  #1
Old 01-10-2019, 04:57 PM
Madspeed's Avatar
Madspeed Madspeed is offline
Fat Bastard
Default LBZ lifters
Looking for some lbz lifters in good shape.
__________________
71 2WD 4X4 1ton conversion, LB7 TT SCV and some other shit/ OOPs I found a suburban to melt into the pickup and make a CC longbed 71 4x4. back under the knife for the 71
2007 Suburban LBZ/LMM Lifted and shit. Pile of Shit mounting... Fingers ovals, Socal Stage 2 cam, Socal stage 1 heads, SoCal billet mains, ats damper, 480SXE, PPE dual fueler, ARP studs top to bottom,
  #2
Old 01-10-2019, 06:40 PM
Ne-max's Avatar
Ne-max Ne-max is offline
I like turtles
Default
I have a set out of a 300k mile engine that cracked a piston. You can have them if you pay shipping. Not sure if miles scare ya.
__________________
2013 ccsb Tow rig
2006 rclb 6.6
The fun stuff. Built motor, trans, triples, nitrous
  #3
Old 01-10-2019, 09:48 PM
Bonestock's Avatar
Bonestock Bonestock is offline
Default
I should have a set of LMM lifters here next week or so. They are currently at Custom Auto in Idaho. They were out of my LMM with 28k miles on them lol.
__________________
14 Kingranch F350 6.7 PSD
16 Denali LML .....Stock for now waiting to go under the knife!
  #4
Old 01-11-2019, 07:40 AM
Bdsankey's Avatar
Bdsankey Bdsankey is offline
Gearhead
Default
I've got a set of LLY lifters, 140k miles on them. Send me a PM.
__________________
Current Rides:
1) Toy: 2005 LLY ECSB, Leather, Sunroof
-820hp/1748ft-lbs @ Duramax Tuner (6/25/18) - Old 475/87/1.00 setup
-Built Motor, Forced Inductions Billet ETR 480/96/1.10 T6 w/V2 Race Cover, Modded Exergy 250% Injectors, Exergy 14mm Street Pump/LBZ CP3, Goerend Q Converter, Billet Trans, Fuelab Supply Pump/Reg, RCD Sump, Front E-Locker, TrueTrac, Yukon 4340 Rear Shafts, Traction Bars, DHD Center Link Brace, DHD Lower Crossmember Support
2) DD/Tow Rig: 2002 LB7 CCSB, Leather, Loaded
-Bosch NEW Injectors, FASS 150, 3" Downpipe, 4" Downpipe Back, RCD Sump, PPE Sleeves, DHD Centerlink Brace, DHD Lower Crossmember Support, Steering Wheel Radio Control Swap
  #5
Old 01-11-2019, 10:24 AM
Madspeed's Avatar
Fat Bastard
Default
Quote:
Going in my Twin turbo motor w socal stage 2 cam. Do I really want that many miles on them?
__________________
  #6
Old 01-11-2019, 10:36 AM
Bdsankey's Avatar
Gearhead
Default
Quote:
Theoretically they don't really go bad as its a roller setup and only really fail when they get lack of lubrication or debris ran through them. That said, I replaced them on my truck when I built it and will be doing the same if the heads come off my LB7 tow rig.
__________________
Current Rides:
  #7
Old 01-11-2019, 10:41 AM
Ne-max's Avatar
I like turtles
Default
I personally would only go new. They are 400 new
__________________
2013 ccsb Tow rig
2006 rclb 6.6
  #8
Old 01-14-2019, 09:53 AM
Madspeed's Avatar
Fat Bastard
Default
Man I wish I could just throw 400 here 2k there like nothing =(
This Fing motor has taken 3 years so far. Still need push rods, Injectors, Pumps, ECT
Ive got to stop telling people they dont need a rebuilt transmission when they walk in pre sold themselves (NOT!)
__________________
  #9
Old 01-14-2019, 10:25 AM
Chevy1925's Avatar
Chevy1925 Chevy1925 is online now
Default
Double edged sword though. You donít want to put a used set of lifters in that then lock up a roller and kill your cam. Storage of the lifters plays a roll here. They should be stored in good clean oil and out of the open air. Lower mileage, less likely to have worn rollers. If the cam is new and you donít have lifters, its best to buy new so the lifters wear into the cam together. They are not flat tappet so not as important but they still wear together
__________________
Quote:
Originally Posted by JoshH View Post
Mike L is my role model. I want to be like him when I grow up.
James
02 LB7, LLY, LBZ, LMM, LML, L5P 2500HD CC/LB dmax/alli "The Limo"
BIG THANKS TO: Mike L, Steve, Trent, Guy, Dan, Ruben, Josh H, Scott, Brian and everyone else who has put a hand in to help me.
best time to date: 12.39
motor died/bent rods = 3/11/11
back from the dead 7:04pm 4/9/2012
Limo is back in the garage, now driving a built chevy tracker
Tailgate Crew Member #4
  #10
Old 01-14-2019, 10:30 AM
ikeG's Avatar
ikeG ikeG is offline
Oughta Know Better
Default
There are two different lengths of lifters. I cannot say for sure which engine is shorter, but its definitely a difference in height. Had several sets in a pile from core engines and there was a mysterious set of shorter ones.
Sent from my SM-G960U using Tapatalk
__________________
Isaac Griffith, formerly 04jimc
03 Chev CC SB ZF6-Gone
04 GMC CC SB SLT LLY
597/1096 Batmostocker-Gone
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
New DD/Beater: Beat up 06 GMC CCSB w/ 252,000 miles
Current Tow Rig-12 Ram 4500 Crew
'Oughta K
now Better'- PPL Lim Pro Stock 05 3500 Crew Cab 158" WB 2014 PPP 2.6 Champions
Thanks to Blackout Performance
  #11
Old 01-14-2019, 10:42 AM
Bdsankey's Avatar
Gearhead
Default
LB7 is shorter. Purchase LLY+ lifters as they are all the same PN up until L5P.
__________________
Current Rides:
  #12
Old 01-14-2019, 04:56 PM
Madspeed's Avatar
Fat Bastard
Default
Yea I have a set of Lb7s, to short. the core LBZs sat around and have some surface rust so thems out
__________________
  #13
Old 01-14-2019, 05:30 PM
Ne-max's Avatar
I like turtles
Default
Just remember. With Performance specs need to be closer and parts need to be 100%. Like the saying says if you cant afford to do it right the first time you can't afford to do it twice.
I am suprised no one has a low mile set laying around.
__________________
2013 ccsb Tow rig
2006 rclb 6.6
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vB.Sponsors
