Old 01-09-2020, 06:43 AM
pavetim pavetim is online now
Default EGR delete little confused
I started mine. I got a kit that has the crossover tube, lb7 up pipe, down pipe and it has like some premade T hose for the coolant reroute. I am confused cause i seen a video of a guy doing it and he had a 90 degreee coolant hose and a plug for the coolant. Do i need those 2 things in addition to what i have?
Old 01-09-2020, 07:05 AM
ZeroGravity58's Avatar
ZeroGravity58 ZeroGravity58 is offline
What year truck?
09 lmm ccsb ltz, moonshine, mpi s480 over 68mm vgt, sdp y bridge, BigDipper trans, 60 overs, 10mm pump, ppe up pipes and manifold, banks intercooler & exhaust, airdog165 w/sump, isspro guages, traction bars, the list goes on...Big thanks to BigDipper!
01 lb7 red RC/LB 11.58@119 MPH, SOLD
01 lb7 Black CC/LB, SOLD
Old 01-09-2020, 08:39 AM
2015
Old 01-09-2020, 08:41 AM
Here is the plugs he used. The one is for the return on the 9th injector. Top one is for coolant
Old 01-09-2020, 06:51 PM
Nothing? I need to know so i can order. The 9th injector plugs i will get just not sure about the coolant questions
Old 01-09-2020, 06:55 PM
JoshH's Avatar
JoshH JoshH is offline
Different kits deal with coolant with different methods. None of them do anything about the 9th injector though. I would guess the plug for that is the only thing you need if you’re new down pipe doesn’t have provisions for installing it.
06 Silverado 4x4 CC/SB
Old 01-12-2020, 04:51 PM
What is the sensor on the top of the up pipe? I had to cut it off to get last bolt out
Old 01-13-2020, 08:05 AM
JoshH's Avatar
Exhaust temp sensor for the EGR inlet. You don't need it anymore.
  #9
Old 01-13-2020, 01:48 PM
Was hoping so since new up pipe doesnt have it lol. Well got most of it done just need to wiggle egr cooler out and remove up pipe from turbo pedestal. Think install will go smoother than removal, at least hope so. Anybody have torque specs for the up pipes and v clamps?
  #10
Old 01-18-2020, 03:57 PM
What sensor should i turn off in efilive?
