Old 03-18-2020, 10:37 PM
tenderdurden's Avatar
tenderdurden tenderdurden is offline
FNG
Default Advice for LLY Head Gasket replacement
I'll try to keep this short. I do a lot of work with addicts in recovery, and because of helping a family get their kid into rehab, they gave me this 2005 LLY for WAY less than it's worth. However, it does need to have the head gaskets replaced.
The truck still ran with great power before I started on this (except spitting out all the coolant.) It has had over $6,500 in maintenance done in 2019, new transfer case, new transmission, $1,500 in new tires, and it has clearly been well-loved in the past. I'd rather not spend $6,000 to get the heads done at the shop. I've spent DAYS researching and watching how it is done. If I do put extra money in, I'd rather learn about my truck and have a decent tool set to show for the expense.
Can someone who has only replaced fuel pumps, alternators, and other basics tackle a head gasket job on an LLY or will I make it all worse? Do I add the EGR block while I'm at it? How about the turbo intake that I've heard are bad on these LLY's? It has a Bully Dog performance system, so should I do studs? Here's how far I've gotten:
2005 Sierra 2500HD - First Duramax - YOU know more about this truck than I do... but with your help we can fix that.
Old 03-19-2020, 05:25 AM
Bdsankey's Avatar
Bdsankey Bdsankey is offline
If you take your time and understand it won't be a 2 day job then I think you can tackle it. Don't rush, don't skip any steps etc and you should be fine if you are pretty decent at turning wrenches. As for parts, you will need all the same parts either way, what changes is if you decided to do studs/egr while you're in there.
You need grade c head gaskets (you could use a different thickness based of protrusion but the grade C is a little easier as it will work on any factory block that hasn't been decked), an upper gasket kit, and head fasteners of your choice. You can either use factory torque to yield (TTY) bolts or ARP studs. The cost difference is ~$450 to get studs vs TTY bolts. You also will NEED to have the heads checked for flatness and overall health (guides/seats/etc).
My kit is ~$508 with TTY and ~$960 with ARP studs. Both prices are shipped and use only Mahle/Victor Reinz gaskets with wave stopper head gaskets as opposed to the GM gold gasket. In my opinion, an EGR delete isn't a bad idea if your state/area doesn't do testing. The early systems were failure prone and nowhere near as refined as the newer systems. My truck had a ton of gunk built up in the intake tract from the EGR and PCV when I tore it down to start the first stage of my build.
As for the mouthpiece, I would definitely replace it as they are very restrictive. You can use an S&B, AFE, HSP, WCFab, or even a factory LBZ/LMM mouthpiece with a few little changes to the factory intake. Lastly, while you're in there, I would recommend replacing the cover on the rear engine housing that seals the cooling system. Note, this is my personal opinion and not 100% mandatory but I have been bitten more than once by that cover warping and leaking so I make it a point to change every one I can while I'm that far into the job to avoid that failure again. The billet covers are ~$65 and are sealed with an o-ring as opposed to the factory flimsy stamped cover and gasket.
K&D Service Inc
Call or Text: 906-284-0962
Providing a "one-stop-shop" for all of your automotive needs!
Current Rides:
-Built Motor, Forced Inductions Billet ETR Gen 4 S480/96/1.10 T6 w/V2 Race Cover, F1 Diesel 275% Inj, Exergy 14mm Street Pump/LBZ CP3, Goerend AR Converter, Billet Trans, Fuelab Supply Pump/Reg, RCD & Beans Sumps, Front E-Locker, TrueTrac, Yukon 4340 Rear Shafts, Traction Bars, DHD Center Link Brace, DHD Lower Crossmember Support, Banks iDash 1.8 Monitoring System
-Cast S475/96/1.10 T6 Over Stock IHI, FASS 150,4" Exhaust, RCD Sump, PPE Sleeves, DHD Centerlink Brace, DHD Lower Crossmember Support, "Budget" Motor, Big Oil Cooling, Banks iDash 1.8 Monitoring System
Old 03-19-2020, 07:07 AM
Chevy1925's Avatar
Key isnt you being able to do it, its having a competent machine shop by you that knows how to check those heads for cracks, how much they can deck the head before needing to recess the valves more, and what spring seat pressure the valve springs should be checked and set to.
its all nuts and bolts for you, just take your time and take pics of how you pulled it apart. organize all the bolts in little sandwich baggies and label them where they go. wiring harness is hard to plug into the wrong stuff as they are keyed for specific plugs
James
2002 LB7, LLY, LBZ, LMM, LML, L5P 2500HD CC/LB dmax/6sp alli "The Limo"
2020 L5P 2500HD CC/LB dmax/10sp alli "The New Limo" staying stock........ish
Tailgate Crew Member #4
Old 03-19-2020, 07:18 AM
Bdsankey's Avatar
Sandwich bags are the most underrated items when it comes to repairing these trucks. It allows for easy labeling and makes it much easier to put back together instead of just grabbing from a big box of bolts.
K&D Service Inc
Current Rides:
Old 03-19-2020, 07:50 AM
jedenbeck's Avatar
jedenbeck jedenbeck is offline
FNG
I did my first set with pretty much no knowledge of what I was getting into. Anyone with mechanical ability’s can do it if they are careful and pay attention. I labeled everything I took off and parts went in bags labeled etc. it will take you a few days to do it. Clean and organized work area is a must. Most aggravating part to me was adjusting the valves back. I did everything my self I had zero help.
2006 LBZ Ccsb stock motor, limitless built trans suncoast 1055, FI 467.7/83/.90, 60% injectors, 10mm pump
Old 03-19-2020, 08:35 AM
NevadaLLY's Avatar
NevadaLLY NevadaLLY is offline
Adam B
I did this build myself as well and a few tips I recommend:
Set up a large table or two, so you can lay out all the parts. I used blue masking tape and a marker to stick on the table and write down what it was and where it came from. (Baggies got too cumbersome). Next, I used a silver sharpie to label every electrical connection and any disconnects I made. I drew the mark directly on the parts so when going back in, match 1-1, 2-2, A-A, B-B, etc. Using this method, I did the whole job and not one issue. Started in first crank and has been running perfectly the last 7 years. I also did not do anything with the heads other than clean up (very carefully) any residue or debris from the prior gasket. I installed ARP studs and I’d recommend it for an LLY. TTY are single use and if you have to get back in there later, you’ll re-spend the money on hardware.
2004.5 GMC 2500HD
LLY - Banks 4 in exhaust, cat delete, ARP head studs, Grade C gaskets, HSP Compound Turbo S475/96/1.15, Kory Willis EFI live DSP5, Air Dog 4gII 150GPH, 6" RCD lift, Mike L. Trans built, Mike L. Trans cooler, Fluidyne AUX OIL cooler, Air Lift compressor & bags, RDS 40gal AUX tank; Longhorn FAB traction bars; PPE Race manifolds (ceramic coated and wrapped) and up pipes; FLEECE performance tapshifter, CSF HD Intercooler
Plans: paint.... Suggestions???
Old 03-19-2020, 10:45 AM
Dozerboy's Avatar
Dozerboy Dozerboy is offline
Are you pulling the engine or not?
06 GMC 2500 CCSB SLT LBZ 4X4
Old 03-19-2020, 03:57 PM
NevadaLLY's Avatar
Adam B
I didn't pull the engine - wasn't that bad.
2004.5 GMC 2500HD
  #9
Old 03-25-2020, 06:19 PM
techperry techperry is offline
GM Diesel Tech
So using the wave stopper that are listed for overbore and decked blocks on everything?
05 lly built trans by me ,fass 150 ,Lbz mouth piece, 4inch exhaust
  #10
Old 03-25-2020, 06:25 PM
Bdsankey's Avatar
No. Do not get grade D gaskets for every application.
K&D Service Inc
Current Rides:
  #11
Old 03-25-2020, 06:44 PM
Chevy1925's Avatar
I suggest just picking up Grade C victor reinz or mahle gaskets. These will have a compressed thickness of .0394 to .0433 (most list them as 1.05mm thick)
All the ones I’ve gotten have been a “wave stopper”, even the A’s I have sitting in my shop right now. Even if they are not, I wouldn’t worry. They are still better than the gold acdelco
James
  #12
Old 03-26-2020, 01:06 AM
GM Diesel Tech
Ok well the only gasket that actually say wave stopper cross to the grade D part numbers.
  #13
Old 03-26-2020, 03:50 AM
Bdsankey's Avatar
Grade C wave stopper, left: 54597
Grade C wave stopper, right: 54598
K&D Service Inc
Current Rides:
