Old 01-14-2020, 07:56 AM
turndriverside's Avatar
turndriverside turndriverside is offline
Gearhead
Default Hardwire Dashcam from Mirror Power
Anyone done anything like that yet?
I can find a plenty of hard wire kits for radar detectors, but not a single one for a mini usb or a micro usb.
https://blendmount.com/mirrortap/
https://www.gen5diy.com/products/14-...tector-harness
Old 01-14-2020, 08:00 AM
Gearhead
Actually looks like I answered my own question.. the 2nd link you can select for them add two additional power output for a dash cam.
Old 01-14-2020, 08:09 AM
Gearhead
If you don't want to spend $55 on that wire kit, other option is to get this - https://www.amazon.com/Two-prong-Uni...tronics&sr=1-8
Old 01-14-2020, 11:03 AM
DAVe3283's Avatar
DAVe3283 DAVe3283 is offline
I usually get a sunroof harness from a junkyard Suburban which gives Retained Accessory Power right to the center console. Then just wire in a cheap 12V to USB adapter. Works great.
Pulling power off the mirror means the dash cam would shut off with the key, which might be fine for most use cases. I prefer it to be on RAP though.
Old 01-14-2020, 12:22 PM
2004LB7's Avatar
2004LB7 2004LB7 is offline
^^ I got my 5 volts from a 12 to usb adapter wired into my sunroof to power my dashcam
2008 Chevrolet 3500HD DRW LTZ
Old 01-14-2020, 03:20 PM
snowman22's Avatar
snowman22 snowman22 is online now
I did the sunroof too, below is the thread with the wire diagram I used.
https://www.duramaxdiesels.com/forum...ad.php?t=81818
2015.5 LML GMC Denali 3500 SRW 4wd CCLB 100k Miles
Mike L Trans, 4" FlowPro, MBRP Down Pipe, 30" FTE Resonator, S&B Intake, Twin Kennedy Pumps, Bilstein 5100, Kryptonite UCA and Tie Rods, EBC Sport Rotors Orange Pads, Edge CTS2
Old 01-16-2020, 07:48 AM
Gearhead
Awesome thanks guys. I already sunk $55 into that harness, so I'm kind of committed to it, but it should work for me just fine as long as the key is on in the ignition.
Old 01-17-2020, 06:38 AM
Gearhead
I got the gen5diy harness yesterday and installed it, along with the 12v to 5v USB Mini step down module. I went with this one: HOMREE DC 8-35V to DC 5V Step-Down Converter Buck Module 12V/24V to 5V 3A 15W Mini USB Output Power Adapter, it had the best reviews for the price.
Boy was it a pain in the ass to fit all of that under that little plastic cover, but it sure looks clean!
