  #16
Old 12-03-2010, 12:42 AM
DAVe3283's Avatar
DAVe3283 DAVe3283 is offline
Originally Posted by Whitetail Addict View Post
I called Mike thinking he sold the fix, and he said no he did not. He sent me in the right direction though.
Do you mind sharing that direction?
Originally Posted by stacks04 View Post
I have had good luck with the jb weld epoxy after getting things real clean and then using the pump rub kits. The only one I have ever installed it the kd one.
I managed to stop the leak with a liberal smearing of RTV. After installing the fix, I think I may just JB weld (or other epoxy) it, since there doesn't appear to be much pressure on it.
  #17
Old 12-03-2010, 01:16 AM
JoshH's Avatar
JoshH JoshH is offline
I'm not sure what Mike recommends, but of all the fixes I've seen, I really like the kit that Sonnax sells. This thread reminds me that I need to get this taken care of on my truck before it becomes an issue.
http://www.sonnax.com/announcements/100246-02K.pdf
06 Silverado 4x4 CC/SB
  #18
Old 12-04-2010, 08:35 PM
DAVe3283's Avatar
That looks like it would work just fine, but for the life of me, I can't find any prices for that kit.
Where would you buy it?
  #19
Old 12-04-2010, 09:30 PM
ripmf666's Avatar
ripmf666 ripmf666 is offline
Mike should be able to get them for you. I am on my way back to MD this week and the I can get Sonnax parts.
Name to come
2013 GMC Denali HD 2500 ccsb,100%stock,spray liner,B&W
Sold but not forgotten
Devil Girl 2006 2500HD LBZ Ex-Cab 4x4
11.53 @ 116.92 1.66 60's
  #20
Old 10-16-2018, 01:59 PM
Capit21 Capit21 is offline
FNG
Default My quick fix
So I had the pump rub issue about 1 year ago, I was desperate for a quick fix, so I grabbed the red permatex rtv, I found the small pen hole, made it a little bigger and sqeezed some in their directly from the tube. It has been in a year and no issues yet. I do plan on rebuilding this eventually.
  #21
Old 10-16-2018, 10:49 PM
DAVe3283's Avatar
So, that's an 8 year necro-post, but what the heck, I'll join the fun!
Coincidentally about 8 years ago, I had a pump rub pinhole, and slapped some RTV on. Eventually got the pump rub kit, but i never replaced the case half. So that RTV is holding back the leak almost a decade later.
Now I wonder if I should've skimmed the thread, this could be totally off topic. Eh, not like anyone will care after 8 years, I bet.
Edit: oh dang, I was posting how I smeared RTV on 5 posts up! So yeah, follow up: it still doesn't leak
  #22
Old 10-17-2018, 03:40 AM
duramax on fire's Avatar
duramax on fire duramax on fire is offline
I'll add to this. JB weld for me. Lasted 3 years until the pump started rubbing another hole in a different spot. Then I had it fixed with a newer half.
  #23
Old 10-17-2018, 07:35 PM
Budneeds2beers's Avatar
Budneeds2beers Budneeds2beers is offline
Aka Mike Honcho....
It is weld able. Ive done my tahoe and my dads 263. Turn the gas up high and it can be done. To grind it clean use a course cutter and go slow. It really isnt hard welds just like aluminum. I would say wile you have it out replace the “wear” parts and clean the pickup tube strainer.
  #24
Old 10-17-2018, 07:57 PM
Mike L.'s Avatar
Mike L. Mike L. is offline
If you have a hole in the housing, you have nasty gouges on the inside. Usually The snap ring groove is wasted. You need a new housing.
Inglewood Transmission Service
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #25
Old 10-18-2018, 11:38 PM
THEFERMANATOR's Avatar
LEGALLY INSANE
My cajones aint big enough to dare even THINK of welding on magnesium. Permatex makes some out of this world strong aluminum epoxy stick, but it said in bold print not to use with any magnesium alloy. I also have duraweld torch filler rods, but the test it gave to see if it had enough aluminum in it to stick and mix in failed. I lucked out and picked up my 261 case out of a wrecked 03 that had almost 300k miles for $650. I got there and the date stamp on it was from 06 so it wasn't the origanal case for the truck. Got it home, pulled it apart, and it looked new inside.
