  #1
Old 01-10-2019, 04:17 PM
sfanello sfanello is offline
sfanello
Question 2011 LML Low MPG
Got a fairly stock 2011 LML, 87k miles, FASS 165 LP, S&B air intake, sinister intake bridge, and running 33's @ 70psi on a 2" front-end leveling kit. I commute daily to work which is a combination of town and highway. Changed my stock fuel filter and installed the FASS at 84k. NOT deleted. Currently only averaging 11.4 MPG (dic) and about the same on my Edge CST2. Seems to regen in spurts 1-2 times per fill up. Any thoughts, ideas or suggestions??? Thanks!
__________________
2011 Chevy 2500HD LT 4x4 LML
S&B Cold Air Intake
Sinister Intake Bridge w/ Resonator Delete
Fleece PCV Block Off w/ Reroute
FASS 165 Lift Pump
Beans Sump
Edge CTS Insight
3" Leveling Kit
285/75R17 Nitto Grappler G2's
  #2
Old 01-10-2019, 04:35 PM
2004LB7's Avatar
2004LB7 2004LB7 is offline
Default
Run some tanks and hand calculate first then report back. The DIC can be way off
How many miles do you typically get on a full tank?
__________________
2008 Chevrolet 3500HD DRW LTZ
285/75/17 Nitto Dura Grapplers, 4.56 gears, Front and rear ARB lockers, Efi Live tuning by me, Raptor 160 LP, Cognito 4-6 NTB Lift, 4" Exhaust, Built Trans by Mike L.
2006 BRM Jetta TDI. Injectors, turbo, Malone custom tuning on ecm and tcm
  #3
Old 02-03-2019, 10:34 PM
sfanello
Default
Will do. Just getting 'er up and running again after this last cold spell (wasn't running the right additive for anti-gelling *smh*) Stay tuned!!!
__________________
S&B Cold Air Intake
FASS 165 Lift Pump
Beans Sump
Edge CTS Insight
3" Leveling Kit
  #4
Old 02-03-2019, 10:43 PM
Whitetail Addict's Avatar
Whitetail Addict Whitetail Addict is offline
Rockin' the stock tune
Default
How many miles are on the truck? Has this only been in the winter months? Is it idling a lot?
The dpf can clog up. Basically it doesn't burn as much off per regen, thus starting at a higher soot content and regenerating more frequently.
__________________
Brandon
'12 LML
'03 LB7
If you feel like everything is under control, you're not going fast enough - Mario Andretti
  #5
Old 02-04-2019, 04:18 AM
NC-smokinlmm's Avatar
NC-smokinlmm NC-smokinlmm is online now
<<<Future tuna killer
Default
You ever tow anything while its trying to regenerate?
__________________
2010 GMC 1500 RCSB Denali Clone < lifted 22's/33's/ Kooks / Magnaflow / 5.3 / 6l80E / TVS1900 @ 14#'s / BTR Top End / Boosted Bump Stick / Trunion upgrade / 90mm / 10% over / 2.8 griptec / 105 lb ID's / Mayhem built/tuned.
2016 LML CCSB Denali < Lifted 22's/35's, Fox 2.0 < I officially need help.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vB.Sponsors
