  #1
Old 12-02-2010, 02:18 PM
Mike_S's Avatar
Mike_S Mike_S is offline
OOPS!
Default Who on here has been unhappy with results using Amsoil?
I had been running amsoil 15W/40 engine oil in my LB7 for the past 30K miles or so. I had noted lower oil pressure, but chalked it up to being the better flow characteristics of a synthetic oil, that was until i noted it continuing to fall over the past months. Now, upon disasembly of the engine, I find that all of the main bearings have been trashed, and the rod bearings beginning to flake.
My question is, who uses/has used Amsoil, and were you satisfied with the result? Don't get me wrong, they make a killer product, and this is the first trouble I have had with them, but it brings about serious doubt in my mind as to weather or not I will continue using their product...
If you used Amsoil and were dissatisfied, what did you switch to?
__________________
Nancy:
2004 CC SB, LB7, 2500 HD, Borg Warner spinny thingy, Carillo tough stuff, Transgo/suncoast tranny stuff, DMP squirt guns, and a couple custom parts.
The General:
1994 EXT Cab, SB, 1500 HD, 350 SBC, Whole Buncha $hit And Its Still Not Fast.
(I do all my own work...and thats not always good)
Good, Fast, Cheap...You Can Only Have Two!
You only need 2 tools: duct tape and WD-40. Duct tape for when it moves and isnt supposed to, and WD-40 for when it don't move and should!
  #2
Old 12-02-2010, 02:21 PM
Big Block 88's Avatar
Big Block 88 Big Block 88 is offline
Multiple choice muscle
Default
Interesting this thread came up, I just switched back to Rotella 15W40 tripple T and my motor is running so much quiter and smoother than it was with Amsoils synthetic. I don't believe I see the need to spend the extra money for that crap.
__________________
"SARGE" 1966 Jeep/Kieser M35a2 duece, whistler multi fuel engine 6x6 pure beast mode
"Maxine" 2007 Silverado CCSB LT3, LBZ/alli, CTS, PYO's and 265 Hankooks, EFI, MBRP, PPE stuff, bilstien 5100,
"Rusty Bullet" 2007 Classic CCSB, 1 LT, Greystone 4X4, Cognito, EFI, tuned by McRat/Neens, DSP by Mike Meyer, PPE stuff, Autometer, Trippin, Airdog, MBRP, Bilstein, Hankook, TransGo Jr SOLD 437 hp 1051tq STOCK TRANS
"Tow Pig" 2003 LB7/Alli EC/LB 2x4 4" straight, cts, EFI, SOLD
"Squirel" 2000 Chevy Silvy 1500 RC/SB 5 speed 4.8 little screamer back to stock, had polished 243's ls6 intake cam and valve train
"Great White Hope" 2013 silverado 1500 z71 CCSB loaded Corsa Exhaust, gmpp intake, leveled, 5.3 HO
"White Power"-2012 GMC Sierra, White on tan leather, CCLB Dually, 4x4 LML Alli, All stock
  #3
Old 12-02-2010, 02:28 PM
coker6303's Avatar
coker6303 coker6303 is offline
Keep Calm and Chive On!!
Default
I have used Mobil 1 and Amsoil both in my duramax and just recently switched back to Rotella 15w-40 for the fact that you can't get better protection for the price. I had been running my oil change intervals at 10000 miles with the synthetics (changing the filter at 5000 and oil/filter at 10000). It is more cost effective for me to use Rotella and change oil/filter at every 5000 miles. I know it works and I don't have the added stress of pushing my oil changes. Its a price and comfort level for me.
By the way, on the LMM, what is considered low pressure at idle and say 2000 rpm???
__________________
Russ
2017 Ford F250 (I know I know...)
  #4
Old 12-02-2010, 02:37 PM
Diesel power Diesel power is offline
Default
Thats all i run, no issue's, Trashed bearings How? Flaking is not oil related, nore is debris issue's....Sounds like the engine has other issue's.
  #5
Old 12-02-2010, 03:33 PM
JMK777's Avatar
JMK777 JMK777 is offline
16's, but i keep em clean
Default
I have ran amsoil, mobil 1 and redline. I like redline the best and change it every 15-20k.
how much has the psi decreased?
__________________
2001 lb7, suncoast IV-1057 by Inglewood, JMK hidden traction bars and bump stop relocate kit, JMK S/S tie rod sleeves,QA1's, modded waste gate, EFI live ,JMK stinger exhaust, Aeromotive tsunami fuel pump , stock charger 12.71 @ 107mph
2005 lly ccsb 4x4 white all stock with a small tune.soo fresh and soo clean clean
2002 lb7 ecsb 4x4 white needs injectors and fix trans
sheet metal workers local 104
  #6
Old 12-02-2010, 03:36 PM
Righteyeblind's Avatar
Righteyeblind Righteyeblind is offline
Default
I just built a transmission that had amsoil ran in it. When I pulled off the pan it looked like I was looking at the bottom end of a diesel engine. Extremely black. The clutches were excellent no burn marks or anything. It had 70k on it.
__________________
"Pepper" 02 CCSB
Tuned by Tony
Carillos, stock LB7 pistons, head/main studs, Socal springs
GMAX 5 with 1055 converter
Garrett TV8403(GT55/47 hybrid)/ITS 74mm BB compounds
FASS 260 pump
ATS Dual Fuelers
Kennedy Diesel 40 over sticks
THANKS to Albert (BurnDown)<<<BIG HELP!!
  #7
Old 12-02-2010, 04:46 PM
duratothemax's Avatar
duratothemax duratothemax is offline
<--- slippery roads
Default
but all 2 billion amsoil dealers swear by it and plaster it up all over the web like a never-ending infomercial....I thought that meant it was good?
__________________
2012 Denali - R&D testbed for upcoming new products.....
2005 Silverado LT - Blown up/broken too many engines and parts to care about making it fast anymore, so its back to mostly stock - The best names in the industry for parts/advice/help...MikeL.Guy-SoCal.Rob-ATP.Evan-Limitless.McRat.BigDipper.Bobo.Tony-RRDP.Fingers.Eric-MA.EFILive...
BT DieselWorks, LLC - EFILive tuning - Duramax/Allison/gasser STANDALONE HARNESSES - Allison lockup controllers - Allison tapshift kits - Digital DSP-5 switches - full assortment of great electronic improvements and gadgets for your GM truck/SUV
All products available for sale through our online store at www.btdieselworks.com
Be sure to "like" us on Facebook at www.facebook.com/BTDWorks
Be sure to "follow" us on Instagram @btdieselworks
  #8
Old 12-02-2010, 04:55 PM
8100 Power 8100 Power is offline
FNG
Default
Quote:
X2
__________________
Jeff
SOLD
06 LBZ
11 LML
  #9
Old 12-02-2010, 05:00 PM
paint94979's Avatar
paint94979 paint94979 is offline
Beer Nazi
Default
I have ran amsoil 15w/40 hd marine synthetic for about 23,000 I change every 5,000 miles. You guys that actually listen too how your engines sound between different oils LOL
__________________
LLY's are COOL
HUGE Thanks to Chris, Mike L., McRat Racing, Total Performance Diesel, PPE, Trent, Wicked Diesel, Mike, Henry of Creatures of the Night, Exergy Engineering and the rest of Team Salad<--My Tailgate's Always open for all of you!!
11.84 @ 115
Tailgate Crew Member #2
  #10
Old 12-02-2010, 05:05 PM
sparepartsracing's Avatar
sparepartsracing sparepartsracing is offline
spareparts offroad&fab
Default
rotella 15w40 in everything i own from trucks, payloaders, atv's and boats
__________________
2006 lbz ccsb pretty stock
leveled w/22" novakanes, led lights, aux fuel tank/toolbox
  #11
Old 12-02-2010, 05:16 PM
S Phinney's Avatar
S Phinney S Phinney is offline
Default
I have been.running amsoil forty plus k and havent had any issues. Its not likely your problems came from the oil.
__________________
03 GMC 4x4 CC/SB Intake, Dual Exhaust, built motor by Me, Cognito Kryptonite Suspension upgrades, Custom Traction Bars by Me, Suncoast Trans, 1055-1 Convertor, Two AirDog II 200's, Billet Sump, Venom Tuning AKA Me, Custom Fabbed Fuel system, Flexlite Fans, Best Time to date 7.14 at 98.21 mph 1211.8HP 1954.5 FT/Lb torque
2013 LML Daily Driver, 5" FloPro Exhaust, Venom Tuning, Ad 165 4G Lift Pump, Upcoming HSP Billet Bridge And Piping, Upcoming CP3 Conversion
  #12
Old 12-02-2010, 05:23 PM
drewkeen drewkeen is offline
Default
I run Valvoline Premium blue in all my diesel trucks. I wait until Oreilly has a good sale on it and buy 10 cases or so. I change it every 5k. There is no point in running a synthetic if you change it every 5k.
  #13
Old 12-02-2010, 05:26 PM
Iceman56's Avatar
Iceman56 Iceman56 is offline
Default
I ran it for awhile... I was always pushing oil past my turbos when running all out. there would be a ton of oil in the boost tubes. Switched back to good ol 50 plus JD and don't have that problem anymore
__________________
11 White Denali CCSB
20X9 BMF Novakanes/285 BFG's
  #14
Old 12-02-2010, 05:30 PM
Default
Quote:
good to hear im not the only anal one who changes their air filter/fuel/tranny spin on and oil every 5k!
__________________
  #15
Old 12-02-2010, 05:31 PM
TeaBagger2006's Avatar
TeaBagger2006 TeaBagger2006 is offline
Im a Garrett Nut Swinger
Default
ive been running delo400 for 135k with 6k intervals. nevr had a problem . construction company i worked for a while back used it in everything and swore by it( plus its cheap) so i gave it a try a never looked back. i use mobil 1 oil filters
__________________
Joe
Loosest Tailgater in USA
2006 GMC 3500 D/A LBZ SRW CC/LB SLT 4x4
8" Fabtech lift 37x13.5/20 tires....Mike L trans....some go fast goodies
13.20@106mph
'06 Jetta TDI
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vB.Sponsors
