  #1
Old 08-09-2018, 06:06 PM
19jake91 19jake91 is offline
FNG
Default Brake light issues after LML hydro boost upgrade
I just installed the 2011 LML hydroboost in my 07 LBZ due to my factory one leaking. The install was straightforward but a problem I have had right away is intermittent brake lights, trailer brake controller and sometimes it will not shift out of park. All symptoms of the brake light switch not getting complete contact. Has anyone else done this swap and experienced these problems? If so, how did you fix the situation? Thanks in advance.
  #2
Old 08-09-2018, 06:16 PM
c5fourj's Avatar
c5fourj c5fourj is offline
Occasionally moving quick
Default
Did the exact same swap with no problems. You might of accidentally messed with a wire(s) in the process.
__________________
2006 GMC cc/sb
HSP s366sxe, w/ ppe up pipes, AFE intercooler,
5" FLOW PRO, fass 150, 72" trac bars
Overloads pulled, 2" drop shackles, torsion key bolts pulled, on 285/55/20
All Rare Parts front end, DHD brace
EFI live and built trans by Diesel Day Dreams
  #3
Old 08-10-2018, 06:42 AM
chevyburnout1's Avatar
chevyburnout1 chevyburnout1 is offline
Fixing it till it breaks
Default
When I swapped mine I noticed the LML booster had a smaller diameter hole where it connects to the brake pedal/mounts the brake switch. Yours may be a bit tighter than other vehicles causing the push rod to not travel far enough to contact the brake switch. Drill it slightly larger.
__________________
Dustin
'03 Silverado LB7
GT3788/CT6x88mm compounds _ 60's _ duals _ fingers _ 6480af
'77 K-10
52"/56" front/rear leaf springs and rear shackle flip: 8" lift total _ D60/14blt 4:56s _ 40" Swamper IROK's _ 383 w/nitrous _ SM465 _ 208tcase
'97 Cadillac Deville
Morimoto Mini 5000k projector headlight conversion _ 500watts in the trunk _ 20's _ Flowmasters _ Tuned ECM _ Rear mount turbo in the works....
  #4
Old 08-10-2018, 07:05 AM
JoshH's Avatar
JoshH JoshH is offline
Default
Quote:
What he said is correct. You need to drill the hole out on the booster rod where it goes onto the pedal with a 41/64" drill bit. The first one I did (on my truck), I used a step bit and drilled it out to 11/16" which worked, but 41/64" is almost exactly the same size as the factory booster.
__________________
06 Silverado 4x4 CC/SB
06 Express 2500 Duramax Van "The Dumpster"
  #5
Old 08-10-2018, 09:48 AM
FNG
Default
Quote:
Thanks for the info. Iíll borrow a drill bit from work and hopefully Iíll have the same problem you guys did as well.
  #6
Old 08-10-2018, 10:44 AM
CarolinaHD CarolinaHD is online now
Default
Good info this should be added to the other hydroboost thread. I hope I don't have this issue, really don't wanna remove it again.
__________________
Alex
LBZ CCSB 4x4
EFI Live
RDL Y-bridge
166,000 miles
Sold
2003 C&C lb7/zf6
276,000 miles
LBZ/ZF6/4x4 Conversion
  #7
Old 08-10-2018, 11:39 AM
JoshH's Avatar
Default
Quote:
You don't have to remove it. Just unhook the rod from the brake pedal and hold it with a pair of vice grips. It can be drilled in the truck.
__________________
  #8
Old 08-10-2018, 01:27 PM
Default
Good call, I love this forum.
__________________
Alex
LBZ CCSB 4x4
EFI Live
RDL Y-bridge
166,000 miles
Sold
2003 C&C lb7/zf6
276,000 miles
  #9
Old 08-10-2018, 07:36 PM
FNG
Default
Thanks for the great info JoshH. I was able to drill out the rod to a 21/32Ē(closest size I had readily available) with it still in the truck and the brake light problem is fixed. I would definitely recommend drilling out the new rod before it is installed.
As for the swap, I am happy with the improvement in braking. Iím not sure if it was because of the new design or just because my old one was leaking.
Either way, thanks again for the great info and time saved!
  #10
Old 08-11-2018, 04:25 AM
NC-smokinlmm's Avatar
NC-smokinlmm NC-smokinlmm is offline
<<<Future tuna killer
Default
I need to do this to my regular cab so it stops better...
__________________
2010 GMC 1500 RCSB Denali Clone < lifted 22's/33's, Kooks, Magnaflow, 5.3, 6l80, TVS1900 @ 15#'s, BTR top end and boost cam, Trunion upgrade, 90mm, 10% over, 2.8 griptec, 65lb sticks, Mayhem built/tuned.
2016 LML CCSB Denali < Lifted 22's/35's, Fox 2.0 < I officially need help.
  #11
Old 08-11-2018, 08:22 AM
FNG
Default
I know the info is out there but just to confirm other posts, I went with GM part number 178-0853. It was less than $200 to my door with no core charge.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vB.Sponsors
