  #6271
Old 09-18-2019, 09:19 AM
zakkb787's Avatar
zakkb787 zakkb787 is online now
<thatís not me...
Thanks guys. Sorry I’m just now seeing these. The tail lights are the cheapest ones on eBay I could possibly find. The sockets are sketchy but they work haha
2006 LLY CC/SB LT3 black, charcoal interior, tuned, leveled on 33s, my little piece of heaven
Other toys:
1982 K10 6.2 Detroit diesel/sm465/np205 with 4 inch lift and 35s.
2011 Yamaha YFZ450X
2018 GasGas XC300
  #6272
Old 09-18-2019, 12:25 PM
STLCHEVYHD's Avatar
STLCHEVYHD STLCHEVYHD is offline
Haywood Jablome
I put a Pedal Commander in the new truck. Holy smokes does that make a difference!
-Jason
01 Chevy 2500HD ccsb 4x4, black, all the cheap bolt-on's I can do.
  #6273
Old 11-15-2019, 04:46 PM
Pure Diesel's Avatar
Pure Diesel Pure Diesel is offline
Randsburg Drifter
Well, today I hit 200,000 miles on my 03. Two things I love about this truck. One the day I bought it and two the day I put the LBZ in it. The LBZ motor has 200,000 miles and I've put 87,000 miles of that on. I plan to keep it two more years, sell it and then buy another Duramax.
Sent from my LM-G820 using Tapatalk
White GMC 2003 2500HD D/A SLE/CC/SB 4x4] Bilstein 5100~Air bags~Autometer Gauges~MBRP 4" Exhaust~Cognito Braces~Kryptonite upper control arms DMAXSTORE XD TIE RODS~PPE high flow pick up~Fass 95 pump~Titan 52-gal.~Prodigy~New tranny 02/12/2015 Mike L. "Baby Frankenstein " w/Goerend converter w/ Mike L. tranny cooler and pump rub fix~6 speed tap shifter~Siege Engineering Anvil train horns(Very Loud)~LED headlights Hi/Lo
New injectors as of 03/12/2010 @ 80k miles
Injectors started going again at 115k. 07/01/2013
06LBZ engine transplant from Russ @ RPM Motorsports~No more Lb7 injectors to replace
'19 Yamaha YXZ 1000RSS
'04 29' Keystone Laredo 5th wheel
  #6274
Old 12-03-2019, 09:02 AM
gmc502 gmc502 is online now
I plowed some snow today,new tires were awesome.BFG KO2's 35x12.50x20's.
those were the stock 20's on the right.
2002 GMC 2500HD, ECSB, 4WD, LB7,300k miles and still truckin
new style gm exhaust manifold, banks big head wastegate, PPE boost valve, banks air intake,high idle switch in cruise control, stock but not for long
EFI live tuned byMe now,dps5 switch,EGT probe and autometer boost sensor,SoCal 6spd conversion
  #6275
Old 12-03-2019, 09:05 AM
copied my friends truck,,he put those tires on first.we both plow.did an alignment after mounting tires and only had to move the toe ever so little.
  #6276
Old 12-03-2019, 02:22 PM
DAVe3283's Avatar
DAVe3283 DAVe3283 is offline
I replaced my aux oil cooler lines and transmission cooler lines last night. Towed particularly heavy a while back, and the truck started leaving drops on the driveway. I had put on some generic braided -8 AN lines from Summit Racing when I built the motor. They did fine for years, but after that last tow, they were done for. The hot lines (both oil and trans) had started to melt, and the hose was expanding out through the braiding.
I took the opportunity to switch from -8 to -10 size, so new fittings in the sandwich adapter, trans, and coolers. The sandwich adapter & coolers were all sized for -10 to begin with, so I am not sure why I put -8 line on back in the day. Never caused any restriction that I could tell, but I can't think of a reason not to go -10 now. Had the local Parker shop make me some high-temp hydraulic lines. Not cheap, but man they are nice. Hopefully that will be the end of the leaking for a long time.
  #6277
Old 12-03-2019, 08:55 PM
Bdsankey's Avatar
Bdsankey Bdsankey is offline
Gearhead
Today I ordered a new set of General Grabber AT/X tires for my daily/tow rig (285/75r16 on PYO) as well as one of Evan’s C3 Oiler setups for each truck.
Current Rides:
-Tuned by Zach @ Starlite
-Built Motor, Forced Inductions Billet ETR Gen 4 S480/96/1.10 T6 w/V2 Race Cover, Modded Exergy 250% Injectors, Exergy 14mm Street Pump/LBZ CP3, Goerend Q Converter, Billet Trans, Fuelab Supply Pump/Reg, RCD & Beans Sumps, Front E-Locker, TrueTrac, Yukon 4340 Rear Shafts, Traction Bars, DHD Center Link Brace, DHD Lower Crossmember Support, Banks iDash 1.8 Monitoring System
-Tuned by Starlite
-Cast S475/96/1.10 T6 Over Stock IHI, FASS 150,4" Exhaust, RCD Sump, PPE Sleeves, DHD Centerlink Brace, DHD Lower Crossmember Support, Steering Wheel Radio Control Swap, LML Oil Pump, LML Piston Cooling Nozzles, 2020 L5P Oil Cooler, Derale Aux Oil Cooler w/Fan, Banks iDash 1.8 Monitoring System
  #6278
Old 12-29-2019, 07:16 PM
took advantage of the weather,,got her washed and then went after the little rust spots on the paint w/ Adam's iron out.got the stubborn ones w/ collinite cleaner.
had time to clean the inside to.of coarse,bad weather is coming in.oh well
  #6279
Old 12-29-2019, 08:04 PM
DMAX Slim's Avatar
DMAX Slim DMAX Slim is offline
Collywobbler
Used it to haul the tractor, disk, and plows home after plowing the deer food plot yesterday.
2003 CC/SB LB7 "The Ole Heifer"
1056-Suncoast internals
Built by SMR Diesel Performance
2003 Toyota Double Cab 4WD V6 D.D.
Jesus Is The Only Way!
2002 RC/LB LB7~~Sold~~
  #6280
Old 01-01-2020, 06:14 PM
TheBac's Avatar
TheBac TheBac is online now
Not the Dmax, but working on the Cruze. Started getting P20e4 and "bad DEF" messages, so have been replacing the three EGT sensors. EGT1 and 2 were easy. But EGT3 decided it didnt want to leave, instead breaking it's retaining nut off so I couldnt get it out. Spent today removing the front pipe and ended up cutting the bung off.
Got another weldable bung coming from Amazon, while also waiting for new gaskets and flange nuts, so the little car will be back on the road next weekend.
As a consolation, I get to drive BBT regularly again.
Tom
  #6281
Old 01-07-2020, 05:41 PM
frankenstien's Avatar
frankenstien frankenstien is offline
my fass lift pump decided that the system needed 30+ psi system pressure, even with the regulator backed all the way out, so that was cool. pulled that and sent it them to be fixed.
tossing around the idea of replacing the D max or keeping it
2005 ECSB LLY
Built Trans w/SC1058
Bumpers built by me
  #6282
Old 01-14-2020, 07:58 AM
M.A.M.'s Avatar
M.A.M. M.A.M. is offline
Worked on it for a while last night. SoCal heads, head gaskets, and swapping 625s for my 425 ARPs.
2015 CCLB 3500
HTML code is On
