  #856
Old 01-08-2019, 06:58 PM
cdbright's Avatar
cdbright cdbright is offline
JUST RENT IT
i need to see this girl throwing roosters
2016 GMC Denali 2500 4x4 CC/SB LML- 6" Rough Country lift w 20" XDs, EFI, Deleted , 5" straight, 3" DP, S&B
2015 GMC Denali 2500 4X4 CC/SB LML - (STOLEN)
2009 Chev 2500 LMM (TRADED) EFI, all deleted, rode just as hard as her !!!, stayed together
2008 GMC 2500 LMM (SOLD)
EFI,all deleted,rode hard,stayed together
  #857
Old 01-11-2019, 01:13 AM
kidturbo's Avatar
kidturbo kidturbo is offline
Piston Tester
Just wrapping up the sanding on first piston set. Haven't started the final polishing yet.
Going from a sand blasted surface to somewhat shiny (1500) takes about 45 minutes per piston with a low speed dremel tool. Did I mention I dislike coatings??
Rings arrived yesterday, so need to grind all those gaps down again. Then I'm within about 8hrs of where I was end of November..
Sent from my SAMSUNG-SM-G890A using Tapatalk
  #858
Old 01-11-2019, 08:22 AM
DAVe3283's Avatar
DAVe3283 DAVe3283 is offline
Well, they look good at least!
  #859
Old 01-11-2019, 08:31 AM
Chevy1925's Avatar
i mean, worse case you can make a really cool table or lamp with them
Just out of curiosity, did you measure bore dia, taper and out-of-round before and after the quick hone? curious if there was any distortion in the little run time and if the ball hone took any out, added any or opened the bore any.
James
best time to date: 12.39
Tailgate Crew Member #4
  #860
Old 01-11-2019, 09:43 AM
kidturbo's Avatar
Piston Tester
We checked for outa round before and didn't notice any measurable difference. Then literally made 3 - 8 strokes with the bead hone just to knock that glaze off in a few spots.
  #861
Old 01-18-2019, 08:59 PM
kidturbo's Avatar
Piston Tester
So as not to completely scrap all the twins 316 stainless, and hours of labor in the last set of up pipes, decided modify them into a 3 piece Y pipe / turbo mount. After a whole day of fitting and welding, discovered the turbo outlet tube is gonna clash with charge cooler cover. Mock up twice, measured 3 times, and dang thing still doesn't fit how I want....
  #862
Old 01-19-2019, 07:57 AM
PureHybrid's Avatar
Isuzu Shakes IT
That rectangle part is the manifold inlet?
8.17@84mph 1/8mi
Jesse
  #863
Old 01-19-2019, 12:26 PM
kidturbo's Avatar
Piston Tester
Yeah in the bottom. And trying stuff a 75mm throttle body in between as a emergency air shutoff.
  #864
Old 01-23-2019, 09:39 AM
kidturbo's Avatar
Piston Tester
Getting closer.. Engine 1 pipes are tacked up and turbo in final position. Now to jacket these pipes and start on set 2.
  #865
Old 01-23-2019, 10:14 AM
kidturbo's Avatar
Piston Tester
Hood Stack It?
  #866
Old 01-23-2019, 01:02 PM
Chevy1925's Avatar
Originally Posted by kidturbo View Post
Hood Stack It?
Brooooooo
James
  #867
Old 01-23-2019, 04:23 PM
cdbright's Avatar
JUST RENT IT
stop teasing !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  #868
Old 01-23-2019, 05:58 PM
Pure Diesel's Avatar
Pure Diesel Pure Diesel is offline
Randsburg Drifter
White GMC 2003 2500HD D/A SLE/CC/SB 4x4] Bilstein 5100~Air bags~Autometer Gauges~33 BFG's~MBRP 4" Exhaust~SD tie rod sleeves~Cognito Braces~Kryptonite upper control arms DMAXSTORE XD TIE RODS~PPE high flow pick up~Fass 95 pump~Titan 52-gal.~Prodigy~New tranny 02/12/2015 Mike L. "Baby Frankenstein " w/Goerend converter w/ Mike L. tranny cooler and pump rub fix~6 speed tap shifter~Siege Engineering Anvil train horns(Very Loud)~LED headlights Hi/Lo
New injectors as of 03/12/2010 @ 80k miles
Injectors started going again at 115k. 07/01/2013
06LBZ engine transplant from Russ @ RPM Motorsports~No more Lb7 injectors to replace
  #869
Old 01-23-2019, 10:34 PM
kidturbo's Avatar
Piston Tester
How about this one. After ya get everything tacked up and looking perfect, ya gotta cut it all apart and start fitting the outer tubes..
Hope it all lines up again when welded together for the second time.. lol
  #870
Old 01-24-2019, 06:52 AM
gmc502 gmc502 is offline
doing an awesome job.
2002 GMC 2500HD, ECSB, 4WD, LB7,300k miles and still truckin
new style gm exhaust manifold, banks big head wastegate, PPE boost valve, banks air intake,high idle switch in cruise control, stock but not for long
EFI live tuned byMe now,dps5 switch,EGT probe and autometer boost sensor,SoCal 6spd conversion
