  #5956
Old 10-18-2018, 10:55 AM
ironmax's Avatar
ironmax ironmax is online now
chock full of goodies
Default
I was definitely past 7500, but I try not to load the tongue down. Not the first one I've ripped off either
Sent from my SM-J337A using Tapatalk
__________________
air intake
Genuine tornados
4inch turbo back exhaust
bosh remans from lincoln diesel, @290k
fass 150
19.5 american eagle alloys
cognito upper a-arms
Quote:
Your freedom to be you,includes my freedom to be free from you....
  #5957
Old 10-18-2018, 11:02 AM
ChrisPerry's Avatar
ChrisPerry ChrisPerry is offline
Default
You didn't upgrade to a class v or better after the 1st one failed? Or was it on a different truck?
__________________
02 GMC 2500HD, EC/LB, LB7, 2wd, 6" lift, 35" tires. ds LML manifold, PPE level 10, boost valve, race plug, Airdog 165 lift pump, CAT filter mod, mechanical egt and boost gauges, SB intake, high flow turbo horn, ported turbo exhaust housing, kbd drop in wheel, Banks Bighead wastegate, egr blocked, intake heater delete, PPE downpipe, 5 " exhaust w/ cat delete, Mike L built trans w/ Goerend R converter. Levi's heat blankets
7-6-17...New headgaskets, studs, Fed heads, and LDS replacement injectors @ 202,239 Miles
  #5958
Old 10-18-2018, 11:27 AM
Dozerboy's Avatar
Dozerboy Dozerboy is offline
Default
Quote:
Originally Posted by ChrisPerry View Post
The factory tow package is rated at 7500 pounds towing and 1000 tongue weight. Its a wonder why they hold up at much as they do with how most people use them.
I upgraded tk a Curt class v a few years back after seeing one fail at the worst possible moment. Totalled the truck, trailer, and offroad rig he was towing. I heard later that the insurance company denied the claim because he was loaded past the receivers rating.
Are you sure about that I swear they were rated for at least 10,000 pounds?
__________________
06 GMC 2500 CCSB SLT LBZ 4X4
These views expressed on this post are not my own, but rather randomly generated computer gibberish, and in no way should be used to judge the author's IQ or mental health.
  #5959
Old 10-18-2018, 11:40 AM
ironmax's Avatar
Default
Diffrent truck
__________________
air intake
Genuine tornados
fass 150
  #5960
Old 10-18-2018, 11:45 AM
ironmax's Avatar
Default
Here is what the hitch says
__________________
air intake
Genuine tornados
fass 150
  #5961
Old 10-18-2018, 12:39 PM
ChrisPerry's Avatar
Default
I thought so too until I actually read the tag. Still can't believe the hitch is so light weight. I pulled around 12-13000 a few times locally before I knew better. Now that I have a class v, never more than 8000. Go figure.
__________________
  #5962
Old 10-18-2018, 04:10 PM
NC-smokinlmm's Avatar
NC-smokinlmm NC-smokinlmm is offline
<<<Future tuna killer
Default
They stepped it up on the newer trucks, have to use an insert to use 2" receiver...
__________________
2010 GMC 1500 RCSB Denali Clone < lifted 22's/33's/ Kooks / Magnaflow / 5.3 / 6l80E / TVS1900 @ 14#'s / BTR Top End / Boosted Bump Stick / Trunion upgrade / 90mm / 10% over / 2.8 griptec / 105 lb ID's / Mayhem built/tuned.
2016 LML CCSB Denali < Lifted 22's/35's, Fox 2.0 < I officially need help.
  #5963
Old 11-07-2018, 09:48 PM
Chevy1925's Avatar
Chevy1925 Chevy1925 is offline
Default
Put a new FPR in. Ahh there is the nice quiet idle. Glad it was the easy one on the second pump. Also swapped my heater hose from the upper rad hose back to the water pump bypass so I have heat in the morning. Its a freezing 55-60* out here
And momma is gone for the week for a school trip so I took over the garage.
And a little daddy daughter time mixed in
__________________
Quote:
Originally Posted by JoshH View Post
Mike L is my role model. I want to be like him when I grow up.
James
02 LB7, LLY, LBZ, LMM, LML, L5P 2500HD CC/LB dmax/alli "The Limo"
BIG THANKS TO: Mike L, Steve, Trent, Guy, Dan, Ruben, Josh H, Scott, Brian and everyone else who has put a hand in to help me.
best time to date: 12.39
motor died/bent rods = 3/11/11
back from the dead 7:04pm 4/9/2012
Limo is back in the garage, now driving a built chevy tracker
Tailgate Crew Member #4
  #5964
Old 11-08-2018, 06:43 AM
DAVe3283's Avatar
DAVe3283 DAVe3283 is offline
Default
Haven't been able to hurt this hitch yet. It goes 6" farther into the frame than stock, and ties into my lift gate for additional strength.
My dad had a trailer rip off his Dodge stock hitch and go through a fence. He keeps putting stock hitches back on for some reason. I learned the lesson for him, and run this custom hitch.
Sent from my Cat S60 using Tapatalk
__________________
  #5965
Old 12-20-2018, 07:07 AM
Hambone's Avatar
Hambone Hambone is offline
Always learning
Default
Rotating tires and noticed the stock hub cap nuts were lose on the lug nut...
Lil electric tape fixed that problem!
__________________
2017 2500 CC/LB "L5P" WT
2005 2500 CC/SB "LLY" LTZ
Typical mods for Longevity
awaiting stuff to go BooM then replace with more go fast parts!
And a few other retired Duramax's
06 360k aka Hog truck
07 320k aka Shop truck
07 340k Flatbed spare welding rig
  #5966
Old 12-23-2018, 08:00 AM
lts1ow's Avatar
lts1ow lts1ow is offline
Needs moar PAH!
Default
Took truck for a alignment while back and along with a $1200 estimate, they said all tie rods are bad and RH upper ball joint is shot.
So, Rockauto to the rescue
I should have done this a long time ago, old parts are shoooot
__________________
2005 LLY: AFE Bladerunner, MBRP downpipe, sewer pipe exhaust, PPE tuner, !EGR
1995 Z28: 76mm, 383ci LTwon, 80e 660hp/750ft-lb 10.2@140
2014 CTD Stock
  #5967
Old 12-23-2018, 03:37 PM
frankenstien's Avatar
frankenstien frankenstien is offline
Default
Finished making a new lighter bumper, front end parts should be much happier now. still have to mount my light bar to it
finally got my new wheels and tires on, hopefully get this fuel leek whooped and she will be good to go
__________________
2005 ECSB LLY
Danville Tuned
S&S LBZ SS Cp3
5'' exhuast
Fass 150
Built Trans w/SC1058
Bumpers built by me
  #5968
Old 12-23-2018, 09:06 PM
Burn Down's Avatar
Burn Down Burn Down is offline
Default
Looks good Mike. Hows the winter been?
__________________
04.5 CCSB ole blue, built trans, mpi twins
03 Reg Cab ZF 6
05 CCSB ole crappy, built eng, built trans, mpi twins
  #5969
Old 12-23-2018, 09:26 PM
lutzjk913's Avatar
lutzjk913 lutzjk913 is offline
Default
Picked up my LMM from the body shop. Got a freshly painted lml front bumper swap done to it.
__________________
Joe
2008 CCLB LT2 DURAMAX LMM
13.44 @ 98.69
456HP 925 TQ
2003 Regular Cab LB7
  #5970
Old 12-23-2018, 10:34 PM
Default
Quote:
Thanks
pretty good so far, not a lot of snow, weather has been mild, i think we had one day of -20F, but other than that coldest is in the 10-15 below at night, currently 5 below at work
__________________
2005 ECSB LLY
Danville Tuned
S&S LBZ SS Cp3
5'' exhuast
Fass 150
Bumpers built by me
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vB.Sponsors
