  #1
Old 03-12-2017, 09:47 AM
Subman's Avatar
Subman Subman is offline
Old Geezer
Default Buying and bring a Canadian truck to the US
Can anyone tell me what is involved in buying and then bringing a Canadian truck to the US? I have no clue.
__________________
2007 LBZ Classic
Idaho Rob ATP tuning, MPI twin turbos
  #2
Old 03-12-2017, 10:01 AM
Burn Down's Avatar
Burn Down Burn Down is offline
Default
How stock or Modified is it Ken?
__________________
Albert
04.5 CCSB ole blue, built trans, mpi twins, 12.5X @ 108
03 Reg Cab ZF 6
05 CCSB Millennium Falcon, built eng, built trans, mpi twins, 11.51 @ 119 1.59 60
  #3
Old 03-12-2017, 01:06 PM
LBZ's Avatar
LBZ LBZ is offline
Default
The guy that tried to bring Nasty Girl across was unsuccessful and ended up pulling the engine and trans and I think Curtis ended up with the roller.
There might have been some other circumstances around his issues though.
I know every used truck including my old LBZ is getting sold to wholesalers and being shipped and sold in the US so it can be done.
  #4
Old 03-12-2017, 04:08 PM
lutzjk913's Avatar
lutzjk913 lutzjk913 is offline
Default
We buy Canadian trucks at work all the time.
Not sure on the steps though.
__________________
Joe
2008 CCLB LT2 DURAMAX LMM
13.44 @ 98.69
456HP 925 TQ
2003 Regular Cab LB7
  #5
Old 03-12-2017, 06:45 PM
duramaxdiesel's Avatar
duramaxdiesel duramaxdiesel is offline
Dmax Nut
Default
It's not too hard Ken. The more stock it is the better though. You need to know what border it will be passing through and I believe they need the paperwork 72 hours before it crosses to check out if all is legit. All recalls need to be rectified too before it crosses or it ain't going to happen.
Nick
__________________
2001 Chevy K2500HD Duramax/Allison Ex/Sb...Waaayyyyy far from stock;-)
2001 Chevy 3500 Dually Reg. Cab Duramax/Allson...Stock other than a Juice Box
2008 Chevy 2500HD Duramax/Allison CC/SB with some more info to follow...
  #6
Old 03-13-2017, 09:41 AM
Subman's Avatar
Old Geezer
Default
It's Simon's 2007 LBZ GMC Classic SCLB 2x4, sweet truck Has a few minor things done;
The truck has around 80 000 miles great shape, I don't think it's ever seen a gravel road! Under the truck looks like new.
transgo Jr. Installed
Small efi tune from Josh H. and dsp 5 switch in dash.
Spray in box liner
Roll n lock bed cover
New tires and rims with probably 2000 miles on them I think they were 20s ?
Bd full exhaust
led light bar mounted behind the grill
tinted back window
Fass 150 pump brand new not installed
egr block plate
Pvc reroute
all headlight mod
Top of line Kenwood double din deck 8" sub center console and door speakers ...sound great with the 2 amps
alarm system think viper
auto meter boost and egr temp not installed with full dash cover that holds the gauges nice setup
Djm lowering kit and adjustable rancho shocks all way around
Caltracks
ppe tie rod sleeves only install because I had them left over lol
Old full port exhaust up pipes from Abby (made by Paul a old member ) not installed
Recon 3rd light and tail lights tinted
New lb7 mirrors replaced the ugly cheap tow mirrors
blacked out marker roof lights
roll pan with b/u cam Kenwood
shimmed fuel rail
File Type: jpg 15209069_10154230540982545_1803296814_n.jpg (57.9 KB, 47 views)
__________________
2007 LBZ Classic
  #7
Old 03-14-2017, 03:32 AM
036.6turbo 036.6turbo is offline
Default
Quote:
I can't tell you the exact steps, but here in South East Michigan, it's done all the time. U.S Speedo makes a very good income converting the I.P.s over.
One of the guys at my gym, brings 300 to 500 cars / trucks in, every week.
He just has them converted to U.S. spec, so they are legal and then wholesales them out.
__________________
2003 GMC Sierra CCSB.
LBZ / Six speed / EGR Delete / DSP5 with tuning from Idaho Rob @ ATP Trucks / Bilstein 5100s / Air Ride 5000 bags / Merchant Reman Tcase / TNR head unit.
2015.5 Denali. Dmax Allison / Exergy Sportsman CP3 / WCFab "Y" Bridge with cold air bundle / WCFab 3" downpipe / LB7 up pipe / 4" Flo Pro exhaust / FASS 150 / Sump / AirLift 5000 bags with WirelessOne on board air / B&W Turnover ball / AMP Research power steps.
  #8
Old 03-14-2017, 06:03 AM
Hernpj01 Hernpj01 is offline
On a Time Out
Default
the truck has to meet all USA DOT and Compliance Regulations. I have done two trucks.
They pop the hood and look for the tag that states the truck meets all regulations and emissions standards in the US, also the driver door tag states the Vehicle is US complaint. If you look at your driver door tag you should see what I am referring too.
The two trucks I brought to USA, I was lucky with because they were originally from the states so the tags matched up for me. I think if it has Canadian tags GM has to get involved.
They are also forms that customs will fill out that you will take to your local BMV to title the truck. Its been awhile for me a couple years but I'm going to look back into importing more trucks.
  #9
Old 03-14-2017, 11:57 AM
LBZ's Avatar
LBZ LBZ is offline
Default
You should be able to bring that across no problem Ken.
I can't believe it took him a year plus to sell that truck. It is very clean but 2wd so useless up here.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vB.Sponsors
