Old 05-24-2019, 05:59 AM
briencolgan briencolgan is offline
brien colgan
Default Home heating oil gaff
I did something brilliant with my 03 duramax. I came across 300 gallons of free diesel in a metal tank. And I put it all in the truck . And things were good until the last 40 gallon fill.
I watched the fuel turn black going in and thought to myself this is a bad idea. And predictably Iím chewing through filters every 50 miles.
Iím probably on filter 6. (I get just over 200 miles per fill up) I was figuring eventually after enough filters, the problem would go away. On this particular truck dropping tanks is doable but a pita due to an aftermarket box thatís welded on.
Am I gonna have to just suck it up and remove the tanks or do you think after enough filter changes the sludge in the tank will be eliminated.
Iíd rather spend another couple hundred on filters versus dropping the tanks.
2003 6.6 LBZ stock with spartan supreme service body
Old 05-24-2019, 06:37 AM
Burn Down's Avatar
I’d wait until it needs a pump and injectors
Albert
04.5í CCSB ole blue, built trans, mpi twins, 12.5X @ 108
99' Reg Cab, 1500 2wd, Turbo or Procharged 6.0, 4L80E build inprogress
05í CCSB Millennium Falcon, built eng, built trans, mpi twins, 11.51 @ 119 1.59 60í
84' Reg Cab SB, 415 BBC, 4-speed, needs a D-max zf6 swap
Old 05-24-2019, 06:53 AM
TheBac's Avatar
TheBac TheBac is offline
Moved to Fluids and Maintenance, b/c after using that fluid, you're going to be doing a lot of maintenance....
Tom
Old 05-24-2019, 07:22 AM
AZlml's Avatar
AZlml AZlml is offline
Even after seeing it turn black you kept going? And after the first filter change at 50 miles you still kept going?? Free "fuel" is not free if you cause thousands in damage...
Bryan
11 CCSB 4x4
EFI by Ridgerunner, 5" FloPro, Profab manifolds and up pipes, Wehrli cp3 conversion, 3" downpipe, S&B intake, AD165 4G, DHD tie rod sleeves, 2" rear drop shackles, Rancho RS9000XL
67 C10 LS 6.0 swap and frame off build in progress
Old 05-24-2019, 08:10 AM
brien colgan
I figure the filter is doing its job. Thatís why. Am I missing something? Can impurities get past the filter?
Old 05-24-2019, 09:32 AM
Burn Down's Avatar
No fuel filters catch everything...
Albert
Old 05-24-2019, 09:43 AM
DMAX Slim's Avatar
DMAX Slim DMAX Slim is offline
Collywobbler
When do you think I should change mine? Or does mine even have one?
2003 CC/SB LB7 "The Ole Heifer"
1056-Suncoast internals
Built by SMR Diesel Performance
2003 Toyota Double Cab 4WD V6 D.D.
Jesus Is The Only Way!
2002 RC/LB LB7~~Sold~~
Old 05-24-2019, 10:50 AM
2004LB7's Avatar
2004LB7 2004LB7 is offline
Filters catch a percentage of particles based on their micron rating and efficiency. So some will get past the filter. How much? Depends on the filters you are running. The more junk in the fuel the more will make it to the pump and injectors
I would drop the tank and clean it out fast. LB7s are the least tolerant of bad fuel. You can trash a good set of injectors in a few miles like that
2008 Chevrolet 3500HD DRW LTZ
  #9
Old 05-24-2019, 11:14 AM
brien colgan
Thanks 2004LB7. Thatís what I was looking for. I appreciate it.
  #10
Old 05-24-2019, 01:12 PM
gmduramax's Avatar
Shits broke
Iíd wait until it needs a pump and injectors
waiting for the white smoke thread
10.98@124mph
Tailgate Crew Member #1
