Old 06-19-2018, 07:22 AM
Columbus450's Avatar
Columbus450 Columbus450 is offline
Default Pics of 20x10 -24 offset
Going to order some new 33s 12.5 20s and they only have the 20 x 10 wheel in -24 offset curious how far these wheels are going to stick out ive searched but I can't find any pictures with the same offset and I'm hoping they don't stick out too far
Thanks 06 Gmc LBZ
Old 06-19-2018, 08:02 AM
cmckillip cmckillip is offline
FNG
I had some 20x10s with -18 offset and they barely stuck out. I ended up adding 2 inch wheels spacers.
2007 lbz cc/lb
4in straight pipe
Afe intake
EFI live dsp 5
Old 06-19-2018, 08:05 AM
c5fourj's Avatar
c5fourj c5fourj is offline
Occasionally moving quick
305 50 20s. No spacers in the rear. Need some...
2006 GMC cc/sb
HSP s366sxe, w/ ppe up pipes, AFE intercooler,
5" FLOW PRO, fass 150, 72" trac bars
Overloads pulled, 2" drop shackles, torsion key bolts pulled, on 285/55/20
All Rare Parts front end, DHD brace
EFI live and built trans by Diesel Day Dreams
Old 06-19-2018, 08:11 AM
Madspeed's Avatar
Madspeed Madspeed is offline
Fat Bastard
Why would one want them to stick out? looks like a roller skate. I guess it goes with lowered pants and a hat pulled down to ones neck =/ Ya know in prison they wear their pants down to let others know they want to get plowed
71 2WD 4X4 1ton conversion, LB7 TT SCV and some other shit/ OOPs I found a suburban to melt into the pickup and make a CC longbed 71 4x4. back under the knife for the 71
2007 Suburban LBZ/LMM Lifted and shit. Pile of Shit mounting... Fingers ovals, Socal Stage 2 cam, Socal stage 1 heads, SoCal billet mains, ats damper, 480SXE, PPE dual fueler, ARP studs top to bottom,
Old 06-19-2018, 08:15 AM
zakkb787's Avatar
zakkb787 zakkb787 is offline
<thatís not me...
To each their own. I enjoy the “stance” look. I’m 22. Well groomed. Try to be respectful to those who will return the thought. And yes I wear a belt. I can’t atand skinny wheels and giant tires. I can’t stand overly stretched tires either.
OP check out custom offsets website. There’s hundreds of trucks posted there in the same setup you’re looking at.
2006 LLY CC/SB LT3 mostly stock
Other toys:
1982 K10 6.2 Detroit diesel/sm465/np205 with 4 inch lift and 35s. Fixed and driving again
2011 Yamaha YFZ450X
2003 Yamaha YZ250
2003 Kawasaki Z1000
Old 06-19-2018, 08:27 AM
FNG
Originally Posted by zakkb787 View Post
To each their own. I enjoy the ďstanceĒ look. Iím 22. Well groomed. Try to be respectful to those who will return the thought. And yes I wear a belt. I canít atand skinny wheels and giant tires. I canít stand overly stretched tires either.
OP check out custom offsets website. Thereís hundreds of trucks posted there in the same setup youíre looking at.
I agree. I really like the stance look my self.
2007 lbz cc/lb
4in straight pipe
Afe intake
EFI live dsp 5
Old 06-19-2018, 09:09 AM
boostwhore's Avatar
boostwhore boostwhore is offline
Drag racer wannabe
20x10 -24 with 1.5” spacers in the back.
Chad
2007 lmm: kryptonite front end, full billet trans by Sdp, SoCal engine ovals and Carrillos, 12mm exergy stroker, 100 over exergy injectors, sdp billet 68mm over billet 480, awesome tuning from Aaron at All in trucks.
Best 1/4 to date: 11.06 at 127 in the chase for 10ís.
Old 06-19-2018, 10:01 AM
Thanks for the pics guys and Zack thanks for the website after looking at the pictures on site I figured I'd rather go -12 offsetstill will stick out just a little bit but not too bad
  #9
Old 06-19-2018, 10:30 AM
zakkb787's Avatar
<thatís not me...
Not a problem amigo
Other toys:
2011 Yamaha YFZ450X
2003 Yamaha YZ250
2003 Kawasaki Z1000
  #10
Old 06-20-2018, 05:44 AM
NC-smokinlmm's Avatar
<<<Future tuna killer
I'm not a huge fan, I thnk they look ok, I'd just hate to keep the wheel bearings and front end together...
2010 GMC 1500 SCSB Denali Clone < lifted 22's/33's, Kooks, Magnaflow, 5.3, 6l80, TVS1900, lots of boost, Mayhem tuned, etc... <<<<Broken Under Construction : BTR boost cam, sodium valves, titanium springs, 15% overdriven balancer, 80lb squirters>>>>
1969 MGB GT MKII Factory Condition
  #11
Old 06-20-2018, 06:00 AM
FNG
Every one says that but Iíve never had a front end or wheel bearing problem...
2007 lbz cc/lb
4in straight pipe
Afe intake
EFI live dsp 5
  #12
Old 06-20-2018, 06:54 AM
After lots of research I'm going with 20 x 10 fuel hostages. -12 offset
wrapped with Nitto ridge grappler's 305x55-20 should give it a sweet stance
  #13
Old 08-07-2018, 04:30 AM
DMAXDFloridian DMAXDFloridian is offline
FNG
Should be a nice stance without to much paint chipping from road debris.
  #14
Old 08-08-2018, 04:16 PM
