Old 01-09-2020, 05:32 PM
JoshH's Avatar
JoshH JoshH is offline
Default SoCal 9200 cam
We are planning on going through Richard's motor to fix some problems and upgrade some parts before he goes back to Denver for the DPC. One of the things we are considering is changing the 9100 cam out in favor of a 9200. Does anyone have back to back experience with both cams or even been around a truck that had a 9200 cam? One of the things we are concerned about is hurting how well the turbos spool. The 9100 cam really brings boost up pretty quick, and when you are at 8000 ft DA, that can make things difficult sometimes. Guy and Lorenzo told us the 9200 would lose some of the spooling characteristics, but they couldn't give us much in the way of exactly how much it would affect it. We don't want to run into an issue where we can't get on top of the chargers.
06 Silverado 4x4 CC/SB
Old 01-09-2020, 06:45 PM
coker6365's Avatar
coker6365 coker6365 is offline
Coker6303's ***** Daddy
Any info would be appreciated. We are very competitive as we sit, but there is always room to grow.
Sent from my SM-G965U1 using Tapatalk
2015 Denali CC/SB LML
2006 RC/LB LBZ, SXE472/87/1.0 & FI491/100/1.45, 250% F1 Injectors, Dual 10mm CP3, SoCal Built Engine, JoshH Built Trans, JoshH Tuning. 10.18 @ 140mph, 1487HP 2885TQ Corrected ATS Dyno. 2019 Diesel Power Challenge 1st Place
Big thanks to Josh Harris, Josh Chambers, and my brother Russell Coker for all the help with the LBZ.
Old 01-13-2020, 12:36 PM
coker6365's Avatar
Well, sounds like 9100 it is.
Old 01-13-2020, 12:51 PM
Chevy1925's Avatar
are you sticking with the same converter/stall?
James
2002 LB7, LLY, LBZ, LMM, LML, L5P 2500HD CC/LB dmax/6sp alli "The Limo"
2020 L5P 2500HD CC/LB dmax/10sp alli "The New Limo" staying stock........ish
Tailgate Crew Member #4
Old 01-13-2020, 12:58 PM
coker6365's Avatar
That's open for suggestion as well. Would rather not have to do another reinstall but we will it it's necessary. Havent had much seat time in a good track scenario to see how this J will 60ft at the track regardless.
Old 01-13-2020, 01:02 PM
Chevy1925's Avatar
if you were on edge before, id just up the converter stall close to the same amount the 9200 moves the power band from before.
or you can see if you can con Evan into letting you try the new converter dump valve for the allison, no need for a re-stall then. hasnt been released to the public from what i saw on his FB post.
James
Old 01-13-2020, 01:25 PM
Bdsankey's Avatar
Bdsankey Bdsankey is offline
Gearhead
From what my understanding of the 9200 is, IMO you're better off with the 9100 and the J you have now. The J is a fair bit of stall but it couples so damn well I don't think you'll see a reduction in 60ft times. The next converter above that would be an AR which is ~3400 stall and I believe overkill for the charger's on the truck.
Based on the way the truck ran and PW you were giving it, I don't think you guys are out of air yet but more so reaching the ideal limit of that injector size and as you found out the limitation in the block itself. If you'd have turned on the big stage it would have been an impressive number but would have been an even more impressive mess to deal with during DPC.
Current Rides:
-Tuned by Zach @ Starlite
-Built Motor, Forced Inductions Billet ETR Gen 4 S480/96/1.10 T6 w/V2 Race Cover, Modded Exergy 250% Injectors, Exergy 14mm Street Pump/LBZ CP3, Goerend Q Converter, Billet Trans, Fuelab Supply Pump/Reg, RCD & Beans Sumps, Front E-Locker, TrueTrac, Yukon 4340 Rear Shafts, Traction Bars, DHD Center Link Brace, DHD Lower Crossmember Support, Banks iDash 1.8 Monitoring System
-Tuned by Starlite
-Cast S475/96/1.10 T6 Over Stock IHI, FASS 150,4" Exhaust, RCD Sump, PPE Sleeves, DHD Centerlink Brace, DHD Lower Crossmember Support, Steering Wheel Radio Control Swap, LML Oil Pump, LML Piston Cooling Nozzles, 2020 L5P Oil Cooler, Derale Aux Oil Cooler w/Fan, Banks iDash 1.8 Monitoring System
Old 01-13-2020, 01:42 PM
JoshH's Avatar
I think the LL is higher stall than the J, but I don't think it is over 3400. I'm not 100% sure the cracked block doesn't have something to do with losing water pressure from a failed water pump. I agree on the injector; we will be stepping up on injector size as well. I think we have a pretty good game plan to make some improvements without taking away too much from our strong areas.
  #9
Old 01-13-2020, 01:51 PM
Bdsankey's Avatar
Gearhead
If you guys don't change the valley charger I cannot think of a reason to jump away from the J. The J is the best coupling high stall converter available from Goerend. I'll send you over some data I received from Goerend on dynamics inside the converters (J vs AR vs Q).
Current Rides:
-Tuned by Starlite
  #10
Old 01-13-2020, 05:52 PM
Ne-max's Avatar
Ne-max Ne-max is offline
I like turtles
At Richard's power level I would just stick with a stocker. Those baby twins wont flow enough to benefit from big boy cams.
2013 ccsb Tow rig
2006 rclb 6.6
The fun stuff. Built motor, trans, triples, nitrous
  #11
Old 01-14-2020, 04:38 AM
ikeG's Avatar
ikeG ikeG is offline
Oughta Know Better
Are you going to engine dyno?
My thoughts are you won't know till you try, unless you are dynoing. Just have to accept the fact that you might have to put the 9100 back in with the engine in the truck.(not fun)
Caleb swapped cams a while ago without removing heads. Used 16 pen magnets to hold lifters up.
03 Chev CC SB ZF6-Gone
04 GMC CC SB SLT LLY
597/1096 Batmostocker-Gone
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
'Oughta K
