM
zakkb787's Avatar
zakkb787 zakkb787 is offline
<thatís not me...
Welcome. You have a strong base as mentioned. The PPE is a good tuner but thereís more to be had with a custom EFI tune from a vendor, although itís somewhat pointless on a stock LLY trans. Save for a good built trans from mike or Evan, meanwhile running the PPE. After you get your trans done, a hot EFI tune will really impress you. Then you can step up to a newer turbo from Mark at Danville performance even in stock fuel you can make impressive numbers.
2006 LLY CC/SB LT3 black, charcoal interior, tuned, leveled on 33s, my little piece of heaven
Other toys:
1982 K10 6.2 Detroit diesel/sm465/np205 with 4 inch lift and 35s.
2011 Yamaha YFZ450X
2018 GasGas XC300
Old 04-26-2019, 05:08 PM
torqued2dmax's Avatar
240,000 mi and those upgrades and the talk of demons , call Mike or Evan soon !
05 CC/LB DRW LLY Allison
